Serpent 710
#9481
Originally posted by BaxterC
Perfectly clear skies here, not a cloud in sight... but the 710 is in pieces...
Anyway, Is there a quicker way of getting hold of Mr Bervoets? I will go onto the myTSN Forum and post, but I am checking for a quicker way?
#9484
Originally posted by InitialD
Congrats on your first run Mark ! Are you sure the pic was taken after you drove the car?
But now all is ok. I was going to try some 37 tyres today, but the way the weather is, I've got no chance!
#9485
Originally posted by Voodo_Magic
Hi Julius i have been using the default setup of my-tsn, and having a look i thought i might try Rene Cornella's setup http://www.mytsn.com/setups/setup.asp?sid=2311 because he was using the front diff and try that
the body iam using is a dodge stratus version 1
#9487
Originally posted by markp27
Don't bother with the forum - email him direct: [email protected]
#9489
I tried that setup. Apparently it makes the front end tires lift up a little on throttle. It looks like as if it was doing wheelies...
Has Rene been training to be a stunt driver
#9492
WOW!
WOW!
The track we ran last weekend was bumpy. So I guess more droop was required. Rene's setup used a front droop of +2.
#9493
Yep
What oil is best to use for the engine bearings?
Yep
#9494
So you think the one-way would work best, not the ball diff?
#9495
My car weighs 1709 grams with only the fuel missing. How's this compare to anyone elses - mine is kitted with lots of titanium screws, so should be a bit lighter than normal.
Titanium screws and 2 speed mainshaft only with Tornado external fuel filter.
