Like Tree7Likes
Old 05-23-2013, 12:29 AM   #6811
Jazza's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Team_Krusty View Post
The higher the voltage the better the performance from the servos (assuming they can handle it). I run the RSX One10 servos and they are faster and have more torque when running off 7.4v rather than 6.6v:
Torque @6V: 138oz-in, 10.0Kg-cm
Torque @7.4V: 165.6oz-in, 12.0Kg-cm
I also found I had more choice for battery size in the Lipo range so getting a battery that was a good fit for the nitro car was a bit easier.
Regards,
Simon
Guy's he has a great fitting battery.....we just need to get him to drive & race the car more. How we do that I haven't worked out yet
Capricorn Lab Co3....Black Edition Co2
Kickass Racing OS Racing Engines RB TXR Engines
Capricorn Racing Tyres....Highest Servo's....VP Racing Fuels
Supporter of Capricorn Australia....Walters Hobbies....JPM Racing
Jazza is offline   Reply With Quote
Old 05-23-2013, 09:32 AM   #6812
roger999's Avatar
Default HD flyweight istead of normal...?
Any chances to use Clutch Flyweight - High Dynamic instead of normal one in XCA clutch? just checked and my original is damaged and have only HD... Will it cause any damage to the clutch if i try? I know HD is bit smaller and thicker than normal black shoe.
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 05-23-2013, 09:59 AM   #6813
azeroth's Avatar
Trader Rating: 20 (100%+)
on a fast open high bite track the hd is great but on tight technical or slick tracks it can be a bit aggressive from my experience with it IMO
Nitro is for Racing!!!!!!!!!!!!!!!!!!!!!!!!!
YA SMELL WATTs I BE STEPPIN IN????
Yes I race a Snake, VP, Radiopost,Protek,EDS,Matrix
Team Nitro RC Club Lynwood, IL
azeroth is offline   Reply With Quote
Old 05-23-2013, 10:18 AM   #6814
roger999's Avatar
no, you didnt get the point... i have damaged standard black shoe and want to use instead of standard HD weights for XCA clutch....
Old 05-23-2013, 10:25 AM   #6815
TAMAK's Avatar
Trader Rating: 28 (100%+)
I used both standard and HD flyweights in my HD clutch / standard clutch... HD shoes have the extra hole, which makes the clutch less consistant by itself. Most pros are installing M3 x 4mm set screws in the flyweight to make them more consistant.
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 05-23-2013, 10:41 AM   #6816
roger999's Avatar
Thanks a million for that!
Old 05-24-2013, 10:09 PM   #6817
Team STPN's Avatar
Originally Posted by Team STPN View Post
so does anyone know the conversion of the shock spring ratings from the 2013 C vs 2012 D vs lbs.. very confusing!
Anyone???
C vs. D vs. Lbs.???
Team STPN is offline   Reply With Quote
Old 05-27-2013, 12:24 PM   #6818
djiewie's Avatar
i`v recently broken 2 lightweight axle`s on exact the right spot. Just between the bearing and the brakedisc holder. It happened both in finals after about 10 minutes running. The axle`s being quite new. Has anyone had this also and whats the cure? Is it just quality control or too soft material.?
i am using the standard solid axle now, just to be safe. any advise what to do is welcome since this is new to me.
djiewie is offline   Reply With Quote
Old 05-27-2013, 01:33 PM   #6819
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
Unfortunately that's the trade off for lightweight! Cap is the same way, pillow balls r light as hell cause the threaded part is hollow, hit something n its done.....light weight dogs gotta go also......smh
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "TKI4 PILOT" /XRAY NT1 16' /FUSION X3LCFM / M2c / PROTEK / FUTABA 4PX / SAMURAI
1evo RRR Driver is offline   Reply With Quote
Old 05-28-2013, 06:30 AM   #6820
esckalayd's Avatar
I have snapped two in the last 5-6 months. What motor do you run? I know Picco based motors with all the torque seem to cause this more than a nova based motor. I just know to have a spare axle always available.
I have actually had an issue with the dogbones in the rear axles snapping and not even touching a wall. Happened at our last major FORGASS race.
Anthony Schimizzi AKA ~The Rookie~
| Serpent America - DeSoto Racing |
esckalayd is offline   Reply With Quote
Old 05-28-2013, 10:46 AM   #6821
djiewie's Avatar
i`ve used one lightweight axle for 2 years without a problem, but i changed it recently for a new one because it was getting marks on it. Than the problems occurred wit the two new axle`s. I still have the old one but i use a standard one now. Have used RBM3 and Picco torque in the past but i race the nova stock engine now wich is just as fast for 75% less money. Its a blast this engine.
N12T1 stock NOVAROSSI.
So its must be quality from xray is slipping i guess.
Old 05-30-2013, 03:00 PM   #6822
Trader Rating: 65 (100%+)
Can anyone tell me if the capricorn big bite shock springs will work in he 2013 big bores? Getting a little impatient waiting for the xray ones to be available.
goose510 is offline   Reply With Quote
Old 05-30-2013, 05:47 PM   #6823
Team STPN's Avatar
Be patient Grasshopper. I have an awesome set up if you need it. My car rotates really well at Speedworld this past weekend. Its a combo Kit set up with a Scotty B. set up combined.
Old 05-30-2013, 10:19 PM   #6824
GREGORY!'s Avatar
Has anyone tried the new big bore shocks back to back with normal length ones?
Any feedback?
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 05-30-2013, 11:39 PM   #6825
iam interested in you set up also Team STPN
Brought to you by the number 4 and the letter X
Running a Kyo MP9 TKI3 and An STRR EVO truck
rcmad2700 is offline   Reply With Quote
