Like Tree3Likes
Mugen MBX6
Old 07-28-2010, 10:23 PM
  #8386
barty1989's Avatar
Originally Posted by michaelfox
tried my overdrive diffs today, and it worked out great!!
with 15-15-7 in the diff i really got lots of power and punch.
still lacking a bit of low speed steering, i know i have to drive a bit differnt than without the overdrive but still.
any one?
best thomas from Bergen Norway
give this a shot
run this basically everywhere with minior changes to shock oils + rear upright + front upper arm positions depending on the track
http://www.buggy-sport.info/index.ph...420&Itemid=109
barty1989 is offline
Old 07-28-2010, 10:41 PM
  #8387
imaxx21's Avatar
yeah Prather was the best...
owner retired
imaxx21 is offline
Old 07-28-2010, 11:07 PM
  #8388
mrbusta's Avatar
Trader Rating: 20 (100%+)
Originally Posted by barty1989
give this a shot
hahahah awesome buddy!!!!!
its the setting i have been using for a while works a treat
mrbusta is offline
Old 07-29-2010, 01:29 AM
  #8389
michaelfox's Avatar
he he...
way too thick shock oils for my liking, and our tracks are a bit on the bumpy side so thick oil will make the car bounce all over the place.
as for the rest of the setup, maybe ill give it a try.
does the ackerman position matter all that much?
or are they just minor changes?
see the ackerman is in the forward position.
just playing with the setup this summer
michaelfox is offline
Old 07-29-2010, 03:38 AM
  #8390
barty1989's Avatar
he he...
id say start with 45 40 wt shock oils. with 24-25mm ride height
oils are slightly higher then normal due to the shocks being leaned over
softer initial dampening. also makes the car more forgiving.
as for the the ackerman position. i have only ever ran in the front position.
rearward holes for quicker steering response
Old 07-29-2010, 03:55 AM
  #8391
Default engine mount
Originally Posted by wfo
I need a new motor mount What are you guys using? How is the m2c 1piece ? or go w/the king headz...
This is the best mount you can get if Dave still has some left.
http://www.mugenracing.com/phpBB3/vi...php?f=2&t=1193
jet flyer is offline
Old 07-29-2010, 07:48 AM
  #8392
vti-chris's Avatar
A friend of mine just bought an MBX6 and we would like to know a few more details on the overdrive thing.
What are the part numbers that match and where do we install it in the rear or up front.
We did the math and if we install the 42T/12T in the rear it actually overdrives the rear since the front is 44T/9T...meaning it will turn faster than the front...won't this cause oversteer.
Xray uses the same principle 41T instead of 43T but puts it up front...thus turning the front faster to pull the car forward and not oversteer.
vti-chris is offline
Old 07-29-2010, 09:21 AM
  #8393
morgoth's Avatar
The front needs to turn faster than the rear.
morgoth is offline
Old 07-29-2010, 09:30 AM
  #8394
awdcameolsx's Avatar
Trader Rating: 36 (100%+)
I got both the king headz is way better. The extended part helps with the excesive chassis flex, the pined quick change part is amazing for maintnence, and the king heads wont hit the engine block like the m2c will with some engines.
awdcameolsx is offline
Old 07-29-2010, 09:35 AM
  #8395
michaelfox's Avatar
hey again
anybody tried the AVID brakes for the mbx6? i see they are a bit thicker so they will not fit straight into their place.
i see somebody online says remove the braks pads.
is that right?
Old 07-29-2010, 09:40 AM
  #8396
jnslprd's Avatar
Originally Posted by dishsoap
What is everyone using for fuel line. I am noticing that the mugen fuel line is not holding up to well.
Who makes the top of the line fuel tubing????
HERE IS THE USUAL REPLY.
Mugen is the best fuel line, I have had the same line for 11 years now its not even dirty.
Maybe your installing it wrong, make sure it goes on the tank and the carb.
Also check to see if the ends are round.
How annoying is this?
jnslprd is offline
Old 07-29-2010, 09:52 AM
  #8397
hey again
is that right?
In the stock brake setup, the brake "material" is on the calipers, while the discs are metal. In the case of the avid discs, the discs are the brake "material". This requires the brake calipers to be metal only. You do not want braking material on both disc and caliper. Hopefully this makes sense.
We use the xray hardened steel pads (XRA354121) with the avid discs. This is an excellent combo with consistent braking action. Build these brakes with about a 0.5mm gap and you should be fine. Remove the lower brake disc guides on the center diff mount, otherwise you will have clearance issues.
071crazy is offline
Old 07-29-2010, 10:10 AM
  #8398
vti-chris's Avatar
I agree...so what do we do??
I mean i know but need to confirm it...in case i'm still sleeping.
Old 07-29-2010, 10:29 AM
  #8399
morgoth's Avatar
You want the car to pull through turns. If the rear is turning faster than the front, the car will drift/oversteer a lot. You don't want that
morgoth is offline
Old 07-29-2010, 10:30 AM
  #8400
s porter's Avatar
The stock MBX6 pinion is a 13T not a 9T if memory serves...Try your math again with that.
s porter is offline
