Serpent 710
Old 01-28-2004 | 12:54 AM
  #3556
InitialD's Avatar
Default Re: 5th body mount
Originally posted by sparksy
Here is how I did it D....
Finally ! A partial pic of your car !
Thanks. That's clear enough. The next shell I won't be reaming the extra 5th hole in the body.
Say have you run the car yet? I assume you have seeing that you've used red springs. What are your impressions?
InitialD is offline
Old 01-28-2004 | 12:58 AM
  #3557
sparksy's Avatar
Front view
sparksy is offline
Old 01-28-2004 | 01:00 AM
  #3558
sparksy's Avatar
Do I need to add weight FastHarry?
sparksy is offline
Old 01-28-2004 | 01:04 AM
  #3559
InitialD's Avatar
Is that weight with your modded hollow front shaft, Impact dogbones and PRO wheel axles?
InitialD is offline
Old 01-28-2004 | 01:09 AM
  #3560
sparksy's Avatar
Default Re: Re: 5th body mount
I havent had a lot of time driving it yet. We just moved house over christmas so I'm still unpacking alot of our stuff. But from the limited amount of tracktime I like the car so far. Easy to setup. Predictable.
Preliminary testing has me thinking it drives a lot like my old MTX3. Corners very flat with nice midcorner grip.. a little under steer on turn in. Is still box stock setup wise except the red springs. So I am pleased so far.
sparksy is offline
Old 01-28-2004 | 01:11 AM
  #3561
Julius's Avatar
Originally posted by clmbia45
I am talking about the vertical dimension between the radio tray and the chassis. My KO Propo PDS-2143FET measures 20.1 mm, so the 9550 is actually 0.9 mm thicker. Servo vibration via the chassis was felt by some to be the reason for servo failures in the Vetec. And all servo manufacturers I am familiar with, use anti-shock mountings to prevent this.
I read your PM about this but I'll answer here so all can benefit.
Most servos should fit without problems. Be aware the holes in the servo mount are larger than the screws so make sure the servo is as far "up" in the mount as possible. If you still have problems with it touching the chassis, take a little off the notches of the servo mount so the entire thing goes up a bit. As little as possible though!
Julius is offline
Old 01-28-2004 | 01:17 AM
  #3562
sparksy's Avatar
No... I cheated just for a joke.
Its actually 1740g ready to tech. But Ive still got fullsized servos in there and the wheel axles are still stock. I have a 9550 on order for throttle, so that will bring the weight down. As will the Ti screws and spring steel wheel axles.
I guess I best order some weights for when its all on the car.
sparksy is offline
Old 01-28-2004 | 01:20 AM
  #3563
sparksy's Avatar
Julius,
is it also possable for you to answer the question on the sloaping radio tray?
I dont recall seeing an answer in relation to it.
sparksy is offline
Old 01-28-2004 | 02:09 AM
  #3564
Julius's Avatar
Julius,
The slope is due to the middle bracket shrinking slightly more than anticipated. It is about 0.9mm too low. That means about 0.5 degrees of slope in the radio tray. That is not an issue except for the cosmetics. Most likely we will make a small change in the mould so the top part will be 0.9mm higher. There is no need to shim the tray. Most likely you will no longer have the benefit of the centering function of the nylon protrusions. That will lead to a decrease in stiffness an may cause tweak in the chassis during racing.
In short: "It looks a little funny but that's it"
Julius is offline
Old 01-28-2004 | 02:18 AM
  #3565
InitialD's Avatar
Let me understand this better... If we shim the tray, then there would not be any centering function benefit from the nylon protrusions?
Or do you mean when Serpent remedies the mold to make the middle bracket 0.9 mm higher, we would not get the centering function benefit of the nylon protrusions?
InitialD is offline
Old 01-28-2004 | 02:21 AM
  #3566
sparksy's Avatar
Thanks Julius.
sparksy is offline
Old 01-28-2004 | 02:28 AM
  #3567
jfc_tech's Avatar
Im still confused
jfc_tech is offline
Old 01-28-2004 | 02:40 AM
  #3568
Pyramid's Avatar
Registered User
Pyramid is offline
Old 01-28-2004 | 02:45 AM
  #3569
Pyramid's Avatar
Registered User
I think (car not with me now) the protrusions are 2mm (as thick as the upper deck). I shims mine at 1mm so it leaves me enough protrusions to hold the upper deck.. yes, wont be as much as without shims.
I imagine the mod is sliding tipe which should be possible to add 0.9mm thickness and still having the protrusions
Hi Julius, I always meant to ask, what specific plastic material that serpent uses for making those parts such as arms, bulkhead, etc?
Pyramid is offline
Old 01-28-2004 | 02:56 AM
  #3570
jfc_tech's Avatar
which one is this...radio tray? slopping? protrusion? pictures please...
jfc_tech is offline
