Mini-96 World Challenge
#3136
Class- NARROW
Date- 06/29/2025
Location-Central Texas
Race Time- 274.340 / 4:34.340
Fastest Lap- 3.252
Chassis-MR03EVO
Body-Yaris
Wheelbase-90mm
Tires- F-PN KS Medium LH (KS1138) / R- PN KSK535 Soft
Wheels-F- 3D Disk N-0mm 19mm Blue / DXR N-0mm 20mm Gold 10spoke
Motor-PN 3500Kv
Batteries- SpeedHouse 800HV
Front Springs-Kyo Orange (soft and short) on Inner Tube Shock Set
T-Plate-Nexx #5
Motor Mount-Nexx 90/94mm MM
Dampener (If applicable)- PN DDS Gold top and Bottom springs
Gearing- 12/53 PN Ball Diff
Notes- Car is WICKID QUICK!!! I had 2 Traction Rolls, but it landed on it wheels both times, but I LOVE the disk wheels!!! NO more Super glue on the sidewalls, and TR is all but eliminated! This car is probably most fun to rip around the track! it's soo narrow it feels like you are on a much bigger track! And when you do hit a wall it reminds me of a Bomber crankbait hitting a log, give it a little slack and it pops right back off the log like it's in reverse! The Yaris acts the same way! I'm going to paint it like my all time favorite Crank Bait color "Fire Tiger"! Maybe the paint scheme will bring me luck racing the way it did when I first found the color pattern as a kid fishing!
Date- 06/29/2025
Fastest Lap- 3.252
Chassis-MR03EVO
Body-Yaris
Wheelbase-90mm
Motor-PN 3500Kv
T-Plate-Nexx #5
#3137
Class- MX-5
Date- 06/30/2025
Race Time- 282.024 / 4:42.024
Fastest Lap- 3.237
Chassis-MR03 EVO
Body-Mazda MX-5
Wheelbase-90mm
Tires-F- PN KS Soft LH (KS1134) / R- PN KS-M Soft LH
Wheels-F-3D Disk N-+1mm 20mm Blue / R- DXR MP1 W -1mm 20mm Carbon Black
Motor-PN 3500Kv V4
Batteries- Eneloop 850HV
Front Springs- PN Purple
T-Plate-Nexx #5
Motor Mount-Nexx 90/94mm RM
Dampener (If applicable)- PN DDS (Purple top/Green bottom springs)
Gearing-13/53 PN Gear Diff
Notes- Humidity fell 10% from yesterday, and cars were EDGY! I had a hard time keeping them off the wall, and the MX-5 is a work in progress, and needs work. I NEED to start keeping times all month, as I had better runs! The loose nut behind the wheel, was extra loose tonight!
Date- 06/30/2025
Fastest Lap- 3.237
Chassis-MR03 EVO
Body-Mazda MX-5
Wheelbase-90mm
Motor-PN 3500Kv V4
T-Plate-Nexx #5
#3138
Class- STOCK
Date- 06/29/2025
Race Time- 261.078 / 4:21.078
Fastest Lap- 3.128
Chassis- PN 2.5W/MR03EVO board/ 04 arms
Body-Jomurema
Wheelbase-98mm
Tires-F-PN KS Soft / R- Marka V1RR10 Soft Radials almost worn to slicks
Wheels- F-PN N+1.5mm 19mm Flanged White 6 hole / R- PN W+2mm 20mm Flanged White 6 Hole
Motor-PN 3500Kv
Front Springs-PN Purple
T-Plate-PN #3 Silver Carbon Fiber
Motor Mount-PN V3 94/98mm
Dampener (If applicable)- PN DDS ( Green top/ PN lt. purple X-Strenght bottom spring) PN Dual Spring Top Shock (Green Front/Purple Rear)
Gearing-12/53 PN Ball Diff
Notes- Car ok, me not so good! Today wasn't a good driving day for me! The walls were calling my name!
I'm so ready for July's layout with no diagonal straights!
Date- 06/29/2025
Fastest Lap- 3.128
Body-Jomurema
Wheelbase-98mm
Motor-PN 3500Kv
#3139
Class- PROSTOCK
Date- 06/29/2025
Race Time- 272.062 / 4:32.062
Fastest Lap- 3.059
Chassis- PN 2.5W/MR04EVO board/ 04 arms
Body- Mazda 787B
Wheelbase- 102mm
Tires-F- PN KSK 40* LH (KSK540) / R- PN KSK 30* (KSK2030
Wheels- F- 3D Disk Wheels +1mm 19mm Blue / R- Kyo +3mm Black BBS
Motor-PN 5500Kv Anima Sensored
Front Springs- Kyo Green
T-Plate-PN #4 Black Fiber Glass
Motor Mount-PN Multi Mount
Dampener (If applicable)- PN DDS ( Green top/ Green bottom spring) PN Dual Spring Top Shock (Silver Stock Springs)
Gearing-10/52 PN Ball Diff
Notes- Same notes on ProStock as Stock, I sucked tonight! I was actually 3 seconds faster with my ProStock as a 98mm and the Pink Jomu, but I don't have the setup notes from that run, so I'll just stick with this time. Besides I LOVE the Endurance Cars!
I have .5mm shim behind the front wheels to take up slack and add track width.
Date- 06/29/2025
Fastest Lap- 3.059
Body- Mazda 787B
Wheelbase- 102mm
#3140
Class- OPEN 2WD
Date- 06/29/2025
Race Time- 264.824 / 4:24.824
Fastest Lap- 3.162
Chassis- GL GLR
Body- Pink Jomurema (prepped for paint- no windows)
Wheelbase- 98mm
Tires-F- PN KS Medium LH (KS1138)/ R- Marka MZR-V1R05
Wheels- F- N+1mm 20mm 3D Disk wheels Blue / R- W+2mm 20mm 3D Disk wheels Black (no disk)
Motor- NHX 2500Kv
Batteries- GNB 350mAh 2S LiPO
Front Springs-Blue
T-Plate-N/A
Motor Mount-GL 98mm
Dampener (If applicable)- Short Center Shock (Blue Spring) / Yellow side springs
Dampener Fluid (If applicable)- 25K Atomic grease- Center / 15K Atomic grease- Sides
Gearing-10/53 PN Gear Diff
Notes- Put back in the Flysky GMR rx that was glitching (briefly loosing Tx signal, usually on the long sweeping turns) , as the MXO rx was bad out of the pkg, but it's being replaced. I then went to the 20mm 3D Disk wheels from 19mm wheels and a 3D front bumper and clip from a carbon fiber one and after that I drove over 3 hours with NO GLITCH!!!
Only thing I can think of was a static issue causing problems??? Anyway it works, and I'M HAPPY!!! Going to soft rears made the rear end much more planted in the turns and on power! I will try soft fronts, when I receive them, to see if it will calm down the front end a bit! My steering D/R is in the 50% range with 30%+ -Expo! FREAKIN fun car to drive!
Update after run: DAMN thing glitched again twice tonight!!!
First time it lost signal completely, needing me to shut it off and back on, killed that run. Next run it briefly glitched and went back to working, both times was in turn 5. The 3rd run went pretty smooth, besides not having any confidence in the car, and made me nervous and not near as smooth as I usually am with the GLR! Looks like i'll be trying another RX, since warranty work is going to take a month or more to get the 2 repaired/replaced I have! Maybe a DasMikro next! This is starting to get aggravating!
OH WELL, next month has to be better! It easily had a 2.9 second lap in it, I just couldn't pull it off tonight. It was a ping pong fest when I tried to up the throttle anymore!
Date- 06/29/2025
Fastest Lap- 3.162
Chassis- GL GLR
Wheelbase- 98mm
Motor- NHX 2500Kv
Front Springs-Blue
T-Plate-N/A
Motor Mount-GL 98mm
Only thing I can think of was a static issue causing problems??? Anyway it works, and I'M HAPPY!!! Going to soft rears made the rear end much more planted in the turns and on power! I will try soft fronts, when I receive them, to see if it will calm down the front end a bit! My steering D/R is in the 50% range with 30%+ -Expo! FREAKIN fun car to drive! Update after run: DAMN thing glitched again twice tonight!!!
First time it lost signal completely, needing me to shut it off and back on, killed that run. Next run it briefly glitched and went back to working, both times was in turn 5. The 3rd run went pretty smooth, besides not having any confidence in the car, and made me nervous and not near as smooth as I usually am with the GLR! Looks like i'll be trying another RX, since warranty work is going to take a month or more to get the 2 repaired/replaced I have! Maybe a DasMikro next! This is starting to get aggravating!OH WELL, next month has to be better! It easily had a 2.9 second lap in it, I just couldn't pull it off tonight. It was a ping pong fest when I tried to up the throttle anymore!
#3141
Class-Box Stock
Date-6/29/2025
Location-Central Wisconsin
Race Time-6:20.403
Fastest Lap-4.299
Chassis-MR-03 LM
Body-Sauber-Mercedes-Gruppe-C #63
Wheelbase-102mm
Tires-Kyosho low profile medium/Gekko medium
Motor-stock, silver/white can
Batteries-PN-750
Front Springs-Kyosho purple
T-Plate-stock
Motor Mount-stock
Dampener (If applicable)-stock
Gearing-7p stock rear diff, white
Notes-Pics are posted on the Mini96 facebook group (BJ Ruland)
Date-6/29/2025
Race Time-6:20.403
Fastest Lap-4.299
Chassis-MR-03 LM
Wheelbase-102mm
Batteries-PN-750
T-Plate-stock
Motor Mount-stock
#3142
Class-Open 2WD
Date-6/29/2025
Race Time-7:58:590
Fastest Lap-4.831
Chassis-Club Race Hero Racers 3d Printed Chassis
Body-Lexan,
Wheelbase-98mm
Tires-Kyosho low profile soft/Kyosho Radials 40
Motor-stock, Marka 2500KV
Batteries-350 Lipo
Front PN Reds
T-Plate-doesn't exist
Motor Mount-3d Print
Gearing-10p63d PN Ball Diff
Notes-Pics are posted on the Mini96 facebook group (BJ Ruland), this is a 3d printed chassis and drives like a drunk sailor on shore leave.
Date-6/29/2025
Race Time-7:58:590
Fastest Lap-4.831
Body-Lexan,
Wheelbase-98mm
Batteries-350 Lipo
Front PN Reds
#3143
Class- Box Stock
Date- 6-21-25
Location-Omaha, NE
Race Time- 4:41.728
Fastest Lap- 3.098
Chassis- MR04
Body- Jomurema
Wheelbase- 98MM
Tires- Kyosho 30F 20RR
Motor- Stock
Batteries- Eneloop
Front Springs- Yellow
T-Plate- Kyosho FRP 6S
Motor Mount- MM
Dampener (If applicable)- Stock
Gearing- 7T
Notes- Glad I'm done ping ponging on that diagonal straight. Car drives really well!
Date- 6-21-25
Location-Omaha, NE
Race Time- 4:41.728
Fastest Lap- 3.098
Chassis- MR04
Body- Jomurema
Wheelbase- 98MM
Motor- Stock
Batteries- Eneloop
Motor Mount- MM
Gearing- 7T
#3144
Class- Stock
Date- 6-22-25
Location- Omaha, NE
Race Time- 4:38.109
Fastest Lap- 3.089
Chassis- MR03
Body- Jomurema
Wheelbase- 98MM
Tires- Kyosho 30 F 20 RR
Motor- Stock
Batteries- Kyosho
Front Springs- Purple (MR04 front end)
T-Plate- Kyosho FRP 6M
Motor Mount- MM
Dampener (If applicable)- R246 RM (found cheap for the Porsche but this Damper is for the R246 motor mount that seems to be discontinued)
Gearing- 8T
Notes- Gotta drive better!
Date- 6-22-25
Location- Omaha, NE
Race Time- 4:38.109
Fastest Lap- 3.089
Chassis- MR03
Body- Jomurema
Wheelbase- 98MM
Motor- Stock
Batteries- Kyosho
Motor Mount- MM
Gearing- 8T
#3145
Class- Porsche
Date- 6-8-25
Location- Omaha, NE
Race Time- 5:02.172
Fastest Lap- 3.326
Chassis- MR03
Body- 911 GT3
Wheelbase- 90MM
Motor-
Batteries- Eneloop or Kyosho
Front Springs- Kyosho Yellow or Purple
T-Plate- PN 5
Motor Mount- RM
Gearing- 8T
Notes - Tried to get it faster but ended up having the cleanest run earlier on I guess. Got some new T plates stuff so hopefully next month will be better sorted.
Date- 6-8-25
Location- Omaha, NE
Race Time- 5:02.172
Fastest Lap- 3.326
Chassis- MR03
Body- 911 GT3
Wheelbase- 90MM
Motor-
T-Plate- PN 5
Motor Mount- RM
Gearing- 8T
#3146
I had ordered a brushed XSpeed motor to try and found it a handful swapped into my Stock car on the challenge track. I had disassembled the track to go back to a faster three tile wide setup and decided to try the XSpeed motor again and got the setup changed up a bit but was running out of rear grip. Decided to swap it into my LM mount and get the Toyota GT-One body going again and it drove so well with the extra power, that is how that car should have came from Kyosho! Might have to try that one, even if it requires some swapping to try another class. Kind of fun to stretch cars into different classes/configurations with some tinkering,
#3147
Class- BOX STOCK
Date- 06/30/2025
Location- Lake Forest, CA
Race Time- 4:15.21 / 255.21
Fastest Lap- 3.06
Chassis- Kyosho MR03 Rwd
Body- Vett C8R
Wheelbase- 98mm
Tires- FR +1 PN KSM Med / RR +3 (Marka V1 10* radial)
Wheels- Atomic disc 20mm +1/ Stock Kyosho 20mm +3
Motor- Stock Silver Can
Batteries- Powerowl 1000 mAh
Front Springs- Kyosho Red
T-Plate- PN #4 Carbon
Motor Mount- MM2
Dampener Fluid (If applicable)- Tamiya AW Grease on shock shaft
Gearing- 7T Pinion (PN Pro Match) / Stock Differential (44T)
Notes- Kingpin Flip, Car drives easy and has the best rotation amongst all my cars no matter what tire combo I use. It might be the MM2 pod generating good inertia in the corner but it definitely has enough steering to spare for an MR-03.
Date- 06/30/2025
Fastest Lap- 3.06
Body- Vett C8R
Wheelbase- 98mm
Motor Mount- MM2
#3148
Class- STOCK
Date- 06/30/2025
Race Time- 4:20.23 / 260.23
Fastest Lap- 2.92
Chassis- PN2.5 MR03 Rwd
Body- Jomu
Wheelbase- 98mm
Tires- FR +1 PN KSK40 / RR +3 (Gekko Slick Soft)
Wheels- Nexx disc 20mm +1/ Flanged 20mm +3
Motor- PN 3500 kV
Front Springs- PN Red
T-Plate- PN #5 FRP
Motor Mount- Nexx LCG
Dampener (If applicable)- Nexx damper and dual spring shock
Dampener Fluid (If applicable)- Dry
Gearing- 16T Pinion 53 spur PNWC Spec
Notes: Fighting pushing and oversteer no matter setup until I changed to the front tires to KSK 40 and Gekko Soft Slick. Originally I had PN KS medium and Marka V1 15
Date- 06/30/2025
Fastest Lap- 2.92
Body- Jomu
Wheelbase- 98mm
Motor- PN 3500 kV
T-Plate- PN #5 FRP
#3149
Class- PRO STOCK
Date- 06/30/2025
Race Time- 4:22.88 / 262.88
Fastest Lap- 2.82
Body- Jomu
Wheelbase- 98mm
Wheels- Nexx disc 20mm +1/ Stock Kyosho 20mm +3
Motor- Kyosho Xspeed
T-Plate- PN #5 Carbon
Motor Mount- Stock MM
Gearing- 6T Pinion / Stock Differential (44T)
Notes- Kingpin Flip, Very easy to drive fast but need to get used to the torque and continue adjusting the throttle with lots of practice and radio settings. Over shooting was keeping my runs inconsistent even at 84% throttle.
Date- 06/30/2025
Fastest Lap- 2.82
Body- Jomu
Wheelbase- 98mm
#3150
I had the same issue with the Xspeed being too much motor for the smaller M96 track. What I did that helped was turn down the Throttle DR to 70% and made driving so much easier. When you feel comfortable you can increase it back to 100% when ready or just leave it and run a clean 75 lapper. I found with faster classes, slower is faster bc I overshoot everything on this tight layout.
3035Likes
