Serpent 710
Old 10-11-2004 | 08:16 AM
  #17311
Julius's Avatar
Default Re: Re: Diff
Originally posted by pelos
Did you already try longer pins? How did you manage to mount them on 10x15 steering block bearings?
You can only use longer pins on the inside. Even when running a one way front I don't reccomend using longer pins.
Julius is offline
Old 10-11-2004 | 08:17 AM
  #17312
Sow&Steady's Avatar
Default Re: Re: Re: Re: New Pipes !
Originally posted by Picard
Sow I get 6 mins with the max pipe
6 should be good enough.
Sow&Steady is offline
Old 10-11-2004 | 10:27 AM
  #17313
Default Re: Re: Re: Re: Re: New Pipes !
Hi,
I run 6,5 min with the Max engine and pipe.
For modified engines runtime between 5 and 6,5 mins is normal.
When it´s over tuned you won´t make 5 min on one tank. When the engine isn´t modified you mostly have runtime between 6 and 8 mins.
When you modify the engine yourself try to make the engine capable of driving between 5,5 and 6,5 mins, unless you modify it for a special track.
During the last two races of the Dutch national championship there were Serpent team drivers using the new Mega's.
It had enough power and runtime was impressive, 7,5 min!
They ran it right out of the box.
When they modify this engine you will have an atomic bomb. It´s a bomb allready
Bye Thomas
840918001 is offline
Old 10-11-2004 | 10:32 AM
  #17314
Suspended
Default NEW PRODUCTS
SERPENT USA IS THE CARRIER OF 3RACINGS PRODUCTS AND PMB PRODUCTS.......CHOCO
SERPENTFREAK69 is offline
Old 10-11-2004 | 07:27 PM
  #17315
InitialD's Avatar
Default Michael Salven's Car in Brazil !
Did anybody notice the new orange part on the front of his car? I guess it's to make the car heavier.
InitialD is offline
Old 10-11-2004 | 07:36 PM
  #17316
Picard's Avatar
Default Re: Michael Salven's Car in Brazil !
WOW...
How good does that car look
I have not seen those oarts as yet?
Julius are they going to be released as an optional part?
Picard is offline
Old 10-11-2004 | 07:39 PM
  #17317
Picard's Avatar
Exactly...I just read it on mytsn and I have got my hands on some today to use on the weekend.
I am only using the longer pins for the rear, on the diff outdrive sides (left and Right). Will let you know how it goes for wear
Picard is offline
Old 10-11-2004 | 09:23 PM
  #17318
redsand's Avatar
I think the orange part is a reactive caster adjustment. So the hinge pin can be positioned flat (normal), tilted forward (less caster when turning) and tilted backward. (correct me if im wrong).
redsand is offline
Old 10-11-2004 | 09:27 PM
  #17319
InitialD's Avatar
Reactive caster? Hope Julius can enlighten us more on this if it's true indeed.
But looking at the caster setup, he has used very little with the smallest shim (1 mm) in the front of the upper front arm. Obviously to get more turn in.
InitialD is offline
Old 10-11-2004 | 09:36 PM
  #17320
redsand's Avatar
that might not be a reactive caster adjustment. i've looked more closely and there isnt any adjustment hole visible.
the hinge pin does look tilted forward though.
btw, i'm sure it isnt some eye candy option part. there must be a good reason for using that stuff.
redsand is offline
Old 10-11-2004 | 10:29 PM
  #17321
Helloooooooo
Hehehehe........probably
Also whats with the rear body post??
PUNISHER is offline
Old 10-11-2004 | 10:39 PM
  #17322
markp27's Avatar
Default Re: Re: Michael Salven's Car in Brazil !
Originally posted by PUNISHER
Helloooooooo
I think Julius said it was to help support the rear body during refuling.
markp27 is offline
Old 10-11-2004 | 10:57 PM
  #17323
InitialD's Avatar
Hey Punisher, what's cooking? Where have you been missing?
Yeah, Mark is correct about the rear additional post. The way they refuel is to grab the cable tie from behind the car through the rear opening of the rear windscreen of the bodyshell with one hand while the other hand refuels with a fuel bottle or fuel gun.
When you grab the car with one hand by picking up the cable tie that connects to the fuel cap, the bottom part of the arm will bend the rear part of the bodyshell. The additional rear post helps the rear part of the bodyshell remain in shape. I think it will also be helpful if you ever get accidently rear ended by somebody else. Prevents the bodyshell from getting stuck under the wheels.
InitialD is offline
Old 10-11-2004 | 10:59 PM
  #17324
InitialD's Avatar
Weight addition is a good enough reason I think... (j/k)
InitialD is offline
Old 10-11-2004 | 11:06 PM
  #17325
Default Re: Re: Re: Michael Salven's Car in Brazil !
Hey D,
Been around just been quite and busy until now.
Also enjoying my new r/c car...HPI Pro4.
Aahh...I.C
I thought it would be for more weight.
Also just notice the front ball diff.......cool.
PUNISHER is offline
