Mugen MBX6
#2386
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
i had a venom 1600 lipo in mine that really did fit nice. dont put a lipo in this car! switched to a reedy 1600 nimh which added 40 grams and the car was way better. need the weight on the right side with the motor/pipe on the left and the rear needed the weight for traction.
#2387
ok......
![Batman](https://www.rctech.net/forum/classic_images/smilies/batman.gif)
#2389
#2390
WHO WOULD EVER FIGURE THAT A MUGEN WOULD END UP LIGHT IT IS A GREAT CAR REMINDS ME OF A RC8 AND LOSI MIX TOGTHER AS A CROSS BREED LOL IT IS THE BEST CAR OUT THERE OOH AFTER THE ALUM UPPER ARM SUPPORT OPPs cap locks on sorry
see what haPPEN when you can only type with 1 hand lol mikel
#2392
#2394
lipo's now are no worse and NIMH. If you have recently purchased a charger chances is that it will charge them. They hold no memory so there is no need to cycle them. There voltave output is linear compared to nimh. weight less and in most cases has more compasity. i know on a 1000mah lipo that i have i can easily make a 45 min main and warm up. try doing that with a 1000mah nimh.
#2395
#2397
Can I put the mbx6 pivot balls on my 5r?
#2398
#2399
not saying the lipo is bad, i use them in my radio,t4, the big thing is the weight. the car is very light but theres only so much that can be removed from a pillowball front end. that extra weight in the rear helps with the weight transfer. you can add lead weight but you may want to bolt it down. i had the car down to 3250 changed the battery and the car felt much better. just trying to help, i dont want to start a battery war lets leave that to the electric guys. lol
#2400
Actually that could be yes and no on the MBX6 AL pivot balls. The MBX6 uses two MBX5R optional AL pivot balls in the top arms, but MBX6 specific in the lower. I would assume if you ran the optional MBX5 longer front driveshafts, they would work, but I haven't checked. I assume you can use the lower shouldered pivotballs without the washer like on the MBX6.
