Serpent 710
Old 07-23-2004 | 03:36 AM
  #14251
markp27's Avatar
Originally posted by InitialD
Somehow, blue looks good on the car !
Blue as in JP-FX blue?
markp27 is offline
Old 07-23-2004 | 03:37 AM
  #14252
markp27's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: rear anti-roll option
Onkel Sow? Naaahh... He's too old to be doing that. Besides, like you said, he's an old xxxxxx.
markp27 is offline
Old 07-23-2004 | 05:23 AM
  #14253
KevinS's Avatar
Default Re: Re: Re: rear anti-roll option
Originally posted by markp27
Not sure if anyone can confirm it, but I have heard that the "wire" anti-rollbars are better than the "blade" anti-rollbars.
Anyone know any better?
Both have up and down sides.
With a wire type rollbar it's easier to make small adjustments, but you have to make sure both sides are adjusted equally. Else it will be tweaked. Also it will not respond the same when rolling left as when rolling right. IMO a torsion bar also gets tweaked easier.
Small adjustments are harder to make with the blade type because it's hard to see over what angle you rotate the blade. Also the relation between angle of the blades and stiffness is not linear. But because the whole thing works like one springblade with a fixed arm length, it doesn't matter if both sides are not set equally.
I use the 1/8 scale blade type adjustable rollbar from Serpent on my 705. I put my Dremel to work and narrowed the blades down to 3mm over the whole length, or it would be too stiff. Then I polished the blades to take the Hudy spring steel brown color off the rest of them too. Looks and works great!
KevinS is offline
Old 07-23-2004 | 06:04 PM
  #14254
rcpanama's Avatar
Smile
Just for does ho are interested the following is the weight difference for this Serpent Options:
Part Number Aluminum weight / Original weight
802155 Bracket Middle Shaft Alu 6 g / 5 g
802136 Bracket Radio plate Support Alu 14 g / 7 g
802241 Anti Roll Bar Levers Alu Orange 7 g / 4 g
TOTAL 27 g / 16 g
This weight is with out any screws in the original as the option parts, this could have an error of +- 1 g
rcpanama is offline
Old 07-23-2004 | 08:35 PM
  #14255
TOTAL 27 g / 16 g
Thanks for sharing that.
Strange you know, coz when you load 60-70% of 3RC option alu parts, your 710 will ended up underweight badly.
The "mother snake" is only 1700 no fuel w/P Transponder.
Mine, bone stock, titanium screw only on topdeck and pro wheel axles weight 1710.
GoldFinger is offline
Old 07-23-2004 | 10:04 PM
  #14256
Suspended
Default TUNED PIPE FOR THE 710
I HAVE A RB CONCEPTS X12 ENGINE I AM GONNA PUT INTO MY 710 BUT WHAT EXHAUST (PIPE)CAN I PUT IN?ANY IDEAS?THANKS KEN
SERPENTFREAK69 is offline
Old 07-24-2004 | 12:02 AM
  #14257
markp27's Avatar
Default Already posted?
Not sure if someone has already posted pictures of the new anti-roll bar fixing kit - I just found some pictures on my LHS's website:
Also listed are anti-roll bars of thickness 2.5mm and 3mm.
The fixing kit has the number 802338 and the two new bars, 802337
Cheers, Mark.
markp27 is offline
Old 07-24-2004 | 01:01 AM
  #14258
PSI Racing's Avatar
TOTAL 27 g / 16 g
My car could live with a little extra weight.
PSI Racing is offline
Old 07-24-2004 | 01:05 AM
  #14259
PSI Racing's Avatar
Default Re: Already posted?
Cheers, Mark.
Did they give a release date?
Old 07-24-2004 | 01:21 AM
  #14260
Sow&Steady's Avatar
Default Re: Re: Re: Flight plan!
I have four letters for you, Sow.....J...P...F...X
Oh man you're making me nervous! I saw NiMo with his JP-Fx run and this thing not only sounded different but it is obviously as good as a standard 5-port turbo.
Sow&Steady is offline
  #14261
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: rear anti-roll option
Oh bugger! that was supposed to be a surprise!
Old 07-24-2004 | 01:22 AM
  #14262
Sow&Steady's Avatar
Originally posted by Proficar403
Here is my car with my new REX engine.
Why do you have the fuel feed tube so long Proficar?
Old 07-24-2004 | 01:23 AM
  #14263
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: rear anti-roll option
Originally posted by ttso
I read this thread all the way from page150, now on page230..
I guess it will cost me least 2 more weeks before I finish everything, you guys talk too much...
Naah ... we don't. Its D!
Old 07-24-2004 | 01:25 AM
  #14264
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: Re: rear anti-roll option
Originally posted by cyba888
Dont waste your time reading the rest, half of it is not even rc related If you have a problem just ask, unless you are that bored to read all of the posts
Or just download the file called 710 FAQ ... the link is under MarkP's posts. He and Glenn Cauley compiles good stuff from here and elsewhere and puts them in there.
  #14265
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: Re: Re: rear anti-roll option
As they say, it takes two to tango !
Yeah but for every tango "step" Mark makes, you do six!
