Like Tree7Likes
Old 06-09-2008, 04:05 PM   #3091
grub's Avatar
gidday my nt1 is awesome at the moment is one of the fastest cars there consestint ave 17.5 s lap done to 16.8 from 18.7s the only problem is tyre wear
will putting my rear roll center higher give me more grip ?i ve read that the higher roll center ill give me more grip and the next book said the opposite.
the link my set up
http://forum.teamxray.com/xform/inde...=652&setup=nt1
many thanks in advance
This is my xray nt1!
There are many other xray nt1's like it, but this one is mine!
Without my xray nt1,I am nothing!
Without me, my xray nt1 is nothing!
pop corn anyone or maybe some fairy floss
grub is offline   Reply With Quote
Old 06-09-2008, 04:49 PM   #3092
teamgp's Avatar
the link my set up
A higher rear roll center usually provides less rear grip and more steering.
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 06-09-2008, 04:54 PM   #3093
MugenDrew's Avatar
Trader Rating: 30 (100%+)
And less chassis roll at the sametime. Remember a roll change effects anything and everything at the same time. Sway bars dont work untill the chassis rolls, and begining to have load placed on them.
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 06-09-2008, 05:07 PM   #3094
Trader Rating: 24 (100%+)
Originally Posted by rcfoolz View Post
Randy, I'll try to make it this weekend to SS....I have a new setup that I want to try..... Get your spool out!
SOUNDS GOOD
RANDY SMOOTH is offline   Reply With Quote
Old 06-09-2008, 05:14 PM   #3095
MugenDrew's Avatar
This Sunday there will be a FDOS race at SS?
Old 06-09-2008, 05:21 PM   #3096
that's right. thanks drew
Old 06-09-2008, 07:02 PM   #3097
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
the link my set up
I looked at your setup and was wanting to know a couple things. I notice that you are running 37 rears.....did you try running 40 or 42 rears? Next time, try running a 40 or 42 on the RIGHT REAR, this would give you better wear running the harder tire and keep the balance closer. Cutting stager into the tires is also something you might want to try. Running 37s in the front and 40 on left rear and 42 on right rear would be the way that I would go. It would give you just a tad bit more steering, but would also keep the tires from wearing so fast.
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 06-09-2008, 07:26 PM   #3098
teamgp's Avatar
the link my set up
grub, I'd definitely try rcfoolz suggestion on the staggered harder rear tires. I would also recommend raising the rear pin position up one notch to the middle-bottom position and adding at least 2mm shims underneath the rear outer camber links. This will spread the wear out between both rear tires a little more, and also increase rear side-bite for more stability.
Guy Hood
Old 06-10-2008, 02:00 AM   #3099
grub's Avatar
thanks rcfoolz ill try the stager next meet' i normaly only ran 40 allround in the morning and 40 42 in the arvo's
but in now middle of winter and the track was very cold with no traction ,and out side temp of 15 deg c
it was a toss up which tyres to run for the finial, i new my tyre wear would be a factor.i did run 40s in the final and ran out of tyres in 27 minutes ..
the mugen guys that pull the same lap times as me dont wear as much tyre
i didnt try to change to much in the states as my car was on rails the best its been
Old 06-10-2008, 04:35 AM   #3100
grub's Avatar
gidday teamgp the rear lower pin you talk of its the one the lower arms pivot off?also i run 2mm on the camber links so do i take it to 4mm
Old 06-10-2008, 06:33 AM   #3101
rcfoolz's Avatar
I sent you setup information to your PM.....
Old 06-10-2008, 07:46 AM   #3102
teamgp's Avatar
Yep. Its listed as the 'rear roll center' on the setup sheet.
On your sheet, you have listed 0mm for the shims underneath the camber links. I would just raise the rear roll center position one and try that first. If the rear seems a little loose, then add shims to the outer camber link position 0.5mm at a time. Let us know if this doesn't work as there are other things you can do as well.
Guy Hood
Old 06-11-2008, 04:13 AM   #3103
grub's Avatar
you have a pm rcroolz
Old 06-11-2008, 10:57 AM   #3104
bboy's Avatar
Has anyone tried the lowest position on the rear roll center piston insert?
I understand the lower CG the better, so if this is the case, would it be best to have set the lowest position as default and change rear link holes and shim for the upright as a secondary change?
Serpent 960-08 + Max XL9
XRay NT1 + Max XXL3
bboy is offline   Reply With Quote
Old 06-11-2008, 11:00 AM   #3105
bboy's Avatar
I thought removing shims on the camber links will add more rear side grip, is this not true?
XRay NT1 + Max XXL3
