Old 05-19-2004, 09:50 PM   #10831
fmolzer's Avatar
Originally posted by stormperson
Hi,
I just started to build my 710 and due having the first step have the wrong part (two left side lower bulkheads, no right side, lol) I started on other parts and build the shocks and radio tray. Which leads me to ask...
what were they thinking but the rx and servo's right in the path of fuel overflow? Has anyone has issues with this? Its kinda hard to protect the rx or put it in a bag since there isnt much room and the wires wouldnt quite fit... Anyone have insight into this?
Sorry to hear you got a kit packed on a Monday morning As for Rx and servo being subjected to fuel, I put my Rx in a baloon and acctually never have had a problem with it or with the Servo for fuel spills. Most Rx will fit inside a baloon and all the wires too, you just need to plan for it. I have used both Novak and Futaba Rx:s with no problem. The wires can be bundled up neatly together and tuck to the die of the Rx, or you can fit them in under the upperdeck, between steering and throttle servo. All this said, if you ask Michael Salven, he did get his day ruined when someone fuled his Rx in the 710 at winternats.....
fmolzer is offline   Reply With Quote
Old 05-19-2004, 09:50 PM   #10832
Originally posted by InitialD
Ummm, I don't know if jhigga15 refers to radio as in WITH the servos or not. I think the radios from RCMushroom does not come with servos...
If I had a limited budget, I would invest in good servos and a normal Tx/Rx.
No the 3-PK (from rc-mushroom) does not come with any servos
Brett.w is offline   Reply With Quote
Old 05-19-2004, 10:07 PM   #10833
Hi,
this is what i use when in a long final, I know it is a bit crude but it protects from over flow of fuel on to electrics
Old 05-19-2004, 10:58 PM   #10834
rodrigo1508's Avatar
hi, just wanted to share my excitement, I got my second 710!
rodrigo1508 is offline   Reply With Quote
Old 05-19-2004, 11:06 PM   #10835
InitialD's Avatar
Damn. Now who's got a 3rd kit?
Hey, so now you have two 710 and one R40?
Old 05-19-2004, 11:07 PM   #10836
InitialD's Avatar
Default Re: Re: Re: Re: Re: Question
Originally posted by crashed_1
I still have that little bit of NTC3 in me...
Old 05-19-2004, 11:09 PM   #10837
Send a message via Yahoo to speedy100
Default 710
hey all, i just switched to 710 from G4..any one know some good setting for 710 ? i bulit the kits and found the servo has a bit interference to the front belt. any solution to this ?
can anyone tell the alignment of the wire ? thank for advance
speedy100 is offline   Reply With Quote
Old 05-19-2004, 11:11 PM   #10838
markp27's Avatar
Send a message via ICQ to markp27
First race today - public holiday here - nervous? YES! But I'm going to have to do it with my 705 and my old SX 12 RE Oh well, lets see how it goes!
markp27 is offline   Reply With Quote
Old 05-19-2004, 11:12 PM   #10839
InitialD's Avatar
If you say the 710 has very limited space, wait till you see the G4 ! This is a pic taken and posted by Rene Cornella.
Old 05-19-2004, 11:14 PM   #10840
Hopefully my 2nd arrives tommorow
Old 05-19-2004, 11:17 PM   #10841
initial D, sorry i am saying the servo linkage of the rod very close to the front belt when it is in motioned, not the servo
Old 05-19-2004, 11:24 PM   #10842
InitialD's Avatar
Default Re: 710
For oneway front and rear ball diff setups, you can take a peek at the following;
http://www.mytsn.com/setups/setup.asp?sid=2366
http://www.mytsn.com/setups/setup.asp?sid=2434
http://www.mytsn.com/setups/setup.asp?sid=2384
For the front ball diff on the 710, Rene's setup in Brazil looks pretty good.
http://www.mytsn.com/setups/setup.asp?sid=2311
Look at the FAQ. I believe there is some write up there that I posted earlier on. You need to shorten the linkage from 44.5 mm to somewhere like 39 or 40 mm. It involves some cutting.
Old 05-19-2004, 11:24 PM   #10843
How did he do that i struggled to fit the fuel tank in when i tried that way, or mybe i have too much wire
Old 05-19-2004, 11:26 PM   #10844
InitialD's Avatar
What is this? A gathering for those with a 2nd 710 kit?
Old 05-19-2004, 11:28 PM   #10845
InitialD's Avatar
Cool. Good luck ! No wonder somebody's burning the rubber on the tracks !
