New XRAY 808
For what it's worth... I put one shim in behind the front pinion just to improve the mesh. The back has none.
Which retailer has the new black front steering blocks and rear hubs? I can only find the old "goldish" ones...
Thanks...
Thanks...
can any of you guys post pics of your 11's
I wonder if the USA kits come with lightnd outdrives and everybody else didnt?It seems like when people post about it,its the US peeps got the lightnd outdrives and the EU folks didnt?
352266 v2 front steering hub
352256 v2 front steering hub
353357 v2 rear hub carrier
cheers
anyone have a good base setup for 11 spec i jus back orderd a kit from amain
Itīs not far off the kit set up, so I would call it a good base set up.
Might not work for you, but I like it
http://forum.teamxray.com/xform/inde...tup=xb808_2011
If that link is not working, go to the team X-ray site and log into set up sheets. You will find it in the 2011 section under the name of GO Racing.
All the US kits I have seen have the lightened outdrives. I am using a setup very similar to JB's standard setup . Car is very stable, easy to drive, my buggy actually has a slight push to it but that's fine, I will take a liitle push vs oversteer.
any of you guys running kyosho shocks?
I run them on my 2010, but the 2011 shocks are improved is what I am hearing and also seeing. Cant lie though TKI2 shocks have been great. Like 4 races on them same Orings and bladders, only changed oil and thats it, still work great. When I do get a 2011 I personally will use the kit shocks.
thanks guys for the help
