Like Tree7Likes
Old 03-24-2013, 07:24 PM   #6631
Trader Rating: 13 (93%+)
Yes ill be running the states cant wait to
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 03-24-2013, 07:36 PM   #6632
Bundy_Bear's Avatar
Cool... all the best then
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is online now   Reply With Quote
Old 03-24-2013, 08:02 PM   #6633
Thanks mate
Old 03-25-2013, 03:25 AM   #6634
Default NT1 for sale
http://www.ebay.com.au/itm/XRAY-NT1-...item1c314bef9b
Mickzo is offline   Reply With Quote
Old 03-25-2013, 05:01 AM   #6635
djiewie's Avatar
Originally Posted by Bundy_Bear View Post
Not sure why you say Pro is better.... it now requires new shocks and shock towers, new flex radio plate, new front bulkheads and lower suspension arms, new wire sway bars and some changes to the bumper.
2013 already has all these plus lighten diff outdrives & front layshaft. It does miss out on the lightened 2 speed shaft and brake upgrade...
I thought the pro already had the lightweight options? my bad.
No need to be disappointed with the Pro though because, the only thing the 2013 has what makes the car quicker is the low profile shocks (lower cg). You can`t use the old shocks anymore and i have 2 sets with different oil in them to change quick. The 2013 LP shock tower however looks weak, (i do seem to roll the car sometimes ) and i would suggest to mod the old shocktower for the LP shocks. Just redrill the holes and remove some. The wire arb is not needed in my opinion. The flex radioplate is easy to make also, if you have the regular one. I made some improvements more to the NT1 than xray did. If you are interested i can post some pictures of it while asembling the car for the first race. Every one can do it if you are handy and want it? also.
But its always nice to have the latest car. So buy the car or only the LP shocks.
Last edited by djiewie; 03-25-2013 at 06:54 AM. Reason: being positive about the 2013
djiewie is offline   Reply With Quote
Old 03-25-2013, 07:49 AM   #6636
TAMAK's Avatar
Trader Rating: 28 (100%+)
This car has more going for it than LP shocks.. Plus the shock towers are the same thickness... 3mm. I don't see them being any weaker just because they are not as tall, maybe stronger.. I like the narrow chassis, that will be nice on the corners with chassis rub. Comes with both front sway bar options. This car IMO is way more optimized than the previous. Black and orange is pretty sweet too!
I wonder if this kit has the new lower engine mounts, i don't believe it was said in the Features
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 03-25-2013, 03:20 PM   #6637
djiewie's Avatar
TAMAK,
Your missing my point.
But the car is sweet i agree with you. It
also has the flex inserts on the radioplate.
The shocks are more angled also for more grip.
It has al lot off improvements.
Old 03-26-2013, 12:24 AM   #6638
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
Any tricks to bending back the main chassis Straight? Im gonna slum it this year if i can Make It Work. New chassis not in my budget.
Rear end is bent up a bit. Seems straight left/right.
My stuff
| Team Associated - Reedy - Reflex Racing/RSD - ProAMPS RC |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/ - www.teamassociated.com
valk is offline   Reply With Quote
Old 03-26-2013, 02:15 AM   #6639
djiewie's Avatar
Valk,
Usually caused by pressing on a startbox with no flat plate.
get someone to pres the car down on a flat table and then tighten the screws.
Ordered myself a eastern brand chassis for 30 dollar? Because the rear tends to hit the surface and gets thinner with wear. Untill its to flexy and you start destroing the spurs in a row. happened to me:
Old 03-26-2013, 02:16 AM   #6640
Bundy_Bear's Avatar
I didn't say the pro didn't have lightened parts in it and yes it comes with more then what is included in the 2013 edition. While I agree you can easily cut the front of the radio tray to allow for front flex, I don't see how you can modify the rear of a tray to the same spec as the 2013 edition...
I don't agree that the Pro is still a better kit and to me the 2013 is a step in the right direction for Xray.
MissMooRC Racing
Old 03-26-2013, 07:02 PM   #6641
Rhyswilldo's Avatar
Pretty impossible to straighten the old one.... Zeppin make a good chassis and much cheaper than an xray one! And it's gold anodized!!
Rhyswilldo is offline   Reply With Quote
Old 03-26-2013, 11:20 PM   #6642
rcabj's Avatar
Default diff oil
hi,
at present my fr diff 100k, rear 60k..and the car 'pushes' on throttle exiting and mid corner..
so should i increase the fr diff to(how much) or decrease the rear to how much...thanks
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 03-26-2013, 11:30 PM   #6643
Rcabj try the spool in the front it will give you more on power steer.
Try it with the front upper arm roll centre position in the top position.
Try the plastic insert that comes in the diff and if you like the feel buy the lightweight version of the spool.
Old 03-27-2013, 07:46 AM   #6644
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
be careful though you dont want use the spool if you dont have traction but it wont hurt to try it i would go 150k-200k in front diff and go 80k rear diff just my 2cents good luck xray up
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 03-27-2013, 08:07 AM   #6645
bluer322's Avatar
I would try this also with the front roll center and adjustment mention above.
T. Nicholson
Murnan Modified Motors
Matrix Tires
Serpent, 748tq
bluer322 is offline   Reply With Quote
