Serpent 710
Old 05-07-2004 | 12:23 AM
  #9721
markp27's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Camber (rear)
Originally posted by BaxterC
Thank you, The more I think about it, the more it will be an ALL Important tool, I am having nightmares about uneven shocks, I dread building shocks, but I think this would help greatly.
Shocks are definately very important to get right - next to tweaking, they are probably the item that I spend most time in getting right - so a good tool is not a waste! But don't stress yourself if you haven't got the Losi tool, you can do it almost as well by hand.
Shock building takes a little practice - even though the first time I built mine, I'd read all the instructions and tips, it wasn't until building the 710's shocks that I felt I'd done a good job
markp27 is offline
  #9722
markp27's Avatar
D, here's where I cut the holes for the posts and look no thingys!
markp27 is offline
Old 05-07-2004 | 12:24 AM
  #9723
markp27's Avatar
Damn, wrong button here's the pic.
markp27 is offline
Old 05-07-2004 | 12:27 AM
  #9724
markp27's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Camber (rear)
The border are DANG expensive... 33 odd euros... I found it at $29
RCModel
Potential import duty and shipping costs make the border cheaper for me.
markp27 is offline
Old 05-07-2004 | 12:28 AM
  #9725
markp27's Avatar
Originally posted by InitialD
I would just drill a hole in the post lower so that the "thingys" would sit lower. I think that was how I did mine. I cannot remember...
That's what I was thinking - I'll get the dremmel out!
markp27 is offline
Old 05-07-2004 | 12:56 AM
  #9726
Serpent Nut!'s Avatar
hi guys!
im just really curious what would be the best fuel? meaning great power and has good lubrication not that corrosive... hhhhmmm what you guys think?
Serpent Nut! is offline
Old 05-07-2004 | 01:02 AM
  #9727
InitialD's Avatar
Default Re: hi guys!
What fuel do you have available at your LHS?
InitialD is offline
Old 05-07-2004 | 01:05 AM
  #9728
markp27's Avatar
Tornado (used by the Serpent guys) and Runner Time fuels are very popular here! Generally most use the 16% mix - this is what I use.
markp27 is offline
Old 05-07-2004 | 01:42 AM
  #9729
BaxterC's Avatar
Default Re: Re: hi guys!
I agree with you on tornado, good fuel, I was going to import it but it was too expensive customs wise. I use sidewinder 16%, also great fuel, will make my motor sing tomorrow
BaxterC is offline
Old 05-07-2004 | 02:17 AM
  #9730
KevinS's Avatar
I'm not sure, but I think my 705 kit came with additional very short body posts, with only 2 holes in them. I used those and actually had to put shims underneat because the body was sitting too low.
KevinS is offline
Old 05-07-2004 | 02:48 AM
  #9731
PSI Racing's Avatar
My Impulse came with those small body post also.
That's what I used when I used the GTP body.
PSI Racing is offline
Old 05-07-2004 | 03:10 AM
  #9732
markp27's Avatar
Are you guys using them on the front rammer? or in the original touring car body post position like in my pic below?
http://www.rctech.net/forum/attachme...&postid=866205
markp27 is offline
Old 05-07-2004 | 03:12 AM
  #9733
PSI Racing's Avatar
I had mine setup the same way you have it in the picture.
My upper bumper is cut the same way you have it also.
Old 05-07-2004 | 03:51 AM
  #9734
PSI Racing's Avatar
Default Clutch
Is anyone using the stock Centax III, or has everyone modified theirs?
Would the new yellow clutch shoe (802509) help with the slipping clutch problem?
Here's a description of the new shoes.
To increase performance of the Centax 3 clutch system even further, Serpent are pleased to present the new yellow clutch shoe. The new material reduces the clutch slipping, which therefore allows more power to get to the wheels. This creates a more efficient performing clutch system but does make the engine work harder.
Isn't the stock clutch shoe an XP type?
I know on the older clutches the yellow was the stock clutch shoe.
They also had a black one that allows slip and an XP one that was supposed to give more punch.
If the stock Centax III shoe is an XP, why would the yellow one have less slippage?
Old 05-07-2004 | 04:47 AM
  #9735
KevinS's Avatar
And the same goes for me.
I think the bumper is too flexible to hold the body.
KevinS is offline
