Mugen MBX6
The solution is this 10X12X0.3 shim, place this shim between the shock body and the cartridge that holds the o ring stack. the shock will be smooth as your B4 Here is the part# 10414 by OFNA a pack of 10 is $1.49, Dont stray away from the stock O rings by mugen,they are some of the best out there.
There is alot of people on here useing these.
Scott
Scott
Scott - of course!!!! Makes perfect sense. remove some crushing! I always thought it took forever to tighten the caps with way too much elasticity!
Thanks for the killer tip
Paul
I don't understand what you mean by "sticking". I thought the shocks were pretty smooth
How much fuel does the buggy tank hold with and without the reducer??
Scott
Scott
the stock orings are pretty good, like you lonestar I tried a bunch of different orings until I learned what the real cause was. also, I would not bother with any petroleum based lubes, the stockers are at their best with just silicone oil. and I will just lube the seals with shock oil.
one other tip if I may to keep your shock always stiction free. before a shock oil change I will unscrew the seal cap and push the shaft a little to purge out the the seals with some oil. this allows you to remove any dirt wedged and re-wet the seals with oil. screw back on and change oil in the usual manner. I guess this wont work though if you run no rebound in the shocks.
I will also fine tune rebound by venting excess oil via the seal cap. Its how the touring car guys do it I believe. It allows the bladder to stay relaxed and makes quick work of getting an exact setting. you can even add rebound easily by pouring oil down the seal well.
[QUOTE=johnny t;9190701]Your welcome...
THANK YOU ! I was just passing along the good idea
Johnny was the founder of the shim solution
Scott
Scott
awe shinn, just giving you crap. everyone gives me a hard time so I got to pass the favor. good run (TQ) in that truggy class saturday, I only wish we could of duked it out in the buggy main.
Scott
Scott
Scott
So you are just adding a washer, and not removing any other parts? If so how does this help to make the shaft feel more free, it would seem that adding a washer would make the orings squish more and tighten on the shaft. I'm just curious, but this sounds interesting enough for me to try.
ok, now I see. thx for the explanation
