Old 11-15-2004, 08:19 PM   #18571
Default Re: Re: The only serpent racer!
Originally posted by JustRace
Brett...what's the purpose of the filter on your pressure line?
Its not a filter its a pressure chamber and it seems to make my JP run alot better
Brett.w is offline   Reply With Quote
Old 11-15-2004, 08:26 PM   #18572
crashed_1's Avatar
Default Re: Re: Re: The only serpent racer!
Looked to me like a Massimo Fantini Max there...
crashed_1 is offline   Reply With Quote
Old 11-15-2004, 08:32 PM   #18573
Default Re: Re: Re: Re: The only serpent racer!
Very good vision It was because the weather was very strange it was very cold one moment and then very hot at another and i just couldnt get my jp tuned properly but my max seemed fine all day so i stuck with what worked best!
Old 11-16-2004, 01:17 AM   #18574
InitialD's Avatar
Well, sometimes it reduces and eases the pressure pulses from the pipe. Gives a more consistant tuning.
Old 11-16-2004, 01:25 AM   #18575
InitialD's Avatar
Default Re: Re: Re: Re: Re: The only serpent racer!
Don't mind crashed_1. He's trying to tell us he has both engines.
Old 11-16-2004, 01:27 AM   #18576
InitialD's Avatar
For the moment, I thought you disagreed he looked like Mark Green and looked more like Massimo Fantini.
Old 11-16-2004, 01:28 AM   #18577
InitialD's Avatar
Default Re: Re: Re: REX RER12S3
Initial....what's wrong with microcast piston? I thought it was suppose to good.
A lot of people have premature failures with the microcast piston. The piston sleeve wears very fast.
Old 11-16-2004, 01:52 AM   #18578
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: Re: The only serpent racer!
Don't we know it isn't it?!
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 11-16-2004, 01:53 AM   #18579
Sow&Steady's Avatar
Wait a minute ... a mutual friend of ours looks like Massimo Fantini.
Old 11-16-2004, 05:52 AM   #18580
crashed_1's Avatar
Had both engines...ones about to be taken away and put to good use on another 710... Oh well, it has served me well.
Old 11-16-2004, 08:01 AM   #18581
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Re: The only serpent racer!
When will your JP FX engine find home in another 710 <hint, hint>?
Old 11-16-2004, 11:38 AM   #18582
rcpanama's Avatar
Smile
Hi D, I had my last race of 2004 on Sunday, my 710 perform excellent I was winning the race until I was hit by one of the racers coming into the straight line making me lose the first place finishing second for few seconds.
I Change from
UTO / LT to UTO / LB
Front Roll Center 0 under
DRS LEVEL
Tighten from Diff and loosen Rear Diff
Increase Toe in from 2 to 3
Anti Roll Bar Front 45
Anti Roll Bar Rear 2.5mm flat
New longer Servo Saver
These changes made the behavior of the car improve in a very low traction fast track.
Now my question is, if I make the Wishbone front 1mm modification will this improve my --ON THROTLLE CORNER ENTRY & EXIT?
rcpanama is offline   Reply With Quote
Old 11-16-2004, 11:59 AM   #18583
Julius's Avatar
What exactly would you say is an improvement in these areas? More steering less steering, more traction?
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 11-16-2004, 12:00 PM   #18584
rcpanama's Avatar
Smile
More steering (turn the sweeper at higher speed)
Old 11-16-2004, 08:38 PM   #18585
InitialD's Avatar
rcpanama, I noticed that the new servo saver really brings the car up to speed in the high speed sweepers so long as you do not lock the steering. Just turn a little to steer the car and the car will cut the sweepers like a hot knife to butter. Not full locking. I found harder rear springs than front really keep the car tracking straight on throttle and point it where you want.
Another thing you could try is to set the 2.5 mm rear sway bar slightly harder. You may want to try less rear toe in. With +3, you loose on power steering. I think the team guys always try as little rear toe in as possible so that you get as much on power and straight line speed as possible.
