Serpent 710
Old 11-17-2004 | 12:24 AM
  #18586
Julius's Avatar
Originally posted by rcpanama
More steering (turn the sweeper at higher speed)
If high speed steering is the only thing you'd like to have more of, you could also experiment with the rear wing position a bit.
Which body are you using?
Julius is offline
Old 11-17-2004 | 02:05 AM
  #18587
InitialD's Avatar
Correct me if I'm wrong Julius but smaller rear wing gives better steering at high speed, right?
What about the additional dampers go in the middle of the rear wing like on the Mazda 6 and the Alfa 2.1 and the ones that go at the side like the older Stratus 1.0 and 2.1? How does it affect handling? When do you use them?
InitialD is offline
Old 11-17-2004 | 02:19 AM
  #18588
Julius's Avatar
Smaller wing = less grip = more steering and more speed on the straight.
The additional flaps on the wings help straight line stability. They also help keep the rear in line a bit in corners. I personally don't use the fins on the wing but experiment with them to see if you notice a difference.
Julius is offline
Old 11-17-2004 | 02:29 AM
  #18589
rice's Avatar
me i prefer medium wing. ive tried smaller wing my run is inconsistent.
rice is offline
Old 11-17-2004 | 02:51 AM
  #18590
Julius's Avatar
It all depends on the combination of car setup body type wing size track layout etc.
Many of us sometimes forget that aerodynamics play a big part in car handling.
Julius is offline
Old 11-17-2004 | 02:59 AM
  #18591
Sow&Steady's Avatar
Julius, have you experimented with the small holes that you can cut out of some wings? I'm told these are for high-speed also ...
Sow&Steady is offline
Old 11-17-2004 | 03:25 AM
  #18592
rcpanama's Avatar
Thanks for the help I am using the Alfa 2.1
rcpanama is offline
Old 11-17-2004 | 04:34 AM
  #18593
Hi im from Aussie here we race on very grippy tracks and i always have a problem of traction rolling with the 710 has any1 got any suggestions plz it would be a big help.
Dark_Horse_Yeah is offline
Old 11-17-2004 | 04:48 AM
  #18594
ammdrew's Avatar
Company Representative
cut your tires to about 51 or 52mm to start, and then lower the chassis to 4mm of ride ht, that will help a lot. other wise stiffer car harder tire.
ammdrew is offline
Old 11-17-2004 | 05:19 AM
  #18595
Julius's Avatar
That depends on where on the track the car is traction rolling. Into corners, out of corners in the middle etc.
Your setup would help as well
Julius is offline
Old 11-17-2004 | 07:49 AM
  #18596
spawn's Avatar
damn my 2 speed housing just broke into 2 pieces. Is this because its worn out? or I am shifting too hard?
spawn is offline
Old 11-17-2004 | 08:03 AM
  #18597
crashed_1's Avatar
crashed_1 is offline
Old 11-17-2004 | 12:51 PM
  #18598
Sow&Steady's Avatar
Split into two how? Pictures?
Its probably wear and tear ... confirm by looking at the pieces ...
Old 11-17-2004 | 06:14 PM
  #18599
InitialD's Avatar
I don't think the 2 speed housing broke because of shifting too hard. Else, you'll have the fastest engine on the track. Never happened to me. Just the 2 speed housing wears out over usage. Perhaps some debris caught on and somehow ripped the aluminum housing apart? Or the 2 speed screw is too much out that it "catches" on the holes of the 2 speed housing and ripped it. That's the only thing I can think off...
Other than that, the only other thing that comes into my mind is to claim warranty from Uncle Crash.
InitialD is offline
Old 11-17-2004 | 06:18 PM
  #18600
InitialD's Avatar
You meant 61 to 62 mm tires... 51 or 52 mm foams and you'll be running on plastic rims.
p/s: How's life on the fast lane?
InitialD is offline
