Like Tree6Likes
Old 04-08-2008, 08:17 PM   #2956
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
somebody that wants to get one of those to me, I'll cut them a carbon fiber one.....
rcfoolz is offline   Reply With Quote
Old 04-09-2008, 09:13 AM   #2957
bboy's Avatar
Unhappy
NEW BEE NEEDS HELP!
Hello, I spent all day assembling the clutch and I am think I must have done something stupid since I am not able to get the clutch on to my OS TZ 5 port per the manual specs.
In step 8 of the instruction, after putting on the flywheel and tightning it against the cone (I am using a Kyosho cone, no shim between cone and engine), I can only get 8.9mm instead of 9.2-9.3mm as shown in the manual, between the flywheel nut and the crankshaft of the engine.
When trying to proceed putting on the clutch, I have 0.1mm of play which I think is wrong. I tried assembing and disassembling many times and hours, but I can't get pass the 8.9 mm.
What am I doing wrong? Help !!!
Serpent 960-08 + Max XL9
XRay NT1 + Max XXL3
bboy is offline   Reply With Quote
Old 04-09-2008, 09:57 AM   #2958
asw7576's Avatar
Originally Posted by bboy View Post
NEW BEE NEEDS HELP!
The length of the cone ( collet is the real name of cone ) should be 6mm
The shape of the collette matters. Team magic G4 collet ( yellow gold ) has the perfect shape to match xray flywheel.
( I already use G4 collette - yellow gold and mugen seiki collet - black, so I know what I'm talking )
Another alternatives : you can sand down the bottom of your kyosho collet against sand paper on flat object. Use fine grit sand paper and start sanding in circular number 8 motion. Use a caliper to measure the length of the collet. I guess 0.5mm material removal is enough to achieve 9.2mm.
Don't use anything between the collet & engine's front bearing.
Old 04-09-2008, 11:18 AM   #2959
bboy's Avatar
Ah... I see. Wrong collet ... I wonder why XRay doesn't provide the right one.
Thanks!
XRay NT1 + Max XXL3
Old 04-09-2008, 11:50 AM   #2960
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
you really use the one that comes with the engine.
Inf1nity CM Beat1 Racing
Serpent-Dan is online now   Reply With Quote
Old 04-09-2008, 12:25 PM   #2961
asw7576's Avatar
He use OS TZ5, and OS engine doesn't come with a collet.
bboy : xray sell their own collet, currently xray made for novarossi and picco engines. I think you can use novarossi collet for OS.
warning : Picco collet really meant for picco engines. I have it, but I cannot install it to novarossi.
Old 04-09-2008, 06:30 PM   #2962
advfuel's Avatar
Trader Rating: 29 (100%+)
ASW7576 why cant you use any shims behind the collet to the front bearing ? Does the flywheel come loose. Even with the nova rossi collet I still have to put a shim in for my 353.
advfuel is offline   Reply With Quote
Old 04-09-2008, 08:04 PM   #2963
asw7576's Avatar
Because he use OS engine. TZ-5
With Novarossi engines, I can use 0.2mm shim before the collet.
Old 04-12-2008, 12:55 AM   #2964
THeGame's Avatar
Send a message via AIM to THeGame
Default Spool
Does any one know where I can find an aftermarket spool for the NT1. Looks like nexus is out of stock on them? Does anyone know anywhere else that carry’s a spool for the Nt1 in the US?
Team Gravity Rc - G's R/C Raceway and Hobbies - Waldorf RC - TheTrack
THeGame is offline   Reply With Quote
Old 04-12-2008, 01:06 AM   #2965
asw7576's Avatar
If I'm not mistaken, you have to buy xray multi diff system : normal one way, one way solid, solid or spool, all in one.
Old 04-12-2008, 02:23 AM   #2966
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
you can get a decent one at. www.YBslowinc.com
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 04-12-2008, 05:09 AM   #2967
grub's Avatar
the spool from www.YBslowinc.com is a awesome bit of machinery and only weights 10 grams...you wont be disapointed
This is my xray nt1!
There are many other xray nt1's like it, but this one is mine!
Without my xray nt1,I am nothing!
Without me, my xray nt1 is nothing!
pop corn anyone or maybe some fairy floss
grub is offline   Reply With Quote
Old 04-12-2008, 07:10 AM   #2968
you can also try
https://www.ssl-stormerhobbies.com/c...s&pn=XRA335100
jelayne is offline   Reply With Quote
Old 04-12-2008, 10:04 AM   #2969
THeGame's Avatar
Thanks for the info guys..
Old 04-14-2008, 09:37 AM   #2970
bboy's Avatar
Ok, this problem is getting crazy for me.. help...
I have the TZ12 5 port engine and have difficulty putting it into my new NT1. Since the OS engine didn't come with a flywheel collar, I picked up a Kyosho one that is 5mm.
My problem is as follows:
1) I cannot get the 9.2-9.3mm with the flywheel nut, it will only let me get to 8.9mm (I can't turn further).
2) when adjusting the clutch gap, even with no shimming, I can only get 0.5mm based on the Hudy tool.
3) when I put the pinion on to the cluth bell and try to install the engine, the pinions only touch the spurs 50% of the way (I guess the crankshaft is too short?).
Can anyone please help? I have been trying to do this the last 3 days and this is getting crazy now...
XRay NT1 + Max XXL3
