Like Tree18Likes
Xray NT1
Old 04-02-2013 | 10:55 PM
  #6661
MrHistory's Avatar
i got these to run this year. people are saying they're awesome.
KO Propo "RSx-one10" Low Profile Servo (Li-Poly Compatible)
[KOP30104]
http://www.amainhobbies.com/product_...oly-Compatible
MrHistory is offline
Old 04-03-2013 | 12:35 AM
  #6662
djiewie's Avatar
Originally Posted by Bundy_Bear
Tamak:
Lately the talk has been that a LP Savox servo can't with stand the real life conditions and loads placed on it as a steering servo. I am unsure about it all, but I am playing it safe with just running a low profile servo for throttle allowing me to lower it.
Bundy, (Andrew?)
Well, i have the 1251mg on both. It is good for steering.
I hold the wheel with my hand and turn the steering on the transmitter, and the weakest part is the servosaver spring. The servo turns EVERYTHING, it has 9kg of torque.
Try it yourzelf and see it. If people talk of losing steering because of the savox it must be some other thing wrong.
djiewie is offline
Old 04-06-2013 | 12:34 PM
  #6663
How is the NT1 2013 regarding the 1650g weight limit?
Sti2 is offline
Old 04-07-2013 | 10:23 PM
  #6664
valk's Avatar
soooo bad luck lol. got my car all back together and wanted to start it up yesterday. plug was ok when i checked it a few days ago but it just wouldnt fire this time.. changed the plug fired up pretty quick, but after letting it warm up for a minute, gave it a few little blips to keep it running and TINK.
conrod gone =(
took out the piston and head button. though, the sleeve is still good.. and glowplug is still good... lol?
they dont sell sleeves by themeselves for my motor so getting a new sleeve anyway. was a big debate.... get a $140 RBtuning engine or spend the same $140 on the parts i need for my 12TZ. dont think i can do any better for power for the money than just rebuilding it..
not sure why it decided to pop. started right up and blipped as it should. just. bam...
I didnt change the conrod after breakin, might be it? ran the whole season just fine.
i guess this time, ill buy an extra conrod and change it after the breakin process.
anyone running osengines; could i drop the TZspeed sleeve/piston into a tz-t3 crankcase? its only $20 more for the speed spec2 but not sure if the crankcase is different enough that it wouldnt fit.
valk is offline
Old 04-07-2013 | 10:45 PM
  #6665
Bundy_Bear's Avatar
Originally Posted by djiewie
Bundy, (Andrew?)
On a side note anyone heard when the 2013 is being released?
Bundy_Bear is offline
Old 04-07-2013 | 10:52 PM
  #6666
Car will be in Aus in about 2weeks
mrgsr is offline
Old 04-08-2013 | 01:53 AM
  #6667
Bundy_Bear's Avatar
Thanks John
Old 04-08-2013 | 05:09 AM
  #6668
conrod gone =(
I would just get a new engine. Usually when the conrod goes, the crankcase will be damaged. Rebuilt engines never give the same performance of new ones in my experience.
Serpenteer is offline
Old 04-08-2013 | 10:56 AM
  #6669
valk's Avatar
Doesnt look like there was any damage to the crank case.
Wiped it out with cleaner and aside from some Minor scratches it looks useable.
Ill
Give the bearings a good
Shot with cleaner and she should run just fine with new parts. A shame the headbutton died but thats one of the cheaper parts fortunately.
valk is offline
Old 04-08-2013 | 12:02 PM
  #6670
GREGORY!'s Avatar
How much fuel that engine has?have you ever change the bearings?
GREGORY! is offline
Old 04-08-2013 | 01:30 PM
  #6671
valk's Avatar
That engine was broken in and run for half a season. Maybe a gallon? Got a shot
Of afterrun and sat until Last week. I still noob. Im sure there is other crap i should be doing. Which ill read more about on its replacement. A new engine after some consideration.
valk is offline
Old 04-08-2013 | 08:25 PM
  #6672
I would agree just get a new motor. No harm or foul.
Strykar is offline
Old 04-08-2013 | 10:14 PM
  #6673
valk's Avatar
Gonna get an os spec3, but having a bit of trouble getting info on pipes. was gonna get the t-1060 but there is the 1070 out now. i can get the 1060 for $115, and 1070 for $170 lol... bit of a difference. they say the 1070 is made for the spec 3 but would the 1060 work well too?
i guess its only $50....
valk is offline
Old 04-09-2013 | 05:39 AM
  #6674
GREGORY!'s Avatar
The cost of OS pipes turn me away of OS engines. Why you don't take a Novarossi ?
GREGORY! is offline
Old 04-09-2013 | 06:14 AM
  #6675
TAMAK's Avatar
conrod gone =(
I run OS engines on my Nitro Stadium and my NT1. I have a Spec 2 and noticed two VERY important things with that OS. The bearings are not the best, for any OS really. Break in with a new engine is rough on the conrod, you must replace a conrod after break in, and measure crank pin play after that. Looking at the inside of your engine, it looks like you did not clean it before you ran it. The TZ is old, it would cost a small fortune to revive an old engine. I see you want a Spec 3, I will also be getting that engine once its in stock at tower. And I also heard the new pipe is the bomb!
TAMAK is offline
