Serpent 710
Originally posted by Sow&Steady
Yeah, and you could say the same about Master Glenn who is probably 6ft deep in snow!
Where are you Glenn?!
Jeez! Do you ever work?
Telling D that is like telling NiMo to change over to the 710!
Originally posted by markp27
AND then, there's Dr Koo to deal with
Ooops, musn't forget him!
Maybe we should let him try it during our christmas testing session
Not sure if that'll work because the OSX requires too much common sense to operate!
Now I've heard about thinking laterally, but Sow has just taken it to a completely new level!
I still have the RING from last weekend remember?
Gettin Jiggy with Rear Anti Roll Bar
ttt..........
How do you set up yours ? Step by step please.
Re: Gettin Jiggy with Rear Anti Roll Bar
Originally posted by redsand
ttt..........
ttt..........
With the older one, take car not to tighten the CF plate too tighly as this could bind the 2 mm sway bar. I only tighten the 2 screws going into the bulkheads but the 2 screws that clips and holds the sway bar is tighten just loosely to hold the sway bar in position.
For the new sway bar, I'm currently using the 2.5 mm with the plastic holders meant for the 3 mm. That should ensure that the sway bar movement is free.
With the new sway bar, you cannot set it to 0 mm as the ball linkage will rub on the upper rear arm. Something like 2 or 3 mm from the edge will clear the arms.
As for tweak, I believe the it is described in the FAQ...
Serpent Nitro Tour 2005
Is there anybody from here join that race?
Re: Serpent Nitro Tour 2005
Re: Re: Serpent Nitro Tour 2005
Originally posted by Brett.w
When is it?
When is it?
http://www.mytsn.com/publ/publ.asp?pid=10788
Hey Brett, planning to come along?
Re: Re: Re: Serpent Nitro Tour 2005
Originally posted by InitialD
15th and 16th of January 2005.
