Serpent 710
Originally posted by InitialD
Congrats to the team rcpanama.
I think that the UTI / LT combo in the rear makes the rear RC a little higher than stock UBI / LB. Perhaps with a front diff it is a better combo since the slightly higher rear RC will make the rear of the car rotate better.
If I understood correctly this is what we should use and that the UBI / LB should be without the front Diff ???????
Originally posted by Taylor-Racing
Your not counting the new SpeedMinds you comandeered from my box, then?.
They dont count as they have been scrubbed in. I only count "new" tires in the box..
Originally posted by Finken
I am wondering about buying some ceramic bearings from Acer, for my 710. My question is, are bearings like that, maintaining free?? Need for lube or cleaning. Sometimes we race in rain.
Rain will affect ceramic bearings less than normal steel ball bearings.
Hello.
Finally i received all the parts and my car is back on track
www.eskadra.com/serpent.avi
Take it easy on me, its my 3rd time driving rc car
Max
Max
Hi again
Whats your opinion on diff vs oneway, on a small tecnical track. Will a diff give me less turn in or less steering out of a turn vs oneway.
Hi again
Use a diff for a tight, small technical track. You can still find the best diff setting for the cornering.
Originally posted by rcpanama
Thanks D, can you please explain what you do mean in regards to the UTI / LT combo the two of us are using the front Diff.
So making the rear RC slightly higher, you prevent the rear of the car from rolling and thus will make the car easier to rotate around the corners. This is good when you have a front diff.
For example if your car is already twitchy and with a lot of steering and you find that the rear of the car always stepping out, you could put a lower RC in the rear to stabilise and get back some of the mechanical grip. That is why the page 17 of the Setup booklet is very PRECIOUS information.
When you turn in off power, corner speed is scrubbed away because of the diff action.
When you turn out on power, the power to the inner wheel is bleed off due to the diff action.
But if traction at your track is low and your track layout requires a lot of hard braking, you may be better off with a front diff like what Onkel Sow mentioned.
