Mugen MBX6
#9136
Tank
I asked on hear a few months ago if there was any problems with the fuel tank and everyone said no way. So at the track this weekend I had a guy prove it to me. With a stock tank I could fill up and my tune was good for about half a tank, then would lean out as I got low on fuel. I could then re-fill and the tune would go back to normal for the first half of the tank, showing some type of leak in the tank where the fuel gets picked up. I had heard of this before but this proved it so to speak.
So, I went to the hobby shop and got hot bodies clunk parts and installed them in my tanks. This is reletively easy if you are sorta handy. It involves some precision work with scissors to remove some inner tank parts and possibly with a soldering iron if you want to smooth it out to look really pro. Then just a drill bit or reamer and you have a clunk. I thought the results looked really good. I put fuel in the tanks and they seemed to be sealed really well. So back to the track.
The clunk tank I made for my truck seems to work great, no more tune change and no problems at all. The buggy tanks on the other hand, I made two, do want to pick up the fuel properly. The motor won't idle consistent and you can tell it's not getting even fuel flow. I tried two motors, and they were the same, car would run inconsistent and flame at random, especially on a rollover. So I went back to a new stock tank which eliminated the inconsistent idle and fuel flow, but still had the leaning out problem and ghost flame outs. This has been on going in my mugen buggy and is very frustrating.
Moral of the story, will Mugen or some other aftermarket company please make a dam reliable fuel tank with a clunk. They would be freaking priceless.
#9137
I tried to use a longer return line, didn't work!
I try to use a gas cooler, it was worst!
I tried to change the way of the return line, again, didn't worked!
I just can understand how the pros handle it, Savoya is probably uses the same fuel tank, how does he do it?
#9138
Savoya flames out too! I remember some big race a year or 2 ago(euros?) he won but it got close at the end cause he flamed on a pit. They blamed it on fuel splashed on the pipe but....
Tried my clunk set up today for the first time and that was my biggest impression. I didnt know when i was getting low on fuel. Consistent till the end
#9140
I am going to do some more testing with my buggy tanks. Like I said, the truggy one is perfect, no complaints. However, with the same mod on the buggy tank I had worse problems than with the stock tanks. Maybe I wasn't as good with my drill or something and didn't get a good seal, I don't know. I can't find any fuel leaking but air is harder to detect. I will be re-sealing them and trying again, plus putting the same motor in another car to rule that out. I will report back.
I would rather one be available without the mod though. Much easier that way. I am also finding fuel line routing to be a big problem with the mod.
#9141
#9142
My buggy got the tank problem this weekend. Car comes in, pit man opens lid, motor revs like crazy, pit man puts fuel gun in then dies. Never left pit lane. Did it every pit. Clunk style solves all of that. If done properly.
#9144
Nothing else fits.
#9145
#9146
Tank Mods
2 friends run the tamiya tank and it seems to work and fit well.
15x21 bearing seal
shim the oring for more squish. (tighter seal)
Collars for extra spring tension.
Hacked Tank
Getting your 5mm hole height
losi clunk laying in pocket
Its also important to cut the boss from the capacity plug off the floor of the tank, this allows the clunk to lay and work properly.
#9147
Does the Tamiya tank solve the refueling issues? Cause if it does, there may be other issues we arent addressing because it is NOT clunk style and has the same shitty o ring seal on the cap, NOT TOP SEALING! So basically the same friggin tank! I have one right here. Also the D8 tank doesnt realy fit
If Mugen keeps a deaf ear to the tank and arm problems, there may be a mass exodus to THE Car
#9149
I ran mine at the Byrons race this weekend. The truck one I ran the fuel line up between the top plate and the tank and went backward through the fuel filter, and to the carb and it was right on like 149-150. The buggy with the line coming out and bending around the steering post and back under the pipe mount and straight to the carb with no fuel filter was right on also at 124-125 so I didn't have alot of options running the fuel line. I may leave the restrictor in my next one and see how it works. I think it will hold the clunk off the bottom of the tank though.
