Like Tree18Likes
Xray NT1
Old 04-02-2008 | 11:12 PM
  #2941
Originally Posted by rx7ttlm
I have a tool that works for clutch gap, and tightening my clutch bell lol and it was 40 bucks lol..
Which tool? The Hudy clutch tool?
going4#1 is offline
Old 04-04-2008 | 06:32 AM
  #2942
MRLRCR's Avatar
Got a quick question for you guys, I recently got my NT1 a few weeks ago and built it up, the car is unbelieveable. But the problem I came upon was that when setting the clutch, endplay I think it was, the one with a reccomended gap of .6-.7 mm of play, I could only get .45mm of play. Now I am using the O.S. 12TZ 3port. Has anyone else running this engine had this problem, what do I have to do to fix it?
MRLRCR is offline
Old 04-04-2008 | 06:42 AM
  #2943
Hi MRLRCR,
Yes, it sure is a great car.
You need make sure you don't mixup "end play" and "clutch gap". These are 2 different settings on the clutch.
First you start off by setting your clutch gap, which as mentioned is .6-.7. Remove the large bearing behind the clutch bell and then assemble the clutch. The bell should have alot of play. This is what you measure and then shim at the front of the bell where the bolt is, to adjust your clutch gap. If you are not reaching .6-.7, then the collet behind the flywheel is too high. Xray has one that fits perfect.
Once this gap is set, you then put back the large bearing and set your end play. These shims go behind that same large bearing. You want to get this anywhere between .08-.15
Hope this helps.
Dennison J is offline
Old 04-04-2008 | 07:28 AM
  #2944
teamgp's Avatar
Originally Posted by Dennison J
...If you are not reaching .6-.7, then the collet behind the flywheel is too high...
Only one thing to add...if you have any shims underneath the collet/collar or in between the clutch bell bushing and end screw, then remove them and you will be able to get more "air gap".
A general rule of thumb...when adjusting the shims under the collet/collar, you should try to get the air gap to at least .6mm with no shims in between the clutch bell bushing and end screw.
teamgp is offline
Old 04-05-2008 | 08:03 PM
  #2945
MRLRCR's Avatar
Alright, yea because when I assembled everything I did put a shim behind the collet/collar, so hopefully when I take it out the problem will be solved. Either way Im gonna have to take it apart to put the yellow shoe in. Anyone have a good starting setup for 301, I know you might teamGP. Its built to all the specs in the instruction manual except I have the solid in the front and 60k in the rear.
MRLRCR
MRLRCR is offline
Old 04-05-2008 | 09:25 PM
  #2946
rx7ttlm's Avatar
anyone know of a good pitman for fuel sedan nationals in florida? lol
rx7ttlm is offline
Old 04-06-2008 | 02:06 AM
  #2947
teamgp's Avatar
MRLRCR
Burch's setup from last year works great for myself and a few others. (Bobby posted it)
teamgp is offline
Old 04-06-2008 | 05:00 PM
  #2948
The rear bar Ralph ran was a 2.1 not 2.4
MBlackketter is offline
Old 04-07-2008 | 08:17 PM
  #2949
Default lola bumper mount
Hi guys
Is there a front lola bumper mount for this car ?
at the moment im uisng a custom made foam front bumper cut on an angle but looks a bit dodgey
mrgsr is offline
Old 04-07-2008 | 09:53 PM
  #2950
asw7576's Avatar
Originally Posted by mrgsr
Hi guys
of course yes.
it's a wide bumper, but i don't know the part number, sorry.
asw7576 is offline
Old 04-08-2008 | 01:28 AM
  #2951
jca2000au's Avatar
Hi guys
331201 http://www.teamxray.com/teamxray/pro...0Wide%20Bumper
jca2000au is offline
Old 04-08-2008 | 05:11 AM
  #2952
Originally Posted by jca2000au
have you raced the NT1 yet Jay?
TomB is offline
Old 04-08-2008 | 07:05 AM
  #2953
Z-Mann's Avatar
Hi guys
i use the k factory lola conversion for the g4 but replace the lower bumber with the xray wide bumber. no foam is needed with lola body
http://www.kfactoryracing.com/produc...486&pageNum=15
Z-Mann is offline
Old 04-08-2008 | 10:08 AM
  #2954
asw7576's Avatar
Wow, is that a direct fit ? I mean the top parts ( G4) ?
asw7576 is offline
Old 04-08-2008 | 02:10 PM
  #2955
Z-Mann's Avatar
yep no modification bolts straight on
Z-Mann is offline
