New XRAY 808
Old 03-21-2011, 02:11 AM
  #9931
grizz1's Avatar
Originally Posted by Lille-bror
Hi.
What is your normal setup?
Not sure how to get PDF set up sheet on here. Will PM you with attachment.
grizz1 is offline
Old 03-21-2011, 02:22 AM
  #9932
grizz1's Avatar
Originally Posted by aussies1129
for the 2010 I would service all bearings and check your steering bearing also check your pins on all your drive shafts, basically your checking for too much play if there is to much play then change them. I would definately do all my diff and shocks( I normally do diffs every few months anyway) I also recheck for any play on your pinions in your diff housing this area needs alot of attention be sure that you have the smallest of play from your front and rear drive shaft pinions and diff gear, if there is play you need to reshim. ok thats fairly close but I personally strip the car at the end of each race season and rebuild but thats up to you
did I miss anything fellas
oh upgrades you can get the kingheadz extended motor mount, rear alu brace, graphite disc and hardend brake pads, closed in wheel nuts(xray or vp pro are good) and my custom fit shock covers for that extra bling you should be looking very good now
Only other thing I would change as a matter of course is the centre diff towers. These can get a bit worn resulting in some front to rear slop of the centre diff outdrive bearings. If you do what aussies 1129 has listed you will have no problems.
grizz1 is offline
Old 03-21-2011, 03:44 AM
  #9933
aussies1129's Avatar
Trader Rating: 74 (100%+)
hey shane did you notice a bit of slop back and forth in the front arms the front and back shims dont seem to be as tight in the 2011? how is yours?
aussies1129 is offline
Old 03-21-2011, 10:46 AM
  #9934
Marcus Falconie's Avatar
So did they hit the Usa yet????
Marcus Falconie is offline
Old 03-21-2011, 01:12 PM
  #9935
bigmatt's Avatar
Trader Rating: 16 (100%+)
marcus, did x ray stop making -Xray XB808 Alu adjstable rear hub carrier 353357? It's the new black one that has the ball on top,acts like a ball joint.and I don't think they hit here yet.
bigmatt is offline
Old 03-21-2011, 01:25 PM
  #9936
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
I have not seen them in states yet. But im wanting
To here feedback on the 11 vs the older xrays... ??
Ultraspeed84 is offline
Old 03-21-2011, 02:11 PM
  #9937
grizz1's Avatar
Hi Michael - Nope, mine are sweet. I was running the upgrade alloy holders on my 09 and they were a bit sloppy, but the 11 ones are a nice snug fit in comparison.
I have gone from the 09 Spec (upgraded 08) to the new 11. Did my first race meeting with it last weekend. Vast improvement.
More stable, more steering (rotates through the corners better), jumps awesome (the 09 was no slouch in the jumping department, but the new car launches easier and jumps flatter and longer with minimal throttle input), just seems more drivable all round IMO. I just ran my 09 set up, no changes required and was on the pace straight away. Still running the 09 body as the new 11 cab forward body is at the paint shop. This may offer even more steering control when fitted over the older low profile 09 body.
Hope that gives you an idea.
grizz1 is offline
Old 03-21-2011, 06:27 PM
  #9938
Two-speed's Avatar
Trader Rating: 24 (100%+)
The Eagle has landed! It is confirmed, the kits are on their way to shops as we speak. I picked mine up today. My LHS sold six in one hour.
Love that new kit smell!
Two-speed is offline
Old 03-21-2011, 08:12 PM
  #9939
rfleck's Avatar
Trader Rating: 58 (100%+)
Yes, got mine today thanks to Indy RC World! New buggy build and new motor break in to follow=)
rfleck is offline
Old 03-21-2011, 08:25 PM
  #9940
rfleck's Avatar
Shock caps aren't black unless I did not see a supplemental package. Mine were the same as the 10spec
rfleck is offline
Old 03-21-2011, 11:48 PM
  #9941
looks like I can call mine a limited special edition with the black shock caps
Old 03-21-2011, 11:59 PM
  #9942
"Black Ops" Edition...
ganymede is offline
Old 03-22-2011, 01:32 AM
  #9943
Shane, just enter your setup in to teamxray setup sheets and don't set to private, then you can link directly to it or people can search your setups by name
http://forum.teamxray.com/xsheets.php
I have my old Truggy setup in there as get asked quite lot about the setup on it. http://forum.teamxray.com/xform/inde...=435&setup=xt8
NZ_Basher is offline
Old 03-22-2011, 02:33 AM
  #9944
grizz1's Avatar
Cheers Paul How did the 11 go at the Nelson meeting ?
grizz1 is offline
Old 03-22-2011, 03:17 AM
  #9945
grizz1's Avatar
2011 set up from last Sunday
http://forum.teamxray.com/xform/inde...tup=xb808_2011
grizz1 is offline
