Mini-96 World Challenge
#3256
Class-Open 2wd
Date-9/01/25
Location-Central Wisconsin
Race Time-7:24.337---444.337
Fastest Lap-5.2187
Chassis-Atomic MRZ-SF
Body-Jomura
Wheelbase-98mm
Tires-F-PN Mediums, R-Gekko Mediums
Motor-2500KV
Batteries-350mah 7.4
Front Springs-Atomic Green
T-Plate-
Motor Mount-Stock Atomic
Dampener (If applicable)-Atomic
Dampener Fluid (If applicable)-25000
Gearing-10/53
Notes, I backed off the throttle to 60% this month and focused on consistency, it showed with a lower over all time. Adding some drag brake helped keep the car balanced since braking too much myself was unsettling the car. Photo proof of the run will be on the facebook pages since i cannot post photos yet.
Date-9/01/25
Fastest Lap-5.2187
Body-Jomura
Wheelbase-98mm
Motor-2500KV
T-Plate-
Gearing-10/53
#3258
Well got to do about 947 laps between the two cars over the past 3 days. Being new to the whole thing only a couple weeks old worked on trying to keep a nice consistent flow. Each time I have been able to get better and working to see where I can get too. Figure over time it will come and get faster but happy with putting up my first month of number. Will soon look to ask some questions on building a touring car as I want to run that at the local track and in this.
Lastly trying to find a timing system that I like am torn between Next Level Timing and Live Time. I like the fact that I can close out the session but you can look up the track and see all the races that have been ran to try and get the times down but hate there is a monthly fee. I like Next level Timing but hate I can not delete something where I mess up just starting a race that is never ran.
As for the timing system I use EasyLap hardware and Next Level Timing software. NLT is good, and getting better. It's a easy setup to use, but Live Time seems to be a bit more configurable while not overly complicated like Z Round. I didn't understand timing systems when I bought mine, but you need to decide on what timing software you like, then buy the hardware that works with it! Since you plan on racing at Houston RC too, ya might want to check what they run, to save yourself issues down the road!
#3259
Class - Box Stock
Date - 9/1/2025
Location - Iowa
Race Time - 376.944
Fastest Lap - 4.409
Chassis - MR-04 MM
Body - McLaren 12C
Wheelbase - 98mmTires - PN KS Medium on 20mm F1 flanged wheels, 0.5mm shim, no tape / Marka 15° Radials R2 wheels
Motor - Stock
Batteries - Kyosho 800
Front Springs - Kyosho Softest
T-Plate - Kyosho Carbon Firm
Motor Mount - Stock
Dampener (If applicable) -
Dampener Fluid (If applicable) -
Gearing - 7T, stock diff
Notes: Can't get myself excited to put laps on this layout.
Date - 9/1/2025
Location - Iowa
Race Time - 376.944
Fastest Lap - 4.409
Chassis - MR-04 MM
Body - McLaren 12C
Motor - Stock
Motor Mount - Stock
#3260
Class - Pro Stock
Date - 9/1/2025
Location - Iowa
Race Time - 363.456
Fastest Lap - 4.229
Chassis - MR-04 MM Evo2
Body - McLaren 12C
Wheelbase - 98mm
Tires - PN KS Medium on 20mm F1.5 flanged wheels, no tape / Marka 15° Radials R2 wheels
Motor - Kyosho Black Cap
Front Springs - Stock
T-Plate - Kyosho White Fiber Firm
Motor Mount - Stock
Dampener (If applicable) - Kyosho Oil Damper
Dampener Fluid (If applicable) - Stock
Gearing - 9T, ball diff
Notes: Not my type of layout.
Date - 9/1/2025
Location - Iowa
Race Time - 363.456
Fastest Lap - 4.229
Body - McLaren 12C
Wheelbase - 98mm
Motor Mount - Stock
#3261
Date-09-01-2025
Location- Wisconsin
Race Time-358.425
Fastest Lap- 4.439
Chassis-MR-04
Body- Corvette C8
Wheelbase-98mm
Rear Marka 10
Front PN KSM Med LP slick
Motor-Stock
Batteries- Silver Horse 900
T plate- Kyosho Carbon
Front springs- purple
Location- Wisconsin
Race Time-358.425
Fastest Lap- 4.439
Chassis-MR-04
Body- Corvette C8
Wheelbase-98mm
Rear Marka 10
Motor-Stock
#3262
Class - 90mm Narrow MX-5 Miata Unofficial Experimental Class
Date - 8/1/25
Location - Iowa
Race Time - 396.624
Fastest Lap - 4.527
Chassis - MR-03 RM
Body - MX5 Roadster
Wheelbase - 90mm
Tires - PN KS Medium / PN KS Soft
Wheels - 0 Offset Flanged Narrows x4
Motor - Stock
Batteries - Orion 750 SHO
Front Springs - PN Super Soft Blue
T-Plate - Kyosho FRP 5S
Motor Mount - Stock
Notes -
Date - 8/1/25
Location - Iowa
Race Time - 396.624
Fastest Lap - 4.527
Chassis - MR-03 RM
Body - MX5 Roadster
Wheelbase - 90mm
Motor - Stock
Motor Mount - Stock
Notes -
#3263
Spent the last day I had to run messing with a new car I got. Turns out the MM2 mount doesn't fit under any of my bodies, but the Evo was cheap and my first brushless! Had just a few runs this month (nothing close to last month's times) but they were a while ago and I'm not sure I want to dig through all my times because I didn't take any pictures so on to next month.
#3265
Box Stock
Class- BOX STOCK
Date- 09/01/2025
Location- Lake Forest, CA
Race Time- 5:22.37 / 322.37
Fastest Lap- 4.07
Chassis- Kyosho MR03 Rwd
Body- Vett C8R
Wheelbase- 98mm
Tires- +1 PN KS Hard/ +3 Gekko soft slick RS3
Wheels- Nexx 20mm/ Discs +1/ Reflex 20mm +3
Motor- Stock Silver Can
Batteries- Powerowl Pro 1100 mAh
Front Springs- Kyosho Red
T-Plate- PN #4 Carbon
Motor Mount- MM2
Dampener (If applicable)- No
Dampener Fluid (If applicable)- Tamiya AW grease on upper shock
Gearing- 7T Pinion (PN Pro Match) / Stock Differential (44T)
Note- Kingpin flip mod, AE black grease inside gear diff to slow down action
Car was very easy to drive. Rotated well. Low humidity helped on this run
Class- BOX STOCK
Date- 09/01/2025
Fastest Lap- 4.07
Body- Vett C8R
Wheelbase- 98mm
Motor Mount- MM2
#3266
Stock AAA 3500 (PNWC)
Class- Stock AAA (PNWC SPEC)
Date- 08/13/2025
Race Time- 5:17.13 / 317.13
Fastest Lap- 3.81
Chassis- PN2.5 MR03 RWD
Body- Jomu
Wheelbase- 98mm
Tires- FR +1 PN KSK40 / RR +3 (Gekko Slick Soft RS3)
Wheels- Nexx / disc 20mm +1/ Reflex 20mm +3
Motor- PN 3500 kV
Batteries- Powerowl 1100 mAh
T-Plate- Kyosho Carbon #5
Motor Mount- Nexx LCG
Dampener (If applicable)- Nexx damper and dual spring shock
Dampener Fluid (If applicable)- Dry
Gearing- 16T Pinion 53 spur PNWC Spec, NEXX Light Weight Ball Diff
Notes:
Didn't have enough time this month to give this car a good CCW run. I ran smaller discs taht even exposes little rubber since the KSK40 front tires are getting thinner 21.90mm currently.This care reacted the most when I wiped down the track.
Date- 08/13/2025
Fastest Lap- 3.81
Body- Jomu
Wheelbase- 98mm
Motor- PN 3500 kV
Notes:
#3267
Super Stock
Class- Super Stock (Kyosho Xspeed)
Date- 08/30/2025
Race Time- 5:17.34 / 317.34
Fastest Lap- 3.89
Body- Jomu
Wheelbase- 98mm
Tires- FR Gekko MAX Med / RR Gekko Slick Soft RS3
Wheels- Nexx disc 20mm +1/ Stock Kyosho 20mm +3
Motor- Kyosho Xspeed
Front Springs- PN Blue Soft
T-Plate- PN #5 FRP
Motor Mount- PN 94-98 V2
Dampener (If applicable)- Nexx, Stock Kysoho Top Shock
Gearing- 7T Pinion / Stock Differential (44T)
Notes: Going back and forth testing the MR04 front conversion and back to MR03. Front is too aggressive and I need to tune some major oversteer out of the car. Second off pace with CW car. Didn't have enough time to run this car along with my Mod 2WD car.
Date- 08/30/2025
Fastest Lap- 3.89
Body- Jomu
Wheelbase- 98mm
T-Plate- PN #5 FRP
#3268
Welcome to another Texas boy!!! MAN, I'm jealous you have a GREAT Local track and 1/28th scale rc shop in your back yard!!! You should be able to post pics here in 10 posts or so. Feel free to holler with any questions Ya have. Great folks here and always happy to help! Welcome to the Fold!
Yea Houston Rc got me set yo for sure and working to get out to one of the events they put on. Trying to practice at home so I do not embarrass myself. I think the next thing i am looking at is doing a touring build. Got to do more research but no clue where to start.
#3269
It's more complicated now than ever bc there are so many good options out there. Now we have Associated RC28R in the mix. I would go with one that is supported the most at Houston RC or what is easier for you to figure out and get parts. For me the MRX and Reflex racing is the most supported in my local area so I tend to lean towards those for parts support as well. Just do some research and you will find the right one within your checklist.
#3270
Class- BOXSTOCK
Date- 08/29/2025
Location- Central Texas
Race Time- 341.558 / 5:41.558
Fastest Lap- 4.196
Chassis- MR04
Body- Audi R8
Wheelbase-98mm
Tires- F-PN KSM Medium LH / R- Marka V1R10
Wheels- F- N +1mm 20mm Kyo Blk Enzo wheels / R- W +3mm 20mm 3D wheels
Motor- Kyo Stock
Batteries- SpeedHouse 800HV
Front Springs- PN Purple
T-Plate-Kyo #5 Soft Fiberglass
Motor Mount-Kyo Stock MM
Dampener (If applicable)- Kyo Spring shock (Yellow Spring)
Dampener Fluid (If applicable)- Atomic 25k grease
Gearing-7/44 Kyo Gear Diff- Ruby Lube packed
Notes- MR-04 Ready Set with Reflex 0* Aluminum Knuckles, and I removed the thermal switch from the motor, as it was a PIA to get the top cover back on after cleaning the motor!
Running OK, but HOPEFULLY new batteries will help with the lack of power.
Date- 08/29/2025
Fastest Lap- 4.196
Chassis- MR04
Body- Audi R8
Wheelbase-98mm
Motor- Kyo Stock
3036Likes
