Serpent 710
#6961
Originally posted by Proficar403
As far as I'm concerned so far, the one way in the 710 feels more like a solid axle than the solid axle does.
#6962
Originally posted by Palmaris Europe
That I would agree with because i have known nothing but one-way from my 1:8th days.
#6963
Originally posted by rodrigo1508
Can anyone please tell what effect does the front solid axle has on the handling?
On power steering should be close as good as a oneway front.
#6964
Originally posted by InitialD
Just to put things straight, the 1/8th scale has very wide rear tires on a solid rear axle which makes handling different and more stable altogether than a 1/10th scale TC. You could brake hard even on a oneway front on a 1/8th scale because of the stability.
But in saying that I never much got to show that as I never use any brakes unless it is really necessary (those times when a car appeared in the line of fire from nowhere
. Just hate when that happens
#6965
But regardless of size you should be able to brake any car hard with a 1-way and get the same reaction. It's all a matter of how much work you put into making sure the car is completely balanced from side to side as well as front to rear.
The much wider 1.8th scale rear wheels evens out all these parameters that makes uneven rear tire contact patch. Sort of like having a wide setup sweat spot on the 710...
#6966
I somewhat disagree... While you could control how the car tweaks perfectly on the board with equal diameter tires, equal shocks, equal droop and etc, you can hardly control these parameters in the corse of racing on the track. Unequal rear tire wear (left to right) and the uneven track surface conditions makes for uneven rear tire contact from left to right.
Found one of those topics we agree to disagree
#6967
Originally posted by Schrijver99
Don't think so, becausse The Border isn't a official distributor of JP.
In Holland, Modelsport Hoofddorp is the official distributor (my LHS) See also at JP internet site:JP Distributors
about the bearings yes we have them too we will up-load it.
#6970
Well, using a particular OS does not make you a techie !
I bet crashed_1 cannot read it !
#6971
Good luck, i'm also nitro/electric driver for me it's a Schumacher MI2 (Forget X-ray - when is Serpent comming with their Electro..........)
Why'd you choose a schumacher over an Xray? Just out of interest.
#6972
To InitialD
hey D where can I buy or find NovaMega Engines?
My local hobby shop doesnt carry any of those engines also i was looking for the novarossi ns12s3 but my LHS carries only TOP engines which one of those is similar to the s3
#6973
Originally posted by markp27
Actually its open to interpretation, as the significance of the 0s and 1s is mearly an interaction between the visual cortex and the brain synapses which are stimulated by photons hitting the light sensative nerve cells of the eye. Crashed_1 rather artisic interpretation (enhanced by his commendable choice of Operating System - the popular choice of all artistically gifted people) of the pattern of 1s and 0s is, of course, also valid. It is just that those less giften than he (i.e. those using "that other" OS) won't actually understand nor grasp the significance of his interpretation.
#6974
#6975
