Serpent 710
Old 04-26-2004 | 09:07 PM
  #8971
Pyramid's Avatar
Registered User
Default Re: Which Motor
Originally posted by Wap
Hey guys these our the motors i am thinking about buy. I want to be legal with the rules. which one should i buy
I bet the following legal motor is better in all aspects,
NRS-RR12L3 L3 Long Stroge .12 Engine
Pyramid is offline
Old 04-26-2004 | 09:11 PM
  #8972
Pyramid's Avatar
Registered User
Originally posted by Profoxcg
has anyone tryed this mod yet? with the bearing? what is it supposed to do?
Just to make it turns smoother... Making the inner hub diameter bigger(to host the thrust bearing) is more important than putting that bearing in between.
Pyramid is offline
Old 04-26-2004 | 09:12 PM
  #8973
make the diff turn smoother or the car overall?
Profoxcg is offline
Old 04-26-2004 | 09:21 PM
  #8974
Pyramid's Avatar
Registered User
It will sure to make the car overall... but if you are talking only putting the bearing in that spur gear which will take a difficult work (to make the bearing sits absolutely center), just do the other parts (bigger inner diameter and polishing) that generates 95 percent of the smoother running diff aspects.
Pyramid is offline
Old 04-26-2004 | 09:23 PM
  #8975
Wap
Default Re: Re: Which Motor
I one of those guys if it aint broke don't fix it. the nova mega work so good in my impulse for 6 years no problems, i won't to stick with nova megal. Michael S turbo motor legal and which one do you think?
Wap is offline
Old 04-26-2004 | 09:24 PM
  #8976
what are your thoughts on the 3racing diferential gear. do you think it will be smoother compared to the kits plastic one?
how can i have the hole bigger?
thanks!
Profoxcg is offline
Old 04-26-2004 | 09:29 PM
  #8977
Pyramid's Avatar
Registered User
Default Re: Re: Re: Which Motor
2105MCP should be the better one among your choice. Is Maxpower MAX-MX12MAX5MF NOVAMAX U/C 2,1cc 5P.TRB also consider legal? RR12L3/L5 will still have more power from low to mid range. I believe this is the engine that Fukuda (and Swager?) gives MS someting to remember on winternats...
Pyramid is offline
Old 04-26-2004 | 09:33 PM
  #8978
S710 Rear Shock Tower and front A Arms are not that STRONG!!
Our concrete wall is stronger than 710 ??
Been there, done that... many times..
You just too fast, the 11.347 is unbelieveble !!
For others information, another fast guy in the second fastest lap is only able to makes 11.746.
GoldFinger is offline
  #8979
Pyramid's Avatar
Registered User
thanks!
45T Aluminum Pulley? it will never be since those diff balls will be in friction directly with aluminum. Using those aluminum pulleys will make the tranny runs smoother...
Pyramid is offline
Old 04-26-2004 | 09:39 PM
  #8980
Pyramid's Avatar
Registered User
thanks!
Bring it to the work shop.. a decent lathe machine should be able to do it. Furthermore, in order to help the bearing sits in the real center of pulley, bring used drive belt to cover the tooth for lathe`s chuck to hold the diff gear (45T) better. Idea courtesy from Gold Finger...
Pyramid is offline
Old 04-26-2004 | 09:55 PM
  #8981
pyramid, so the alum 3racing pulley is not a good idea?
Profoxcg is offline
Old 04-26-2004 | 10:32 PM
  #8982
InitialD's Avatar
Default Re: Re: Re: Re: Which Motor
Ummm, that's a sensitive issue ! More like % nitro at work.
Anyway, I think Rene C gave a report on the Pre-Worlds at Brazil. He mentioned that the engines used by the Japanese (assuming those were RR12L3 Kondo ones) were around the same as what they had.
InitialD is offline
Old 04-26-2004 | 10:33 PM
  #8983
InitialD's Avatar
Originally posted by Devil666
Hi everybody, just sold off my mugen over the weekend and got the 710... Started building it yesterday, hopefully able to get it done by this weekend. The Serpent FAQ's are a real help!!!
If you need any help, you know where to find me.
InitialD is offline
Old 04-26-2004 | 10:39 PM
  #8984
AMGRacer's Avatar
Default Re: Re: Re: Re: Re: Which Motor
Man Salvens excuse factory was working overtime there. If the Mugens were running 40% why did not he? Is he not Serpents best racer? How could the "unbeatable" Serpent factory team get out motored? It is no excuse in my book, he just needs to accept that the Serpent guys had not done their homework on that weekend when it came to motors, the Mugen guys had the car speed.
The pre-worlds was run to IFMAR rules, 16% nitro. This will even up the playing field when it comes to "funny fuel".
AMGRacer is offline
  #8985
InitialD's Avatar
Hey Pyramid, next time slow down and don't assume the 710 is invinsible OK?
That looks like the old rear shock tower doubled up. I think the new 3.5 mm single piece rear shock tower is stronger.
InitialD is offline
