Serpent 710
Old 06-01-2004 | 07:16 PM
  #11776
InitialD's Avatar
Originally posted by GoldFinger
Im selling "way" cheaper than that in set packing.
I guess they treat volume buyer with great discount.
Hey bro, you have PM !
InitialD is offline
Old 06-01-2004 | 07:19 PM
  #11777
Originally posted by Sow&Steady
D, Mark forgot to mention to you that with his LSN only at 1.25 turns out, he is having to use 0.5mm of gap in the carb (Idle speed).
I think this is why his engine idles nicely but as soon as touches his throttle to speed up the engine gurgles and bogs down ... the HSN is richer than it should be to compensate for the small gap.
Right now if he leans the LSN further it doesn't help the bogging down issue right?
Uncle Sow, something to consider..
if your engine has to be 1.25 LSN to idle properly, there is a big chance that the compression is very low.
Quick test, dont touch/change LSN - reduce head shim by .1 mm or replace conrod(I suspect too much play in this part) your engine should scream instantly when trigger touched.
GoldFinger is offline
Old 06-01-2004 | 07:42 PM
  #11778
Pyramid's Avatar
Registered User
Originally posted by jhigga15
What do you guys think about the 710 Shocks??? I built mine and they don't seem too great...I think that my HPI shocks were better. Has any one replaced theirs?
In average, I believe I sent about 20hours learning and getting used to building the Serpent shock that once I HATE the most. Art Carbonell written a good tips about it as well I believe (about the bleeding from bottom). After that, you will then realize all other shocks are junks!
Pyramid is offline
Old 06-01-2004 | 07:47 PM
  #11779
Wap
Default Re: Re: Pics
Originally posted by PUNISHER
Looking good Wap!!
I'm planning to race in San Antonio this weekend.......Hope to catch ya there!!
still debating if i will go or not. What is the name of the new track down there? Do they have a web site.
thanks on the pics.
Wap is offline
Old 06-01-2004 | 07:55 PM
  #11780
Pyramid's Avatar
Registered User
Default Re: Re: Re: Re: Wear on Diff axle
Originally posted by GlennCauley
Beware of the 3Racing products!
I agree their quality below serpent in average. I just hate serpent screws and other thing (including shaft) that rust very easly. Also, check out the picture attahced.. another new supplier Glenn?
Pyramid is offline
Old 06-01-2004 | 07:56 PM
  #11781
Pheww..
jhigga15, dont give up on your 1st pair.
Just make sure the force needed to push(up) and pull(down) is the same. Together with good diff, this car is truly very wide sweet spot.
Old 06-01-2004 | 08:50 PM
  #11782
JustRace's Avatar
Originally posted by Marcos.S710
yes i will be racing that weekend!!
Marcos....what gearing do you use at FTS??
JustRace is offline
Old 06-01-2004 | 08:52 PM
  #11783
InitialD's Avatar
That's why I ended up with 5 sets of shocks !
Yeah, not forgetting the red hurting fingers.
InitialD is offline
Old 06-01-2004 | 08:54 PM
  #11784
InitialD's Avatar
I think that is not possible seeing Mark's engine is new !
Anyway, any tips on how to check for too much play in the conrod?
InitialD is offline
Old 06-01-2004 | 08:56 PM
  #11785
InitialD's Avatar
Default Re: Re: Re: Re: Re: Wear on Diff axle
Looks like it's brittle. How did it happen? Perhaps too much power from your engine !
InitialD is offline
Old 06-01-2004 | 09:00 PM
  #11786
Pit-racer's Avatar
Default Re: Re: Re: Pics
thanks on the pics.
Phat Boyz Hobbies in San Antonio. I think the races are on sunday.
Pit-racer is offline
Old 06-01-2004 | 09:01 PM
  #11787
JustRace's Avatar
Default Red shoe
Originally posted by InitialD
The stock clutch setting is a little soft. You either use the stock clutch mounts with the new yellow shoe as it bites better or mod the clutch and use the black shoe to get it to bite better.
Anyone tried the red shoes from Motorman? I tried it with a modified fly weight (added set screw). Works pretty good with the Serpent hard spring but I couldn't get it to work with the Mugen hard spring.
I was thinking of trying it with the cut fly weights to see the difference.
JustRace is offline
Old 06-01-2004 | 09:08 PM
  #11788
InitialD's Avatar
Default Re: Red shoe
You guys are very lucky to get to try out the red shoes from Dennis !
I've tried the Mugen hard spring on the stock black shoe and with cut flyweights way back early and found that the spring somewhat binds with the pre-tension retaining nut and the clutch nut if I recall correctly. This did not make for good clutch engagement. Went back to the soft stock one. Dennis says he does not have that problem and continued to mention that you probably need to smoothen out the burrs to get the correct fit.
I tried momentarily last week to use 2 of the M3x4 set screws on each of the cut flyweights (6 in total as per Goldfinger's suggestion) and mounted them in between the post with the black shoe. Not bad. Of course this was on my lowly 3 port engine.
InitialD is offline
Old 06-01-2004 | 09:21 PM
  #11789
Pyramid's Avatar
Registered User
Default Re: Re: Re: Re: Re: Re: Wear on Diff axle
Broke when making the mods to fit the bearing. Last batch are all ok on the exact same lathe macine with exact operator. Yes, looks brittle and that`s how the new SER-808220 shaft looks also when break on impact.
Pyramid is offline
Old 06-01-2004 | 09:23 PM
  #11790
JustRace's Avatar
Default Re: Re: Red shoe
I did find that the Mugen spring binds. Also it actually longer than the Serpents. I even tried the Mugen with the retaining nut flat with the clutch nut ( i.e. 0mm instead of the usual .5 to 1 mm) and did not get good engagement.
JustRace is offline
