Like Tree7Likes
Old 04-14-2008, 11:54 AM   #2971
asw7576's Avatar
1. I think you should buy xray collet for novarossi, and use it. Or buy Team Magic G4S collet ( bronze color ). As I said, the problem is : kyosho collet not perfectly match to xray flywheel.
Another alternative is adding 0.3mm shim to the crankshaft tip to create artificial length, so you get 9.2mm ( 8.9mm + 0.3mm ).
Super glue the 0.3mm shim to the crankshaft tip. Get the shim from Tamiya.
3. I have no idea with Q3. I think you have to build the clutchbell as per instruction. My friend use OS TZ5 in his NT1, and he is doing okay. I think he use G4S collet for his OS TZ. I also use G4S collet in my novarossi NSR for my NT1.
Old 04-14-2008, 12:17 PM   #2972
asw7576's Avatar
about the 0.3mm shim, where to put.
Old 04-14-2008, 03:25 PM   #2973
JoelNavarro's Avatar
Score another win for my NT1! There isn't enough cars running foam tires to make a class, so i ran RP30 rubber tires. Kind of a loose track, so i ran softer tamiya maroon springs in the front, and tamiya white springs in the rear. I ran 6000wt oil in the rear diff. Has anyone ever experimented with only running 2 gears in the rear diff instead of the 4 to loosen up the action? Or do you think it its not enough to handle the engine's power?
New for this weekend's racing, i ran 3 Racing's solid aluminum axle that uses the out drives from the front diff, so the durability is there. I coated the out drives and the pins that hold the out drives with grease internally so any kind of wear on the aluminum axle is minimum. I decided to go this way instead of the multi diff because i dont think i would ever use a one-way in the front. Here's the 3 Racing aluminum solid axle. $16.50
Here's my rig with a Max Power .12 SL3 (i always forget how fast that engine is!) i reviewed in the RCCA November 2007 issue.
Radio Control Car Action Magazine West Coast Editor - www.rccaraction.com
I race at - SDRC Raceway, CVRC Raceway and SoCal-RC Onroad
My Painters: Fatty Grafx -https://www.facebook.com/pages/Fatty-Grafx/138256833000949
JoelNavarro is offline   Reply With Quote
Old 04-14-2008, 04:22 PM   #2974
I have been using this spool for a few months now and I would recommend drilling out the holes on the spool and outdrives to a lager size and putting fatter pins. This should make last even longer without developing play.
Mugen Seiki USA
Dennison J is offline   Reply With Quote
Old 04-16-2008, 07:13 AM   #2975
shmoot's Avatar
Trader Rating: 17 (100%+)
Default help needed
hi guys
I going over to San Diego and LA in June and was wondering where I could see and meet NT1 drivers practicing or racing at any local tracks and also local Hobby shops location which carries NT1 spares.
Appreciate the help.
shmoot is offline   Reply With Quote
Old 04-16-2008, 10:34 AM   #2976
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
kamakazie hobbies stocks a decent amount of parts... and crystal park is a decent place to go.. its a LARGE track.. 1/8th scale track
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 04-17-2008, 06:07 PM   #2977
shmoot's Avatar
got it!..thanks bro! will check it out..
Old 04-18-2008, 08:44 AM   #2978
bboy's Avatar
I fixed it finally! I got a collar of 5mm and eventhough the clutch gap is smaller, I guess I will try for now.
As for #3, apparently I didn't assemble to spur gear correctly. I didn't push the metal parts into the spur altogether ... my bad.
Thanks so much for your help. Now I cannot wait to run in my engine and take it for a ride.
Serpent 960-08 + Max XL9
XRay NT1 + Max XXL3
bboy is offline   Reply With Quote
Old 04-18-2008, 08:46 AM   #2979
bboy's Avatar
Does anyone know what and when to use a lightweight flywheel vs the one that came with the kit?
Also how do you decide on the size of the pipe, 5mm vs 6mm? Other than 6mm is louder, when should you use which?
XRay NT1 + Max XXL3
Old 04-18-2008, 10:00 AM   #2980
D-nicest's Avatar
The lightweight flywheel has less rotational mass than the stock, which will help the engine get up to speed faster. You won't notice a drastic difference, but with combination of lighting up the clutch and the cars 2 speed and middle shafts you'll notice slight improvement. You'll notice a difference only when your on a high traction surface, and driving the car to it's full ability. 6mm stinger on the pipe is illegal, and the 5mm is legal for racing. Again it doesn't make sense to get the options unless you can make consistent lap times on the track
Diatta Collymore [email protected]([email protected])(www.fordhamhobbies.com) (Wallacemotorsports.net) Fordham Hobbies, Wallace Motorsports, WRC Racing, Hot Race Tyres, Ielasi Tuned Engines, VP Power Master fuel, KO Propo America, Paint By Mikey Mike
D-nicest is offline   Reply With Quote
Old 04-20-2008, 09:51 PM   #2981
Trader Rating: 13 (93%+)
Default Clutch issues
Hi guys, has anyone had issues with there clutch getting boggy in long finals?
I had my clutch set per the book with the exception of a yellow shoe and it would be fine in qualifiers but the car starts losing bottom end in finals.
I have switched to the kyosho 2d clutch to test in the nt1.
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 04-20-2008, 09:55 PM   #2982
rx7ttlm's Avatar
well thats kinda strange. how far into your run does it go flat? you might need to richen the bottem end a bit.. as the engine heats up and heat soaks the chassis the engine tune changes. You may not know that.. or you may, try a different clutch spring.. the stock spring is a bit on the soft side.. I have been running everything but the stock spring..
Old 04-20-2008, 09:59 PM   #2983
yeh i dont think its the engine tune.. i also found that the same engine was heaps more powerful in my rrr using the same gearing / tire size etc
Old 04-20-2008, 10:02 PM   #2984
teamgp's Avatar
Sounds like either the motor was too lean, or you were running the stock clutch spring with maybe a little too much tension. I would highly recommend the new XRAY Hard clutch spring with the spring nut set to 0.8mm (torque motor) or 1.2mm (rpm motor) down from the flywheel nut end. Flawless and long lasting.
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 04-20-2008, 10:03 PM   #2985
Ill compare with the kyosho clutch.. i would prefer the kyosho clutch as it sonly half the nt1 clutch price
