New XRAY 808
Old 09-15-2013, 07:12 AM
  #12361
Originally Posted by Marky_RS4 View Post
Hi
l will steal this tread little bit .
l searched everywhere but no answer . l have little problem.l converted my old XB8TQ to electric but l cant find correct settings especially with shocks . The car weights 4060g and drives really bad on track . lt hits bottom on small jumps , if l raise ride height to maximum it still bottoms and feels like gum . Also the rear end spins quickly , the local track is tehnical with 2 big jumps and ground is dusty/slippery . what would be the best setup , shock oil and pistons , l also have spare 808 big bore shocks but rear shocks are shorter .
l really hope l will find the right answer
Regards , Marko
go to this web link http://www.hudy.net/xhudy/products/p...593873e06ead40 and download the setup book it has a lot of info that will help. look at the shock oil & spring section
Gorden
light is offline
Old 09-15-2013, 10:25 AM
  #12362
Default shock set up for electrics.
Gorden
What we have found is that since the Electric is heavier, It will need a heavier
shock fluid to help with the pack. We are running 5 hole 1.2 tapered shock pistons
on the mugen Mbx7. shock oils are 700/650 cts rated fluids.
You might want to work on the weight bias of the battery. Moving it back a little helps a lot with the rear end traction.
hope this helps.
m2cracing is offline
Old 09-15-2013, 12:19 PM
  #12363
Thanks for quick replys . Should l go with original shocks , rear are little bit longer or with newer 808 big bore shocks . Did you drilled aditional hole by yourself ?
Marky_RS4 is offline
Old 09-22-2013, 10:05 PM
  #12364
[QUOTE=jnfweld;12566506]Here is a link to a blow out on Xray parts. Most parts are $.99. Limited to stock on hand $9.95 flat shipping no matter how much stuff you order.
Thank you mate , do they ship international becouse lm from Europe . BTW unbelievable prices .
Old 09-24-2013, 04:14 PM
  #12365
jnfweld's Avatar
[QUOTE=Marky_RS4;12568065]
Yes Will ship internationally.
jnfweld is offline
Old 09-25-2013, 10:35 PM
  #12366
Gizmatron's Avatar
where's the link?
Gizmatron is offline
Old 09-25-2013, 11:16 PM
  #12367
It was there , just search for Team Helotes
Old 11-08-2013, 05:26 PM
  #12368
jnfweld's Avatar
More closeout parts added and website updated.
jnfweld is offline
Old 02-22-2015, 12:09 PM
  #12369
Rich Panganiban's Avatar
Trader Rating: 72 (100%+)
Sorry to dig up an old thread but does anyone have a stock chassis for the 808. Preferably new. If so, please PM me.
Thanks!
Rich Panganiban is offline
Old 02-23-2015, 07:12 AM
  #12370
rpoage's Avatar
Thanks!
Here you go.
XB808 Alu Chassis Long 3mm HC
http://ashfordhobby.com/SearchResult...eyWords=351103
rpoage is offline
Old 02-24-2015, 08:25 PM
  #12371
Thanks Robert.
Old 12-07-2015, 09:33 PM
  #12372
EDWARD2003's Avatar
http://www.amainhobbies.com/rc-cars-...a357331/p24531
I am looking for some dimensions on these screws.
I am looking for the shoulder length from the bottom of the cap to the end of the threads. Also the diameter of the shoulder.
Thank you very much!
EDWARD2003 is offline
Old 12-08-2015, 06:43 AM
  #12373
Frank L's Avatar
Trader Rating: 148 (100%+)
The measurement you requested is 45.5x3mm
Frank L is offline
