Serpent 710
Old 09-17-2004 | 07:20 AM
  #15721
packetdreamer's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: in case you didnt see it...
Originally posted by markp27
No more glass cars
no more dead glow starter batteries.
packetdreamer is offline
Old 09-17-2004 | 07:24 AM
  #15722
markp27's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: in case you didnt see it...
No more finding out you've forgotten that piece of important equipment when you get to the track!
markp27 is offline
Old 09-17-2004 | 07:29 AM
  #15723
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: in case you didnt see it...
AMEN to that!
no more $23+ for fuel
Old 09-17-2004 | 08:54 AM
  #15724
cyba888's Avatar
Would like to know how some of you guys drive your 710. I have my steering ATV set so that that my wheels have maximum turn. For the steering EXP mine is set at 0% which is quite sensitive for my taste, but I think I will decrease the senstivity so it drives easier next time im at the track.
cyba888 is offline
Old 09-17-2004 | 09:02 AM
  #15725
InitialD's Avatar
How are you suppose to cure those who cannot live without smelling nitro? I suppose they will include a nitro scent together with the software package for those die hards.
BTW, what OS does the game run on? Solaris?
InitialD is offline
Old 09-17-2004 | 09:05 AM
  #15726
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: in case you didnt see it...
i wish it did run on solaris
Old 09-17-2004 | 09:08 AM
  #15727
InitialD's Avatar
Where have you been hiding?
I believe the right way would be not to set it to full lock ! That's how the team drivers do it anyway according to Julius. On large tracks, full locking the steering throw to the maximum the wheels can turn only scrubs speed away not to mention higher chances of dogbones popping out and receiver pack dumping faster if you're not careful with the EPA. If you're not getting enough steering, it must be the setup. On smaller tight tracks, that would be different since you got to slow down on tight hairpin turns anyways.
As for steering EXP, I have mine set to 0 also. But I don't find it too sensitive. I know that a lot of people use negative EXP on the controllers to "slow" down the servos. There are lots of school of thought on this but it boils down to driving preferance and car setup at the end of the day.
InitialD is offline
Old 09-17-2004 | 09:09 AM
  #15728
i run mine with max ATV as well because i need all i can get. i did have to lower my d/r because and max turn the bones can bind (has anyone else had this problem?*). my exp is 0% and i like it that way really. i still some features i want to play with (abs, throttle curve, etc, etc, etc, etc, etc - as these radios go), but overall i run a pretty basic setup for now.
i will be experimenting later today.
pd
* i just put small secions of fuel tube in the out put shafts... maybe 3mm, could this be the cause of my binding?
Old 09-17-2004 | 09:59 AM
  #15729
cyba888's Avatar
MY hand is too twitchy so I need to adjust the sensitivity. I dont have problems with my steering not getting enough turn in but maybe I might drive smoother with some negative EXP and lower ATV. I been busy with my new toy so dont have much time lately, also too hot at the moment and night time racing is not my cup of tea. The mosquitos dont help either at night
cyba888 is offline
Old 09-17-2004 | 10:49 AM
  #15730
InitialD's Avatar
3 mm on each side can be too much ! That would cause the front suspension to bind even at max 200 mm front trackwidth.
I use about 1 to 1.5 mm on each side and set the front trackwidth to 200 mm. Currently on a oneway front. Perhaps 3 mm of fuel tubing on each side could be right for a front diff set up to 200 mm front trackwidth.
InitialD is offline
Old 09-17-2004 | 10:56 AM
  #15731
i only have 3mm on one side (in the oneway outdrives). should i splet it for both saide? or move them to the axles? (man i just set eerything up all perfect, now i have to go throught it all again.
Old 09-17-2004 | 11:07 AM
  #15732
InitialD's Avatar
What I meant on each side is on left and right output drives on the steering knuckles only. No need to put any fuel tubing on the oneway outdrives.
3 mm on one side is still too much I think.
InitialD is offline
Old 09-17-2004 | 11:09 AM
  #15733
welp, at least i know what to do THANKS!
Old 09-17-2004 | 11:12 AM
  #15734
markp27's Avatar
There can only be one
markp27 is offline
Old 09-17-2004 | 01:00 PM
  #15735
jag's Avatar
jag
Default Gearing
I just finished my 710 and was wondering about gear ratios. I will be racing on tracks that are 130'x60' and 140'x70'. Will the stock gearing be appropriate for tracks this size?
jag is offline
