Serpent 710
Old 05-03-2004 | 12:04 PM
  #9331
Marcos.J's Avatar
Super Moderator
Default Re: New rims/tyres to test.
Originally posted by markp27
I'm trying out the Arrows tyres/rims hopefully this week. They look nice (see pic), but one curious thing is that the socket for the wheel hub is larger than on the Serpent rims - this means that the wheels have a bit of play before I tighten down the wheel nut Hmmm, I'll see how they perform before judging any further.
hey try these,monotuning tires
i ran these tires on my 710 and they are great!!!!!!
Marcos.J is offline
Old 05-03-2004 | 12:08 PM
  #9332
markp27's Avatar
Do you have an email address for those guys? I'll have to see if anyone is selling them in Germany,
Cheers, Mark.
markp27 is offline
Old 05-03-2004 | 12:12 PM
  #9333
Marcos.J's Avatar
Super Moderator
Cheers, Mark.
email is [email protected]
tell Aaron that Marcos recommended you.
Marcos.J is offline
Old 05-03-2004 | 12:23 PM
  #9334
markp27's Avatar
Will do, thanks for the info.
Mark.
markp27 is offline
Old 05-03-2004 | 12:26 PM
  #9335
Marcos.J's Avatar
Super Moderator
Mark.
you are welcome!!
Marcos.J is offline
Old 05-03-2004 | 01:24 PM
  #9336
Julius's Avatar
Default Re: Measuring coned tyre diameter
Hi,
Would I be right in thinking that I should take the diameter measurement from the centre of the tyre when the tyre is coned? i.e. if I want to use equal sized tyres front and back, then with the coned tyres a central measurement should then correspond to a central measurement of the non-coned tyres?
Cheers, Mark.
I always measure the outide (largest) diameter. Coned or not.
Julius is offline
Old 05-03-2004 | 01:27 PM
  #9337
rwisejr's Avatar
I am running the ellegi ones which are the same as the arrows and last timeout someone bumped me into a curb and I had the spokes crack on 3 rims I am no trying out the monotuning tires that Marcos is using and the rims seem to be a lot stronger. I purchased mine from here http://www.kinetixrc.com
rwisejr is offline
Old 05-03-2004 | 01:51 PM
  #9338
How come everyone is running these spoked wheels?? Wouldn't dished wheels be much stronger? Just a thought.
SupermaxxRich is offline
Old 05-03-2004 | 02:46 PM
  #9339
Aggdaddy's Avatar
Gotta have a little flash.
Dish rims look so boring.
Aggdaddy is offline
Old 05-03-2004 | 05:01 PM
  #9340
JustRace's Avatar
I'm using the dish ones from www.twistertires.com. They're very strong and I think it's great for the 710. It's resistant to bending so it eliminates the wheel from rubbing on the front steering hub and link.
JustRace is offline
Old 05-03-2004 | 05:16 PM
  #9341
rwisejr's Avatar
Those look pretty good aswell but I just got the mono's and want see how the work before I try anything else.
rwisejr is offline
Old 05-03-2004 | 06:45 PM
  #9342
Originally posted by Julius
You have side traction (ability to not slide outward in a corner) and forward traction (ability to accelerate in a straight line out of the corner).
In a way with foam tires, more camber change gives more side traction but less forward traction. If the camber change is big the tire will angle more in the corner resisting the side forces better. But with a big camber change during braking or accelerating the tire contac area gets less so you lose grip.
Make sense?
Thank you for brought me this new zone.."forward traction".
Less contact area when camber change is big only can happen if the tire is not coning enough. So if the rear tire is still flat, that is make sense.
Been testing for 3 days, Im running 4 deg rear camber (tire coning about 2 deg.), 70-80 diff lock and 6mm front caster.
The more camber change during cornering and accelerating/braking is creating more traction. I think because the foam tire is in a way creating wider contact path, near to 31mm.
With 4 deg rear camber, the temp reading in outside, middle and inside part of the tire is only 1 deg. differ. the outside is the hottest, middle and inside is only a fraction.
GoldFinger is offline
Old 05-03-2004 | 06:48 PM
  #9343
Originally posted by Pyramid
Do you guys remember someone bought a impact dogbones that are now comes in black color just like the regular one? In fact we did receive some new shipments and they are, indeed, in black...
What I would like to ask is, I remember someone over the factory claimming it was in the same quality as Hudy spring steel.. With all do respect... How do you know if it is in the same quality?? they even look weaker than the 710 standard bones.
....Aahhh you were being too polite lah....
Spill it out bro !
A photo will be more representative..
Old 05-03-2004 | 08:01 PM
  #9344
Sow&Steady's Avatar
Oh, that's ok, no need to worry there - it'll be as dry as the sahra within in couple of weeks You'll be able to look forward to a good summer with moderate temps (max around 32 Degrees, average around 23).
Cheers, Mark.
Oooo ... hope so!
Sow&Steady is offline
Old 05-03-2004 | 08:03 PM
  #9345
Sow&Steady's Avatar
I've tried Arrows and I really like the foams. I remember having some problems with the inner part of the rims though but not so much on the "play" of the hex.
Let us know how you got on with them.
