Serpent 710
Old 03-26-2004 | 09:40 PM
  #6976
Marcos.J's Avatar
Super Moderator
Default Re: Re: InitialD
Originally posted by markp27
Half the track's missing!
The infield section looks really good!!
Hmm, I think I'm going to have to add a Wife/Girlfriend section to the FAQ - tips and excuses
the track is built inside a go-kart track, the rest of the track is laid out during race day.
Marcos.J is offline
Old 03-26-2004 | 09:46 PM
  #6977
A quick question. I thought Tire Truers only trued the diameter of the wheel down like say 64mm to 62mm? They can also narrow a rim as well from 27mm wide to 26mm wide? If I buy the Hudy Tire Truer, does it come with everything I need to cut my tires and to narrow my tires as well? Now That I have my car all together I see that the front wheels come really close to the knuckle, even the wheels that come with the car are close.
SupermaxxRich is offline
Old 03-26-2004 | 09:57 PM
  #6978
clmbia45's Avatar
Lightbulb DOG BONES
OK GUYS, I NEED SOME HELP. I'M LOOKING FOR DOG BONES WHICH WILL FIT IN THE 710 BETWEEN 61 mm AND 62.5 mm LONG.
WOULD YOU CHECK YOUR CAR COLLECTIONS AND SEE IF YOU CAN COME UP WITH SOMETHING?
THANKS, JACK
clmbia45 is offline
Old 03-26-2004 | 10:01 PM
  #6979
clmbia45's Avatar
YOU CAN GET A HUDY MODEL WHICH, WITH THE PROPER ARBOR WILL ALLOW YOU TO TRUE YOUR TIRES FROM 1/12 SCALE THROUGH 1/8 SCALE. TO NARROW YOUR TIRES, TRIM THEM DOWN WITH A RASP. OR, IF YOU ARE CAREFUL, YOU CAN CUT THEM DOWN WITH A BOX CUTTER; JUST BE SURE THE TIRE IS SPINNING AWAY FROM YOU!
clmbia45 is offline
  #6980
Default Re: DOG BONES
THANKS, JACK
With Ellegy rims, you can make 197mm trackwidth pecisely using Impact FR Dogbone.
But your tire cannot go bigger than 63mm, very close to hit the axles when you press down the car.
GoldFinger is offline
Old 03-26-2004 | 10:05 PM
  #6981
Hey guys. What size allen head is used to adjust the 2 speed clutch shoes? I had to open up the three holes on the 2 speed gear quite a bit so I could adjust the two set screws to set the clutch depth to the housing. But I can't seem to get an allen key onto the the adjusting screws for the 2 speed clutch. So if I know exactly wht allen key it is then that will eliminate one error.
Old 03-26-2004 | 10:14 PM
  #6982
Without removing rear-right tires, remove 2spd clips and slide 1st spur ass'y out. Than you can see both screw and adjusting nut at your convinience.
Old 03-26-2004 | 10:21 PM
  #6983
sorry maxx, its a typo. No nut present on it.
I mean is to adjusting the screw.
Old 03-26-2004 | 10:46 PM
  #6984
Good call Goldfinger. Sounds alot easier and quicker!
Old 03-26-2004 | 11:58 PM
  #6985
Diesel Racer's Avatar
Default 710 FAQ
Just uploaded markp27's lastest revision of the 710 FAQ to my website, I've also incorporated this into the main menu on my site so it's easier to find.
http://www.markanddebbie.net
Cheers
Mark
Diesel Racer is offline
Old 03-27-2004 | 12:09 AM
  #6986
Anybody know the factory settings for the NS12 S3?? I just messed them up and I don't want to start the engine unless everything is 100%
Old 03-27-2004 | 01:00 AM
  #6987
LSN - 2¼ turns out from lightly seated
MRN - Flush, don't play with this one
HSN - 3½ turns out from lightly seated
Old 03-27-2004 | 09:15 AM
  #6988
cox049's Avatar
Default Rainy practice day
I know all you guys are practicing instead of posting crap , oops sorry I mean spreading knowledge on these pages
But guess what... its freaking rainy here!!! ...
So what I'm I doing? Assembling the kit I bought for "parts"... let me give you all some advice, .Don't buy a second kit for "parts"!! It's very difficult to resist the temptation to assembl;e it!! and than you need more engines , servos and off course more PARTS!!! lol
cox049 is offline
Old 03-27-2004 | 09:23 AM
  #6989
rodrigo1508's Avatar
Thats why I am buying my second kit for pratice not parts
rodrigo1508 is offline
Old 03-27-2004 | 09:29 AM
  #6990
Marcos.J's Avatar
Super Moderator
Default Re: Rainy practice day
why stop when ir rains just soften you suspension , take off the sway bars and used these rain tyres!!!
Marcos.J is offline
