Serpent 710
#3631
I'm having a hell of time trying to post some pictures of the mods ive done to strengthen the front and rear a bit.
Any tips on what I'm doing wrong , or is the moderator of the thread controlling the admittance of photos ????
I know I can attach a photo, but thats lame in most cases !!!
#3633
Seen to many of these break at our track so I had an
aluminum made up. Weight is not an issue with me at this point.
Utilized the aluminum front shock mounts I saved from my veteq and they work great for the porsche type bodies and i can leave the bumper in. By adding the spacers (which are the tool that came in the 705 kits for the rear upper a arm ball installation) I can use my regular stratus bodies.
#3634
Had to throw a couple garage shots up and I almost forgot that I doubled up the rear shock tower mount by gluing them together and then bolting them together with an unused shock hole.
3 of them have broken at our local track the last few weeks , and they were not that spectacular of crashes.
put on a trick little fuel tank lid thumb peice and a few other minor mods like the spring steel drive axles etc.. if anyone wants some photos let me know !!!
#3639
Originally posted by InitialD
Is that at the outdrive part where the dogbone is? Or is the wear at the side where the bearing spins?
I notice that while using hard diff setting.
And the dogbones pin is worn either.
#3640
waaaaaaaaaaahhhhrrghghghghhhhhhh
I want that garageeeeeeeee
I've been asking a lot my wife to turn the other room to be my workshop...but u know the obvious answer, right
So i just settled my thing on the corner of the room...with everything on the floor........
i mean really on the floor
#3641
#3642
I actually do not understand that part about the Veteq aluminum front shock mounts you've referred to. Did you mean the front aluminum body post?
Also, how do you mount the aluminum spacers to mount regular Stratus bodies?
#3643
Originally posted by n1technik
i've tried it. but won't work for both cars. if i get one right, the other one would be misaligned. i've tried giving one more room to play but still doesn't seem right.
well if everything fails, i can use euro's starter box for 710. :-p
