Mugen MBX6
#9887
I find that the ttr diskes can glaze over
#9889
get the updated losi 2.0 disc and use the stock mugen pads but dremel the fiber off them you will have to dremel a little plastic off around the bottom to get the disc to fit but mike just did his and said its great and thats what im going to do to mine
#9895
So totally newbie question here... I'm getting ready to order my MBX-6 but I was wondering if there is much difference between the MBX-6 and the M-spec? I see that on most sites I can get the M-spec for just a tad more (about 5-20$) but that gives me a set for wheels and tires and a body. Does the "standard" MBX-6 come with some better parts than the M-spec that closes the gap between the two kits or is this just a no brainer?
Also, at the risk of opening up a can of worms, please recommend a good engine and pipe.
Thanks,
Shane
P.S. I'm sure this is in this thread somewhere, but who has time to read over 9K posts??? And yes I tried a search and still got tons or posts... This thread is just too big...
Thanks,
Shane
#9896
the M-Spec is pre built
#9897
I know that... But is that the only differance? If so, it seems like the M-Spec (that comes with wheels, tires, and a body) is a better deal. I have always bought the pro kits because I like to build my cars, but in this case maybe I'll have to go pre-built...
What about the engiene and pipe?
#9898
Thanks,
Shane
Thanks,
Shane
The Kit has 1 step stiffer springs, other than that they are the same (and include the same) but the M-Spec is pre-assembled as a race roller.
How much do you have to spend on an engine/pipe combo?
#9899
For engine it dosn't really matter just don't over motor your self.
#9900
We are a Mugen specialty shop in Georgia, check us out www.racemugen.com
I've seen that engines start at around $200 and go up and pipes are about $65 and up... I don't mind spending more but if I spend say $400 as opposed to $265, am I really going to see that much difference? I guess I would say I want to spend whatever is going to give me the best bang for the buck...
Does that help?
