Serpent 710
Old 09-16-2004 | 11:24 AM
  #15691
packetdreamer's Avatar
oh. and do you know if you can play it online?
packetdreamer is offline
Old 09-16-2004 | 02:21 PM
  #15692
Sow&Steady's Avatar
Not the version they showed but I'd imagine that this is a future potential for development. Just doesn't make sense these days to NOT do it.
As for your previous question, yes .. the Sim is designed for an RC racer so being able to change settings is key ... you can "feel" the different effects of setting changes.
Sow&Steady is offline
  #15693
Sow&Steady's Avatar
Old 09-16-2004 | 03:07 PM
  #15694
Have any of you tried the new servo saver, they say its giving better cornering speed, beacouse of less "ackerman"
and the new diff clamp?
Finken is offline
Old 09-16-2004 | 03:40 PM
  #15695
good, because thats the most fun for me.
Old 09-16-2004 | 07:57 PM
  #15696
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Re: New Rims
Originally posted by markp27
Supposed to be a real good racer and one hell of a guy
Thank you.
InitialD is offline
Old 09-16-2004 | 09:34 PM
  #15697
nitro rookie's Avatar
Can I get some more imput?
I am planning on going to my first big race in 3 weeks. The track is 1 1/2 times longer than the one I'm used to running. My straight is roughly 130 feet where this one is 250 plus, with more sweeping and flowing turns. What should I look to run for gearing. I run a NS12s3. Any set up imput would be great. This track is the same one the Gas nat's were at.
Thanks,
nitro rookie is offline
Old 09-16-2004 | 11:09 PM
  #15698
markp27's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: New Rims
Originally posted by InitialD
Thank you.
And is very, very old...ist what I forgot to mention
markp27 is offline
Old 09-17-2004 | 12:02 AM
  #15699
Sow&Steady's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: New Rims
Yeap, that must be D.
Old 09-17-2004 | 12:14 AM
  #15700
Sow&Steady's Avatar
Thanks,
It is not just the length of the straights that counts but also the layout.
Put it this way, if a track has an average lap time of say 25 secs (which is pretty big), you will probably find that the straight might only take 3 or 4 secs, 5 max. This means the rest of the time it is the technical part of the track that takes time.
If there are more sweeping and flowing turns, use the one-way (unlocked). Adjust your brake settings so as NOT to lock your rear wheels at the most important braking point on that particular track.
Tighten your rear diff, even better ... use a solid rear if you can get hold of one (provided the track is not bumpy).
If there is enough grip, use as high a shore as possible.
Adjust your steering for best cornering only for this track. Take out excessive steering sesnsitivity so that you're not snaking around all over. I normally adjust the exponential rather than reduce my EPA.
As for gearing, try the stock ones first but have the 18-23 pinions and 59-55 spurs ready.
Finally ... practise, practise, practise.
Old 09-17-2004 | 12:15 AM
  #15701
Sow&Steady's Avatar
Not yet but they're on their way.
Old 09-17-2004 | 12:20 AM
  #15702
markp27's Avatar
Right, that's it - RING Time!
markp27 is offline
Old 09-17-2004 | 12:24 AM
  #15703
Sow&Steady's Avatar
Ooops! That's the doorbell. Too late Mark, the bits are here!
Old 09-17-2004 | 12:26 AM
  #15704
Sow&Steady's Avatar
  #15705
markp27's Avatar
Nevermind - my Losi shell will make up the difference
markp27 is offline
