Mugen MBX6
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
So I was reading a little about nitro engines and have a simple first question.%
Hmmm... sorry about that! Just noticed it didn't post the rest of my message after I edited it!
If you look at the link below, you will see my filter. I have read that you should use filter oil on your filter prior to running. But, my filter has an outer filter (pre-filter?) and an inner one. Which should I oil?
https://skydrive.live.com/redir?resi...NLRaGg9xy82D5k
hey guys i picked up a used mbx6/r should be here in a few days. what exhaust manifold do you all run. i read somewhere its narrower i think. thanks in advance
I run in GA as well, mainly Loganville and the area. I use Mugen O rings in the diffs, 450 in front shocks and 400 in rear with the double action Fioroni pistons, a little hard to get and expensive but worth it. For diff fluids I run 7/10/3, but I'm thinking of bringing it down a little for the cooler temps.
HI guys, does anyone mod his mbx6 to put the rx pack on the front? And what did you use to do that? Please post pics if possible.
Thanks a lot in advance guys.
![Big Grin](https://www.rctech.net/forum/classic_images/smilies/biggrin.gif)
Thanks a ton for the heads up man, where can i get the graphite tray? Link please...
so to confirm the Kyosho bladers will fit inside the mugen shock? Also are they any different then the CSI bladers?
