Mini-96 World Challenge
#3436
This is my first run with my ProStock with a 12C body, and it was pretty good. I have been running and tweaking in my new MRX ME, but just felt like driving my ProStock this morning. I've hit a 3.315 fast lap with my MRX ME, so the ProStock time was pretty close, but where I can run 3.4xx laps pretty easy with my MRX ME 3.5xx's is where the prostock is running.
I'm thinking a 4:20.xxx is going to be a GREAT CLEAN run for this layout, BUT i doubt it will be me to hit it!
With all the new fast guys and the Old Dogs getting time to run, I think we will have some close driving this month!!!
Have fun Yall, and drive fast! Drew
With all the new fast guys and the Old Dogs getting time to run, I think we will have some close driving this month!!! Have fun Yall, and drive fast! Drew
#3437
Class- Box Stock
Date- 1-20-25
Location-Omaha, NE
Race Time- 4:13.910 or 253.910
Fastest Lap- 3.167
Chassis- MR04
Body- Audi R8 LMS
Wheelbase- 98MM
Tires- Front PN KSK 40 +1 offset Rear Marka V1R15 +3 offset
Motor- Stock
Batteries- Gens Ace
Front Springs- Stock
T-Plate- Kyosho FRP 6M
Motor Mount- MM
Dampener (If applicable)- Stock
Dampener Fluid (If applicable)- 15k Kyosho
Gearing- 7T
Notes- Did a lot of runs and just kept chopping away at the times. Track got faster and faster! Ran the 12C body for most of the runs but switched back to the R8 and had a few good runs, car was fast and handled really well.
Date- 1-20-25
Location-Omaha, NE
Fastest Lap- 3.167
Chassis- MR04
Body- Audi R8 LMS
Wheelbase- 98MM
Motor- Stock
Batteries- Gens Ace
Motor Mount- MM
Gearing- 7T
#3438
Class- Stock
Date-1-24-25
Location-Omaha, NE
Race Time- 4:04.193 or 244.193
Fastest Lap- 3.060
Chassis- PN2.5 (MR04 front end)
Body- Jomurema with lexan roof
Wheelbase- 98MM
Tires- Front: PN KSK 40 offset +1 Rear: Marka V1R15 +3
Motor- PN V4 3500kv
Batteries- Gens Ace
Front Springs- Green
T-Plate- Kyosho Carbon Soft
Motor Mount- PN V4
Dampener (If applicable)- PN disc (both springs green), no top shock
Dampener Fluid (If applicable)- Dry
Gearing- 14/53 Nexx lightweight ball diff
Notes- I think this is my favorite to drive, and again kept chopping away at my best times. Discs had to be dialed in to avoid traction rolling but with the PN tires it stayed aggressive. Haven't done much to this car but try different combinations of tires.
Date-1-24-25
Location-Omaha, NE
Fastest Lap- 3.060
Wheelbase- 98MM
Motor- PN V4 3500kv
Batteries- Gens Ace
Motor Mount- PN V4
#3439
Class- Pro Stock
Date- 1-26-25
Location- Omaha, NE
Race Time- 4:00.955 or 240.955
Fastest Lap- 3.063
Chassis- PN 2.5 (MR04 front end)
Wheelbase- 98
Tires- PN KSM medium front Marka V1RR15 (mostly slicks now) rear +1/+3 offsets
Motor- Kyosho XSpeed Black cap
Batteries- Gens Ace
Front Springs- Orange
Motor Mount- MR04 MM
Dampener (If applicable)- PN Disc (Green bottom Blue top springs)
Dampener Fluid (If applicable)- Mostly dry (Kyosho 5k)
Gearing- 8T
Notes - Kyosho 0.5 knuckles. Got this car running again and it was fast! Just a bit easier to drive than my Evo I had been running in Pro Stock. Fresh motor and the right tires helped me lay down a really consistent run.
Date- 1-26-25
Location- Omaha, NE
Fastest Lap- 3.063
Wheelbase- 98
Batteries- Gens Ace
Gearing- 8T
#3440
Class- Porsche Stock
Date- 1-20-25
Location- Omaha, NE
Race Time- 4:26.349 or 266.349
Fastest Lap- 3.291
Chassis- MR03 (MR04 Front end with Kyosho 0.5 knuckles)
Body- 911 GT3
Wheelbase- 90MM
Tires- Front PN KSK 40 0 offset Rear Marka V1R10 0 offset
Motor- Stock white cap
Batteries- Gens Ace
T-Plate- PN Carbon #5
Motor Mount- RM
Dampener (If applicable)- Oil Shock
Dampener Fluid (If applicable)- 100
Gearing- 7T
Notes - This one was a handful to get a clean run. Tried some 0 offset Reflex wheels up front with discs and got way more responsive steering with only the occasional roll on an over correction. Just had to stay off of the apexes because bouncing off one would send me nose first into the wall on the other side of the track. New resin balls in the lower arms seemed to make turning smoother. Still thinking about trying my Evo (with 4100 motor) as my Porsche chassis, maybe next month.
Date- 1-20-25
Location- Omaha, NE
Fastest Lap- 3.291
Body- 911 GT3
Wheelbase- 90MM
Batteries- Gens Ace
Motor Mount- RM
Gearing- 7T
#3441
Class-Box Stock
Date-1/25/2026
Location-Central NC
Race Time-4:29.904 or 269.904
Fastest Lap-3.386
Chassis-MR-03 FHSS
Body-2012 NSX
Wheelbase-98mm
Tires-PN KS Med fronts, New Marka V1R15 rears
Motor-Stock
Batteries-GensAce 750s
Front Springs-Stock
T-Plate-Reflex G10 Medium
Motor Mount-Stock MM
Dampener (If applicable)-None
Notes-This, my regular Box Stock car ended up being the quickest of the 3 I tried, including a new MR-04 that was 5 seconds slower. Even though I tried the MR-04 MM mount on this MR-03, it was still quicker with the MR-03 MM mount. I did change the t-plate and went back to stock front springs to try to reduce the rear hopping and lifting the inside rear and found the PN KS Medium fronts were better than the KSK 40s I'd been running. This was the most consistent Box Stock run I had at 95.66%, so there is room for improvement. I just wasted too much time running other cars that have been sitting on the shelf and trying to get the MR-04 working, but failed. Pretty frustrating month overall, and I'm missing being retired so I have more time to Mini-Z.
Date-1/25/2026
Location-Central NC
Fastest Lap-3.386
Chassis-MR-03 FHSS
Body-2012 NSX
Wheelbase-98mm
Motor-Stock
Front Springs-Stock
#3442
Class-Porsche Cup Class
Date-1/17/2026
Location-Central, NC
Race Time-4:32.769 or 272.769
Fastest Lap-3.400
Chassis-MR-03 EVO
Body-911 GT3
Wheelbase-90mm
Tires-PN KS Soft on PN 19mm +0.5 fronts, Marka v1R10 on PN 19mm W0 rears (not pictured)
Motor-ATM 3500
Front Springs-Kyosho Stock
T-Plate-GT55 +0.6 FRP #4
Motor Mount-Nexx Round RM
Dampener (If applicable)-PN G10 DDS and Kyosho Inner Tube Shock MZW442
Gearing-PN 64p 13/53 Ball diff
Notes-This car is super quick and fun, but a challenge to drive consistently. I only had tree tries this month, but this was a pretty good run at 92.98% consistency.
Date-1/17/2026
Fastest Lap-3.400
Chassis-MR-03 EVO
Body-911 GT3
Wheelbase-90mm
Motor-ATM 3500
#3443
Class-90mm Narrow MX-5 Miata Unofficial Experimental Class
Date-1/17/2026
Race Time-4:46.793 or 286.793
Fastest Lap-3.653
Chassis-MR-03 FHSS
Body-Mazda MX-5
Wheelbase-90mm
Tires-PN KSK 40 LH fronts, PN KS Soft rears (20mm 0 offset flanged wheels all around)
Motor-Stock
Batteries-Carreras 850s
Front Springs-PN Super Soft Blue
T-Plate-Kyosho Soft Fiberglass RM
Motor Mount-Stock RM
Dampener (If applicable)-N/A
Gearing-7/44 Gear diff
Notes-This car is super light, but very stable and is one of the funnest to drive and watch going around the track! It runs great on both Narrow and Wide rears with no setup changes. Only 2 tries this month, but this 95.55% consistency good for me, but car feels really slow. May need a different motor.
Date-1/17/2026
Fastest Lap-3.653
Chassis-MR-03 FHSS
Body-Mazda MX-5
Wheelbase-90mm
Motor-Stock
#3444
Class-90mm Narrow Stock
Date-1/17/2026
Race Time-4:37.829 or 277.829
Fastest Lap-3.533
Chassis-MR-03 ASF
Body-Toyota GRMN Yaris
Wheelbase-90mm
Motor-ATM 70T
Front Springs-PN Green
T-Plate-PN #3 Spring Steel
Motor Mount-PN MR9094 90mm
Dampener (If applicable)-PN Integrated with dual spring center shock
Gearing-9/44 Gear diff
Notes-It is a very stable body and fun to watch rip around the track. No changes, but only had a couple of tries.
Date-1/17/2026
Fastest Lap-3.533
Chassis-MR-03 ASF
Wheelbase-90mm
Motor-ATM 70T
#3445
Class-Stock PNR 3500kv
Date-1/24/2026
Race Time-4:09.318 or 249.318
Fastest Lap-3.158
Chassis-PNR2.5W
Body-Jomurema with PN Lexan Roof
Wheelbase-98mm
Tires-PN KS Firm fronts, Marka V1RR15 Radial rears
Motor-PN v4 3500vkv
Front Springs-PN AA Yellow
T-Plate-Kyosho FRP 0.5 Medium
Motor Mount-PN 98mm v5
Gearing-PN 64p 16/53 Ball diff
Notes-Pinion still 16t for local club race. Was only able to hit 94.3% consistency this month.
Date-1/24/2026
Fastest Lap-3.158
Chassis-PNR2.5W
Wheelbase-98mm
Motor-PN v4 3500vkv
#3446
Class-Pro Stock GT
Date-1/22/2026
Race Time-4:17.538 or 257.538
Fastest Lap-3.198
Chassis-MR-03 EVO
Body-Ferrari 458 Italia
Wheelbase-98mm
Tires-PN KS Firm on RTRC 19mm +1 fronts, Marka V1R10 rears
Motor-Kyosho XSpeed
T-Plate-Kyosho CF Medium
Motor Mount-R246-1355 One Piece Motor Mount
Dampener (If applicable)-Kyosho DDS
Gearing-PN 64p 10/51 Ball diff
Notes-This 458 body has great balance and I only run it at home because it’s rare. Only a couple of runs this month, but discovered brushes were almost completely worn out after 5+ years, so had to changed motors. Still couldn't beat my best Stock time and only 91.29% consistency.
Date-1/22/2026
Fastest Lap-3.198
Chassis-MR-03 EVO
Wheelbase-98mm
Motor-Kyosho XSpeed
#3447
Class-Open 4WD
Date-1/24/2026
Race Time-4:59.374 or 299.374
Fastest Lap-3.783
Chassis-Kyosho MA-020 AWD
Body-Subaru Impreza
Wheelbase-94mm
Tires-PN KS Soft on N1.5 fronts, Marka V1R10 on W0 rears
Motor-Stock
Batteries-AmazonBasics 800s
Front Springs-Stock
T-Plate-N/A
Motor Mount-N/A
Gearing-Stock
Notes-This car has been sitting on the shelf for another 2 years since I last drove it. It is bone stock other than tires. It feels slow and clunky compared to the 2WD cars and I can't say I enjoy driving it yet, but my goal was to drive all 24 cars this month.
Date-1/24/2026
Fastest Lap-3.783
Body-Subaru Impreza
Wheelbase-94mm
Motor-Stock
Front Springs-Stock
T-Plate-N/A
Motor Mount-N/A
Gearing-Stock
#3448
Class- Box Stock
Date- 1/31/2026
Location- Irvine, CA
Race Time- 4:28.584 / 268.584
Fastest Lap- 3.322
Chassis- Kyosho MR04 Rwd
Body- Audi R8 LMS
Wheelbase- 98mm
Tires- FR (PN KSM538) / RR (Marka MZRV1R10)
Wheels- 3D 20mm F0 22.6 Disc/ 3D 20mm R2
Motor- Stock Silver Can
Batteries- PN Racing 900 mAh
Front Springs- AMA Silver
T-Plate- PN #4 Spring Steel
Motor Mount- Stock MM
Dampener (If applicable)- Stock Center Shock
Gearing- 7T Pinion (PN Pro Match) / Stock Differential (44T)
Notes- KT-531P TX , Had 4:25 pace most runs just couldn't get a run without 2 or more "bad" laps...
Date- 1/31/2026
Fastest Lap- 3.322
Body- Audi R8 LMS
Wheelbase- 98mm
#3449
Class- Stock
Date- 1/31/2026
Race Time- 4:32.106 / 272.106
Fastest Lap- 3.380
Chassis- Kyosho MR03 EVO
Body- Jomurema GT01 (Lexan Roof)
Wheelbase- 98mm
Tires- FR (Marka MZR-V5F25) / RR (Gekko RS2 GK-005)
Wheels- 3D 20mm F0 23.0 Disc/ 3D 20mm R2
Motor- PN 3500kv V3.1
Front Springs- PN Soft Blue
Motor Mount- PN Racing V5 (AMA+)
Dampener (If applicable)- AE Damper Tube
Dampener Fluid (If applicable)- 30K
Center Shock- AE Center Shock White Spring 45K
Gearing- 16T Pinion (PNWC) / Stock MR03 Gear Diff with 64P Spur Mod (53T)
Notes- Need more steering had to stab the brakes to get around the 180°
Date- 1/31/2026
Fastest Lap- 3.380
Wheelbase- 98mm
#3450
Class- Open 2wd
Date- 1/31/2026
Race Time- 4:16.235 / 256.235
Fastest Lap- 3.138
Chassis- Associated RC28R
Wheelbase- 98mm
Wheels- 3D 20mm F0 / 3D 20mm R2
Motor- Rocket 2500kv
Batteries- Reedy 400mah LiPo
Front Springs- AE Blue
Front Shock Fluid- N/A
T-Plate- N/A
Motor Mount- Stock
Dampener (If applicable)- Stock Center Shock AE White Spring
Dampener Fluid (If applicable)- 45K
Side Shock Spring- AE Med Torsion Bar
Side Dampener Fluid- 30K
Gearing- 13T Pinion / Stock AE Gear Differential (53T)
Notes- ESC in "Blinky" zero-timing mode.
Date- 1/31/2026
Fastest Lap- 3.138
Wheelbase- 98mm
T-Plate- N/A
Motor Mount- Stock
3036Likes
