Old 06-02-2004, 01:56 AM   #11806
InitialD's Avatar
Originally posted by mariochi
Hi D,
Fantini is a good engine but in my experience yuo can buy ,if you find it out of Italy Novarossi NS12S3 or NSR12S3(this last has the microcasted piston) signed by Mario Rossi (Mario Rossi edition).
The price is 20-25%less than Fantini but we all like it the same .
I have open these two engine and I don't find great differences.
Thanks for the info Mario. I don't think we are able to find Mario Rossi edition of the Novarossi engines you mentioned. I thought Mario Rossi only did 1/8th scale engines...
Have any pics to show us how the external / internals of the Mario Rossi engine looks like?
Old 06-02-2004, 01:59 AM   #11807
InitialD's Avatar
Originally posted by GoldFinger
Not always the case but mostly idle quality( ) is depends on compression/ healthy of the engine. And I thought 1.25 LSN is not healthy already.
Perhaps the opening at idle was pretty small (less than 1 mm). So lean LSN was required to compensate for that.
Take off the plug, make the piston (stuck) in TDC.
If you play the flywheel around 60 deg (10 minutes), its time !!!
Cool. Thanks for the tip. Being able to turn the flywheel in 10 minutes is a lot !
Old 06-02-2004, 02:28 AM   #11808
This is a new trick ?
You mean to adjust the idle speed using LSN? since the idle screw is constant in .5mm
GoldFinger is offline   Reply With Quote
Old 06-02-2004, 02:38 AM   #11809
InitialD's Avatar
Not a new trick ! Promise. Leaning the LSN little by little, you'll notice the idle will go up slightly when you come to a point. I guess this indirectly affects the idle...
Old 06-02-2004, 02:47 AM   #11810
markp27's Avatar
Send a message via ICQ to markp27
No, it was my fault! I think I had the HSN set incorrectly and it affected the LSN in such a way that I had to make the LSN very lean and this lead to the gap only being 0.5mm.
Either that or my 2106 really is more damaged that I first thought
markp27 is offline   Reply With Quote
Old 06-02-2004, 03:39 AM   #11811
PSI Racing's Avatar
Originally posted by jhigga15
I will go home and check...
Thanks for the help
Here are some articles that might help you with your Serpent shocks.
http://www.ashfordhobby.com/tech02.htm
http://www.mytsn.com/publ/publ.asp?pid=2178
There's another article, but I can't find it at this moment.
PSI Racing is offline   Reply With Quote
Old 06-02-2004, 04:19 AM   #11812
mariochi's Avatar
...Have any pics to show us how the external / internals of the Mario Rossi engine looks like?
No. I have only photos of an old Fantini of the last year(piston not microcasted )
mariochi is offline   Reply With Quote
Old 06-02-2004, 04:23 AM   #11813
mariochi's Avatar
Externally Mario rossi is identical to a ns12s3 or nsr12s3 but with the little signature on the top "M.R."
Internally is worked on the sleeve externally and on the crankshaft as the fantini but it seems to me that the shaft is worked more radically in M.R.
Old 06-02-2004, 05:12 AM   #11814
PSI Racing's Avatar
Default Paint
Crashed,
What kind of paint do you use on your bodies?
Old 06-02-2004, 05:33 AM   #11815
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Originally posted by JustRace
Marcos....what gearing do you use at FTS??
for the 710 i used the stock.
Old 06-02-2004, 05:33 AM   #11816
Sow&Steady's Avatar
Uncle Sow, something to consider..
if your engine has to be 1.25 LSN to idle properly, there is a big chance that the compression is very low.
Quick test, dont touch/change LSN - reduce head shim by .1 mm or replace conrod(I suspect too much play in this part) your engine should scream instantly when trigger touched.
GoldFinger, that's a good point but Mark's engine is brand new I think. He was running it in. I hope he hasn't damaged the conrod already!
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 06-02-2004, 05:40 AM   #11817
Sow&Steady's Avatar
Default Re: Re: Re: Red shoe
Originally posted by Pyramid
Beware.. with max s5, hard spring, 0.7gap, the front end of the car looks like wanted to fly up the minute you push that trigger.
Pyramid, you find that with this kind of power/punch that your belts last?
Old 06-02-2004, 05:43 AM   #11818
Sow&Steady's Avatar
Originally posted by markp27
Hi Goldfinger - you may have hit the nail on the head, as it were. I rebuilt my 2106 and had to use an old conrod, as the new one hadn't arrived!! The conrod is ready for replacing and will be replaced before the next run.
Cheers, Mark.
Ah, I must have missed that part Mark, I thought its a brand new engine that were running in!
Old 06-02-2004, 06:05 AM   #11819
markp27's Avatar
It was, but then came the damaged crankshaft which destroyed the conrod. I ordered a new crankshaft and conrod, but the conrod didn't turn up So I used my "older" conrod from my 12 RE - so I have essentially a new engine with an old conrod, so what Goldfinger said could well be true
Old 06-02-2004, 06:37 AM   #11820
PSI Racing's Avatar
Sow&Steady,
I just downloaded and watched the BRCA 1:10 Final videos.
Nice work!
Seems like everyone on that driver's stand was using stick controllers.
