Mugen MBX6
#9046
guys... what ere the weights of your buggys???
I think mine is a little heavy.
"3.5kilos" with everything on it
I have already changed the axles, drive cups to aluminum.
titanium screws.
titanium turn buckles
I think the aluminum damper stays front and rear makes it a little heavier
my buggy comes with:
nova plus4
futaba servos
AKA tires
metal hydryte receiver batteries
any ideas to shred of some weight? 0.2 kilos would be great!!
THANKS!!!!
titanium screws.
nova plus4
futaba servos
AKA tires
THANKS!!!!
My Sirio STI CL7B was 370grams,now use Picco Evo3 330grams only, and my car total weight is 3360grams without body and fuel.All my car was box stock.
#9048
Guys,I think this mugen car like the shocker to be soft,I had tested 550 front,500 rear,The car feel like not holding a line at all at loose track.500 front,450 rear great for bumpy and bit loose. 450 front,400 rear good for smooth track.
As for 600 front and 550 rear is for very high traction track.
#9049
No I dont think so. I weighed mine when it came in and the difference was around 10 grams lighter for the bce chassis. I just wanted the chassis for its increase in handling, which it did. I used to run 450 f, and 400 r when I had the stock chassis but after using the bce chassis for a while I felt that 400f, 350r was the ticket.
#9054
#9055
I have been running 450/400 in mine and now running 500/450 in mine converted to electric.....Ran it back to back with a buddies losi, the mugen was so much easier to drive fast....
JPZ, have you ran a mugen electric yet? Gonna have to try mine if not.....
#9056
#9057
I run 600f/500r with 3.0mm front and rear swaybars on dry astro turf. The car is doing very well. My mate Losi can't follow I had a Losi before and I like the Mugen more. I can setup it up better for our astrotracks. The Mugen is harder to setup, but there are much more possiblities than with the Losi. Once you the Mugen dialed, it's fast as hell And with 20-15-10 in the diffs, the car feels like it's on rails
#9058
Thanks for the business, we have a re-stock batch of BCE chassis that should be in this coming week!
Thanks to all the Mugen Racers that support us, we try our best to provide the best prices and service.
#9059
What setup changes did you guys make other then shock oil? I ordered a chasis not sure if I'm going to keep the car for next season though. So many new kits to try
#9060
Purchased the bone saver to replace my uni pins and I will have to say I am not at all happy with the device. I followed the instructions exactly and when I started to push out the first pin it split the pin in two and messed up the red tip screw pin. Nest step I ground the split pin flush and tried the yellow screw to finish the job, got it centered and started pushing the pin out, (so I thought) only to find out it was either pushing in our bending the little pin on the screw. So now I have $60.00 tool that is useless. Any input from others who have used this tool. And the pin is still in the dog bone.
