Old 09-03-2004, 02:50 AM   #14971
Default Re: Re: JP in 710
Originally posted by InitialD
What pipe are you using? Has the engine been broken in fully?
can it take much longer than 15 tanks to fully run in a motor?
Brett.w is offline   Reply With Quote
Old 09-03-2004, 02:51 AM   #14972
InitialD's Avatar
Default Re: Re: Re: JP in 710
Originally posted by Voodo_Magic
RD turbo 3 with 2 inserts
Is that the one with adjustable length? Take off the inserts and make the pipe combo shorter for better high RPMs. What plug are you using? How is your mileage?
Else, if it is no go, I guess it's the pipe. Novarossi and Novamega inline pipes as do RD Logic 2 pipes perform flawless.
Last resort I would do is to add 0.1 mm shim on top of the existing stock silver shim (0.3 mm) to get it to 0.4 mm total.
Old 09-03-2004, 02:55 AM   #14973
InitialD's Avatar
Perhaps... If you take off the engine button head, can you turn the flywheel fully without the piston getting stuck halfway? If yes, then it's still not broken in fully. The piston should reach to the top (TDC) and only then get stuck. The inner sides on the piston liner should be shining and polished where the piston moves up and down leaving a band of unpolished line on the furtherst top part all the way around.
Old 09-03-2004, 02:57 AM   #14974
markp27's Avatar
Send a message via ICQ to markp27
Mine started running well after about 7 tanks, I think. Check the temp - I was running mine in at about 90 Deg C at first - make sure you are up around this temp.
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 09-03-2004, 02:57 AM   #14975
Default Re: Re: Re: Re: JP in 710
Thanks for the advise
I will take out the inserts, and iam using Novarossi C6TF glow plugs which are average filament short body.
Just for notes we use 16% nitro with synthetic fuel
however i ran 1 litre of 5% nitro with castor (as per novarossi booklet) to run in could this be my problem?
Old 09-03-2004, 02:58 AM   #14976
markp27's Avatar
Default Re: Re: Re: New Anti roll bar
Good old RC mushroom
http://rc-mushroom.com/product_info....oducts_id=3738
How strong is the Alu holder? Just wondering if it is soft like the 3 Racing parts.
Old 09-03-2004, 02:59 AM   #14977
Cheers, Mark.
Mark were are you taking your temps from (e.g. top of the cylinder head or body etc)?
Old 09-03-2004, 03:02 AM   #14978
Default Re: Re: Re: Re: New Anti roll bar
It is very thick so i presume it will hold out, however dont hold your breath after the alu diff pully i got from them that didnt last 1 run!
Old 09-03-2004, 03:02 AM   #14979
markp27's Avatar
Default Re: Re: Re: Re: Re: JP in 710
I took the temp with an infra-red temp gun through the hole in the body shell for the glow plug starter, i.e. from the cylinder head. This is kind of the defacto point for taking temps.
Old 09-03-2004, 03:04 AM   #14980
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: JP in 710
Yes, that should be the right place to take engine temps.
Old 09-03-2004, 03:04 AM   #14981
I last took it from the top of the cylinder head with an infered and it was running around 95
Old 09-03-2004, 03:07 AM   #14982
InitialD's Avatar
I run in mine with 10% nitro and we use 25% for normal play. That's against common practice of running in using the same fuel as you would use to race it. I did that because the 10% nitro was cheaper.
Anyway, I run in my engines using WOT method. About 15 to 20 tanks or so. I don't have a JP but I would assume their sleeve tightness are about the same as Novarossi's.
Old 09-03-2004, 03:08 AM   #14983
markp27's Avatar
Default Re: Re: Re: Re: Re: Re: Re: JP in 710
Try this Josh's Engine tuning
Old 09-03-2004, 03:08 AM   #14984
InitialD's Avatar
Taking from the heatsink head and from the plug itself can be different.
Old 09-03-2004, 03:09 AM   #14985
I will keep running it and hope fully it will get better Just one other thing what would adding another shim to make 0.4 do?
