Old 01-23-2004, 01:50 PM   #3331
serpentracer1's Avatar
Send a message via AIM to serpentracer1
Chris I deal with Lee also Great guy to talk to Ive got a Murnan and it rocks Im going to have him get me another one this time a Turbo 3pt cause they are roar legal now.I can say nothing but good things about Lee at Winners Circle and Murnan Modifieds motors.
DAVE (THE SNAKE) Rasnake
Original Mimi Wong Clan. M.W.C. For Life
Associated B6D
Orion R10 Pro VST powered
serpentracer1 is offline   Reply With Quote
Old 01-24-2004, 12:40 AM   #3332
Derby Bros Racing's Avatar
Default 710 upgrades
[b]ok guys help me out...
i need to know which parts fit and what.
i'm planning on bulletproofing my car the best i can so i hope you guys can help me...
1. which dog bone will fit the 710? will the 835 dog bones fit? i want spring steel.
2. is there any hardened shock shaft available? will the 8th scale shock shaft fit the 710?
3. i don't care much about the weight so i want to add titanium pivot balls on my 710. what titanium pivot ball will fit the 710? i need something that is available now
4. i need to double my rear shock tower. does anyone know where i can get this right now
5. is there any spring steel axle available that will fit the 710?
sorry for asking too much in one post. i hope you guys understand.
thanks in advance for your help[b]
Derby Bros Racing is offline   Reply With Quote
Old 01-24-2004, 01:12 AM   #3333
sparksy's Avatar
Trader Rating: 14 (94%+)
Default Re: 710 upgrades
Originally posted by evlhdlts
[B][b]ok guys help me out...
1. The 835 front dogbones fit all round
2. The shock shafts are all the same size throughout serpent's current cars. With the front shafts shorter than the rear. So yes the 8th scale shafts will fit.
3. I have seen Titanium pivot balls on Ebay.
4. Try the shop you got the 710 from.
5. The front springsteel outdrives from the 705/835 fit with a little trimming. The front spring steel axles from the 705 will fit all round.
sparksy is offline   Reply With Quote
Old 01-24-2004, 01:38 AM   #3334
Default Re: Re: 710 upgrades
thanks a lot for the quick response.
i do have some questions though.
1. this one is ok...
2. so the 950 front and rear is what i need for the shock shaft? are they the same material or stronger?
3. this one is ok...
4. ive tried the shop i got my 710 from... no luck. any other places to get a rear shock tower??
5. did you mean the 835 needs a little trimming and the 705 is ok? i mean, do the 705 spring steel axles fit with no modification?
thanks again in advance.
Old 01-24-2004, 01:44 AM   #3335
InitialD's Avatar
To be specific, the 950/R, the 835 and the 705 shares the same identical shocks as the 710. So that is why they will fit !
Just a word of caution. You need to get the keyed type shock shafts (909442 for front and 909444 for rear). Not the older threaded ones (although they are identical lengths to the front and for the rear of the 710) as they are for the Serpent older cars (Impulse Streetspec, Impact and the Vector).
Be careful if you come across the titanium pivot balls for the 705 as they may be slightly longer. Besides, Julius mentioned that titanium pivot balls will cause glass filled plastics to wear faster.
Old 01-24-2004, 01:47 AM   #3336
sparksy's Avatar
Default Re: Re: Re: 710 upgrades
4. No idea.. you could look at a few of the online stores.
5. I'm 99% sure they are the same item. They are too long ane need to be shortened. I mentioned them as 835 parts as thets what I have them for. I've never had a serpent 200mm before the 710.
Old 01-24-2004, 01:52 AM   #3337
InitialD's Avatar
As I mentioned, there are only 909442 (front) and 909444 (rear) shock shaft part numbers for 950, 835, 705 and 710 !
I think you are confused here... sparsky mentioned that the 835 dogbones (they are only available in Hudy spring steel) will fit fine on the 710. The 705 dogbones (whether spring steel or not) will not fit.
The one way outdrive of the 705/835 (or even the XRay or the Mugen one) will fit on the 710. This includes the lightened one way outdrive for the Impact which will fit nicely on the 710.
HOWEVER, when you do this on the 710, you will not have the ability to lock the one way unit to make it into a solid axle front.
The front wheel axles of the 705 (also the same as the Impulse Streetspec / PRO) will fit the 710 all around as it is the same part. The 801215 is normal steel while the 801214 is the Hudy spring steel one.
Hope that is clear.
Old 01-24-2004, 05:33 AM   #3338
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
here is the finals body for winternats, before color is added
Team Tekin, Team Scream, Paint By Mike, Team Mölzer Mowery Racing, EA Motorsports, Speedmerchant, TQ Wire
MMR Direct Minneapolis World Class Indoor Race Facility.
On Road and Off Road racing year round.
www.molzermoweryracing.com
http://www.facebook.com/pages/MMR/160679913944205?__req=9
Check out You Tube mmrswracing. Every qualifier and every main uploaded at the end of every race day.
ammdrew is offline   Reply With Quote
Old 01-24-2004, 05:40 AM   #3339
ammdrew's Avatar
and the nose..
Old 01-24-2004, 05:43 AM   #3340
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: Friday pics
Originally posted by InitialD
Most local races do not support the new personal transponder yet !
Actually they can, they just don't want to look into doing it.
Also, Unc Aw, Yok folks and Shariman's systems are the latest ones that directly support personal transponders.
Sow&Steady is offline   Reply With Quote
Old 01-24-2004, 05:44 AM   #3341
Sow&Steady's Avatar
Originally posted by ChrisBlack310
Try this place out.
http://www.gasrccar.com/
They carry Murnan modified engines. On their site, they only have the modified Mugen MT12 listed. I'm sure Lee could get other ones. I'm just not sure if he ships to other countries.
Chris, thanks for the link. I'll check it out.
Old 01-24-2004, 05:46 AM   #3342
Sow&Steady's Avatar
Originally posted by modellor
You could go for a Palmaris. Same day replies and definately shipped worldwide.
Modeller, you're right ... PM response almost immediate! Now THAT'S customer service
Cool avatar by the way ..
Old 01-24-2004, 07:02 AM   #3343
crashed_1's Avatar
Default Re: Re: Re: Re: Re: Re: Friday pics
Saw some folks already using em @ one of the races @ Titiwangsa....
crashed_1 is offline   Reply With Quote
Old 01-24-2004, 07:48 AM   #3344
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Friday pics
My point exactly
That must be the new system they used for the recent electric race right? Maybe it was run using Yok's system.
Old 01-24-2004, 07:49 AM   #3345
quozl's Avatar
Just get your club a copy of Slyfox we've been using it at our club with personals for the past 3 seasons. Used and proven at IFMAR world championship, AARCMCC State and National titles, FAMAR titles and numerous other club and national events in Europe and the USA. Simple and easy to use and setup any racing from club races to National, FEMCA and IFMAR titles. Check it out at
http://www.genisys.net.au/Quantum/
Tell Randall I sent you.
Cheers Alastair
quozl is offline   Reply With Quote
