Mugen MBX6
#9741
I bought the pins this weekend at a race and tried to change them there with a 6mm socket and a hammer. Those pins wouldn't move 1mm :/ Did you heat them or something?
#9742
Any photos of the pin mod please?? I'd like to understand better..
#9743
I did not have to heat them, i stood the 8mm socket on a steel work bench and placed the bone on top of the socket and gave them a few hard hits with the hammer, until the pin was flush with the bone on the one side. Then i used a center punch and a hammer to further drive the pin. Once it was past flush, then i moved to the vise. I used the new pin to push out the old pin using the vise and socket as a press. Some of pins come out harder than others. I have a friend that broke a pro motion chain breaker trying to change a set of losi pins. So if they dont come out, try a little heat.
#9746
The disadvantage seems that with the laydown setup you have a "double falling rate" at which the servo drives the steering. With a standup setup the servo throw is linear with the steering linkage. The standup setup is more direct and responisve.
Mugen had a laydown setup through the MBX5 years and went away from it.
