Xray NT1
#4623
I recently switched to drag brakes, and whilst my driving felt alot smoother, there were no gains in lap times. I had it adjusted on the brake linkage. I tend to throw the car around and brake fairly deep and hard, so I think alittle more persistance could see improvement whilst my driving style adjusts to it.
#4624
Novarossi - when you use drag brakes using the linkage method do you find you get any brake fade from your brakes heating up?
#4625
#4626
#4627
Yes, i believe xray will release a NT2 in about march 2010. It's a basic marketing rule to come up with a special edition when a current product is going to be replaced in the near future.
A shop over here is already lowering the price of the EC and 09 by 40 euros.
So Xray is clearly aiming for a sale boost to cover some of the development costs of the new car.
But right now they are also really busy with 1/8 scale onroad car, and this will have priority over the 1/10. but i think Xray has the capacity to develop two new cars side by side.
#4628
I also feel that xray is working on a new nitro touring, maybe some new ideas like wire type front sway bar, or some aluminum bulkheads, but the next car they will sell wouldnt be a 2010 car. They also done that in the buggy class, they had released an XB8-EC and soon after that, 808 came.
#4632
Hi Guys, I have been fighting with an acceleration issue for a while now can anyone give some assistance. My car is very slugish coming out of turns and at initial start of race.
These are all the things I have tried -
- Rebuilt my Original clutch
- Tried White shoe
- Tried Yellow show
- Bought and built the New High Dynamic
- Changed Fuel tank to V2
- Changed from Maxy Fuel 25% to Byron Gen 2 20%
- Changed from LRP Spec3 to Picco JL3 Engines
- Changed Collets
Each change on different days to ensure accuracy if a solution was found, but all the above attempts failed with the same result slugish out of corners.
Any Ideas ?
- Tried White shoe
- Tried Yellow show
- Changed Collets
Any Ideas ?
#4633
- Tried White shoe
- Tried Yellow show
- Changed Collets
Any Ideas ?
- Tried White shoe
- Tried Yellow show
- Changed Collets
Any Ideas ?
#4634
I don't think Xray is going to do that. More than 60% of drivers are running NT1s from what I have seen. Why make a new car when yours is on top? There is a saying that goes "If it aint broken, dont fix it". I wouldn't be surprised to see a '10 model with other updates done to the car but without the quantity of hopups the EC brought.
The saying "If it aint broken, dont fix it" doesn't work in motorsport.
You need to keep innovating to keep that top spot.
Some other companies (Serpent, Shepherd) have lately introduced cars which i would describe as 'the new generation tourer'.
Serpent for instance has a new layout for the electronics, wire swaybar in front and aluminum bulkheads. Shepherd has the best braking system.
If Xray wants to stay on top they have to release a car with at least the aluminum bulkheads. There are a lot of extra possibilities when using aluminum instead of plastic. And just take a look at the 733, it looks absolutely stunning!.
Off course i don't think it will be completely different to the NT1.
They can keep the entire drivetrain and clutch-gearbox, because that's perfect.
But i would like to see aluminum bulkheads with a wire type swaybar in the front.
Wheelbase adjustment in the front and rear
More focus on centering of mass and low CG, this will do a lot to a car as i noticed with my own heavily modified NT1.
Less flex in suspension parts and bulkheads, flex adjustment in chassis through different inserts.
But if Xray doesn't release a NT2, i will have my own version. Hope to post some CAD renders at the end of this week.
#4635
I had a really hard time building the diffs. and once I finished they were leaking. I used gasket sealant from auto parts store hope it will solve the problem, is there any tips on how to bouild the diffs?
Thanks!
18Likes
