Mini-96 World Challenge >
Like Tree3035Likes
Old 09-22-2025 | 06:44 PM
  #3286
Jeef's Avatar
Jeef is offline
Old 09-23-2025 | 01:43 PM
  #3287
Originally Posted by chjosi
What's up Kurt?
I run slicks more than I run radials, but only because I run the radials almost down to nothing or because I can't keep up with others who have new taller radials in a spec geared class. This is more noticeable when running a large layout at the LHS. For M96, I find the car drives better when I can get lower ride height in the rear, so well used radials (no pattern left) or new slicks.
I have heard the same as you, but when we get a new track layout that is dusty and dirty, the compounds don't act the same.
haha. What’s up dude
I’ll have to try the smaller diameter for the 96. I do like running the radials better so far on the big layouts. Only gripe would be that I like to true my tires and can’t do much with the radial without taking all the tread off. You are correct too. Track condition can completely change how the tires would normally react. Part of the fun
Gburr is offline
Old 09-23-2025 | 03:31 PM
  #3288
Locally now that there are 1/10 and 1/12 drivers running 1/28 cars, they are using tire combos that are definitely not standard and still going fast.
Getting a car that you can drive consistently is the biggest advantage. In the box stock class radials are being used to get that higher rollout, but does it matter if they are in the wall every lap?
ekim628 likes this.
chjosi is offline
Old 09-26-2025 | 08:06 AM
  #3289
Had a question, saw pictures on the Facepage group of people using tape on the side rails. Are many people using that? Or is it allowed? I don't remember anything in the rules specifically speaking about it. It would be a help I'm sure but I've never wanted to use it just because I like to change layouts and it seems like it would be a pain, but maybe it isn't too bad to be peeling that stuff off constantly?
Koma306 likes this.
joelisenat is offline
Old 09-26-2025 | 12:46 PM
  #3290
AM03GT's Avatar
I also thought it wasn't allowed...
Koma306 and joelisenat like this.
AM03GT is offline
Old 09-30-2025 | 01:40 AM
  #3291
BurgerMaster's Avatar
Default September Results!!
Mini96 September Results
Well my first full month participating in the Mini96 challenge is in the books. Head out today for a 5 day work trip. Last night I put in some runs taken this month’s total laps to 11,013 but couldn’t beat my times from earlier in the month. A couple things that came out of last night was a new fast lap with my 3500 2WD Open @ 3.429. Also with that allowed for a new top three consecutive @ 10.545. Fastest single lap for box stock was a 3.589 with a 11.062 top 3. I really wanted to get my box stock car under 300 and had several runs with a pace below that more than half way thru but 75 laps doing that is hard. I don’t think I will be able to get it this month because so far I feel terrible going CCW. Brought the cars with me on this trip to freshen them up and be ready to throw down some laps Friday night! Thanks to all the guys in this group to bounce ideas off of to push each other!
Class- 2WD Open
Date- 9/18/25
Location- Elk Grove, CA
Race Time- 75/4:54.772
Fastest Lap- 3.529
Chassis- Reflex RX28 Gen2
Body- Rad Body
Wheelbase- 98mm
Tires- PN KSM Med F Marka V1 15deg Radial now slick
Motor- HobbyWing 3500kv
Batteries- Reflex 400mah Lipo
Front Springs- Pink
T-Plate- N/A
Motor Mount- Kit
Dampener (If applicable)- Kit
Dampener Fluid (If applicable)- 30k Kyo
Gearing- PN-53/13
Notes- Fresher car as I just had done all the suspension and diff about 2000 laps ago.
Class- Box Stock
Date- 9/18/25
Race Time- 75/5:03.260
Fastest Lap- 3.621
Chassis- MR03 Readyset
Body- Jom
Wheelbase- 98mm
Tires- PN KSK 40deg F / Marka V1 15deg R
Motor- Kyosho Stock
Batteries- Carrera F850
Front Springs- Kyosho Red
T-Plate- Spring Steel #2
Motor Mount- #7
Dampener (If applicable)- Stock
Dampener Fluid (If applicable)- Kyosho 30K
Gearing- 7T
Notes- Front Knuckles had 2x shims under to lower the ride height. Front tires have 22.6 Reflex rings. Motor is new. Did water break in on it for 45 mins. Batteries get a discharge @ 1.0amp before charging @ 1.5 amps.
ekim628 and BoxxerBoyDrew like this.
BurgerMaster is offline
Old 09-30-2025 | 07:53 AM
  #3292
Default Sept 2025 Box stock
It was fun to put some laps in this month. Really miss running this mini 96 track and the great community.
Class- Box Stock
Date- 9/29/25
Location- Camarillo, CA (OLRC)
Race Time- 75/04:54.683 (294.683)
Fastest Lap- 3.739
Chassis- MR03
Body- Kyo ASC P1
Wheelbase- 98mm
Tires- PN KSM soft/PN KSM medium
Motor- Kyosho Stock
Batteries- PN750
Front Springs- box stock black
T-Plate- PN Fiberglass 4
Motor Mount- MM
Dampener Fluid (If applicable)- N/A
Gearing- 7T
Notes- Easy to drive. Car wanted to pull left at the end of the straight. Fun car.
Lucky Lou is offline
Old 09-30-2025 | 09:45 PM
  #3293
AM03GT's Avatar
Class- Box Stock
Date- 09/26/2025
Location- Irvine, CA
Race Time- 5:15.363 / 315.363
Fastest Lap- 3.978
Chassis- Kyosho MR03 Rwd
Body- Audi R8 LMS
Wheelbase- 98mm
Tires- FR (PN KSM538) / RR (Gekko RS2 GK-005)
Wheels- PN 10-Spoke 20mm F0 / PN 10-Spoke 20mm R2
Motor- Stock Silver Can
Batteries- PN Racing 900 mAh
Front Springs- PN Orange
T-Plate- PN #4 Spring Steel
Motor Mount- Stock Plastic
Dampener (If applicable)- Stock Center Shock
Gearing- 7T Pinion (PN Pro Match) / Stock Differential (44T)
Notes- Kingpin Flip
AM03GT is offline
Old 09-30-2025 | 09:46 PM
  #3294
AM03GT's Avatar
Class- Open 2wd
Date- 09/29/2025
Race Time- 5:20.217 / 320.217
Fastest Lap- 3.891
Chassis- Associated RC28R
Body- Jomurema GT01 (Lexan Roof)
Wheelbase- 98mm
Tires- FR (PN KSM538) / RR (Marka MZRV1R10)
Wheels- PN 16-Spoke 20mm F0 / PN 16-Spoke 20mm R2Motor- Rocket 2500kv
Batteries- Reedy 400mah LiPo
Front Springs- AE White
Front Shock Fluid- N/A
T-Plate- N/A
Motor Mount- Stock
Dampener (If applicable)- Stock Center Shock AE White Spring
Dampener Fluid (If applicable)- 30K
Side Shock Spring- AE Med Torsion Bar
Side Dampener Fluid- N/A
Gearing- 13T Pinion / Stock AE Gear Differential (53T)
Notes- ESC in "Blinky" zero-timing mode.
BoxxerBoyDrew and joelisenat like this.
AM03GT is offline
Old 09-30-2025 | 10:05 PM
  #3295
Class-Porsche
Date-9/30/25
Location-Omaha
Race Time-5:34.257
Fastest Lap-3.993
Chassis-mr04 RM
Body-Porsche gt3
Wheelbase-90mm
Tires-front: pn medium slick rear: Marka 15 slick
Motor-Kyosho xspeed 4100
Batteries-speed house
Front Springs-red
T-Plate-soft carbon
Motor Mount-RM
Dampener (If applicable)-nexx racing
Gearing-10tooth 64p
Notes-
Gburr is offline
Old 09-30-2025 | 10:06 PM
  #3296
Class-box
Date-9/30/25
Location-Omaha
Race Time-5:38.555
Fastest Lap-3.929
Chassis-mr04 MM
Body-c7 corvette
Wheelbase-98mm
Motor-white cap
Front Springs-stock black
T-Plate-stock
Motor Mount-stock MM
Dampener (If applicable)-na
Gearing-7 tooth
Notes-
BoxxerBoyDrew likes this.
Gburr is offline
Old 09-30-2025 | 10:35 PM
  #3297
Results
Class- Box Stock
Date- 9-30-25
Location-Omaha, NE
Race Time- 5:14.624
Fastest Lap- 3.871
Chassis- MR04
Body- Mclaren 12C
Wheelbase- 98MM
Tires- Kyosho 30 low height front Marka V1 10 Slick rear +1/+3 offsets
Motor- Stock
Batteries- Kyosho Speedhouse
Front Springs- Green
T-Plate- Kyosho FRP 6M
Motor Mount- MM
Dampener Fluid (If applicable)- 5k
Gearing- 7T
Notes- Finally had a great run, feels good after issues with other cars. I like this body!
Old 09-30-2025 | 10:43 PM
  #3298
Class- Stock
Date- 9-30-25
Location- Omaha, NE
Race Time- 5:18.088
Fastest Lap- 3.881
Chassis- PN2.5
Body- Jomurema
Wheelbase- 98MM
Tires- Kyosho 30 low front Marka 10 Rear +1/+3
Motor- Stock
Batteries- Kyosho Speed House
Front Springs- MR04 Stock black
T-Plate- Kyosho Carbon soft
Motor Mount- PN V4
Dampener (If applicable)- PN Disc
Dampener Fluid (If applicable)- Dry
Gearing- 8T
Notes- In under the wire! Had a great run going and then the rear wheel fell off. Had to scramble to get another started. This car can go faster but I was having problems, had been running PN KSM tires and then tonight couldn't keep it from traction rolling so I had to go back to Kyosho. Got the motor mount to try something new, this might go back to being the Pro Stock car, not sure yet. Tinkering is almost more fun than racing.
Old 09-30-2025 | 10:51 PM
  #3299
Class- Porsche Stock
Date- 9-30-25
Location- Omaha, NE
Race Time- 5:48.228
Fastest Lap- 3.964
Chassis- MR03
Body- 911 GT3
Wheelbase- 90MM
Tires- Kyosho 30 Low Marka V1 10 Slick
Motor- Stock
Batteries- Fujitsu
Front Springs- Stock
T-Plate- Kyosho 6H
Motor Mount- RM
Dampener (If applicable)- R246 Shock
Dampener Fluid (If applicable)- 100
Gearing- 7T
Notes - Tried the wide front end with 0 offset wheels and maybe like it better? Read way back into the Mini Z thread and someone recommended it so I gave it a shot. Got lucky sticking the landing on a barrel roll or two. Stay out of the wall and this car is a lot of fun to drive, just tricky!
Old 09-30-2025 | 10:56 PM
  #3300
Sadly no results for Pro Stock. Really struggled driving the Evo (MR03 5600) on the tight track. It was way more fun when I had a bigger track set up. And then tonight the motor failed. Seems like something came loose inside it? The rotor is catching on something. Don't know how often that happens but kind of sucks. I had some runs but it was a week or two ago and wasn't fast so I'm going to skip that one for now.
