Serpent 710
Old 04-05-2004 | 03:20 PM
  #7771
I don't really use them for the tires unless I run my tires out of the box (64mm) less prong to chucking.
So that is what those stickers are for...
so new tyres break easily without them?
bc i havent noticed lower tyres chuncked as much.
one thing that bothers me is that everytime I hit something I bend my front rims.... =(
Profoxcg is offline
Old 04-05-2004 | 03:33 PM
  #7772
PSI Racing's Avatar
Default Re: Re: Re: Re: Re: servos
Originally posted by cox049
In what situation will you notice 180 oz of torque on a 1:10 on-road car??
After you hit a couple of boards, you'll notice the 180 oz of torque.
When your front end is all messed up, and you're still able to turn.
When your car is toast, but your servos still work.
Would you notice a .05 second difference in servo speed?
Probably not, that's why I'd take the extra 69 oz of torque.
PSI Racing is offline
Old 04-05-2004 | 06:49 PM
  #7773
Not breaking………Chunking the tire
Yea, those stickers are for a reason…………..
They are supposed to be placed on the sidewall of the tires for helping in chunking the tire. When the tire is new out of the box it’s 64mm or more and has a large sidewall that is prone to chunk. When you true or cut your tire down to a smaller size it dosnt have the large sidewall that makes it less prone to chunking. Also keeping the car off the walls will help in chunking tires!
PUNISHER is offline
Old 04-05-2004 | 07:02 PM
  #7774
InitialD's Avatar
Default Re: A second look....
Originally posted by markp27
Thought I'd post a couple more pictures of my new colours, as the one last night was a bit rushed
Ah, that's better ! Nicer without the background props !
InitialD is offline
Old 04-05-2004 | 07:03 PM
  #7775
InitialD's Avatar
Default Re: Mazda6
Originally posted by PUNISHER
I got to run my Mazda6 for the first time last weekend and was very impressed how well balance the car felt. Its between a 2.1 Stratus and an Alfa Losi. Has good front-end downforce like the Alfa but without the agressive feeling (smother). Also I heard that Protoform just lost the rights to make the Stratus bodies so this Mazda6 is a very good replacement!!
Here is my Mazda6............
You always have one of the best bodies around, Punisher !
Yup, that was what I observed after running a friend's Mazda 6 on a 710 for a few laps. Pretty neutral body I would say.
InitialD is offline
Old 04-05-2004 | 07:08 PM
  #7776
thanks for your answers!!!
so does anyone know to to tell if the low end is too rich or too lean?
what kind of pipes do you guys run?
my is an ofna X12 two piece. I think it leaks from the seals...
Profoxcg is offline
Old 04-05-2004 | 07:14 PM
  #7777
PSI Racing's Avatar
Default Volvo
Has anyone tried out the 170019 Volvo body by Serpent?
Old 04-05-2004 | 07:22 PM
  #7778
Default Re: Re: New Colours
Mark, you owe me some of those besten Nuremberg Lebkuchen that you enjoy at home
Here is a pic of my "mechanical orange" ( the colors now borrowed from you) My bodies are more battle type ( they don't last very long ) But the serpent spirit is very present!
Your car looks awesome!! Can the tires turn with the body that low over the front wheels. I love the way it looks! I'm gunna have to paint my next body up like that.
SupermaxxRich is offline
Old 04-05-2004 | 07:49 PM
  #7779
Arun's Avatar
.05 seconds difference in speed is HUGE as far as I am concerned. I run the KO2143 on everything.
I am surprised that you cannot tell the difference, because I could even tell the difference when changing from the futaba 9402 (.11) to the KO2143 (.08).
Arun is offline
Old 04-05-2004 | 08:05 PM
  #7780
PSI Racing's Avatar
I guess my driving skills aren't that good to notice 5 hundredth of a second.
Keep in mind, I never said I compared them in the car.
I was comparing the 2 servos on paper.
Just seeing the differences in specs, I went with the 2344, because I felt that I wouldn't notice a .05 second difference, but I like having the extra torque.
Maybe it was such a huge difference because you are comparing a standard servo (9402) to a digital (2343)
Old 04-05-2004 | 08:12 PM
  #7781
InitialD's Avatar
Default Re: Volvo
I believe Sweedish (pretty obvious) Serpent driver Per-Ola Hard drives with the Volvo body. Hopefully Julius can comment. I know he mentioned that he uses the Volvo wing on the Stratus 2.1 shell.
InitialD is offline
Old 04-05-2004 | 08:15 PM
  #7782
PSI Racing's Avatar
Default Re: Re: Volvo
I just checked Protoform's website, and they don't have their Volvo body anymore.
Since everyone is either running a Stratus or a Mazda 6, I want to run something different, but with similar performance.
Old 04-05-2004 | 08:20 PM
  #7783
serpent astra is very good.
Profoxcg is offline
Old 04-05-2004 | 08:21 PM
  #7784
but then again, i came from TRYING to drive a TG10R with a Lance body !
Profoxcg is offline
Old 04-05-2004 | 08:25 PM
  #7785
PSI Racing's Avatar
I like the Volvo, because it's sort of a joke with my uncle and cousins because they have this real old Volvo that just won't die.
I just want to know if the Serpent Volvo body handles the similar to a Stratus or Mazda 6 body.
