Mini-96 World Challenge
#3421
Class- Porsche Stock
Date- 12-22-25
Location- Omaha, NE
Race Time- 4:10.146
Fastest Lap- 3.146
Chassis- MR03
Body- 911 GT3
Wheelbase- 90MM
Tires- Kyosho 30 Low Marka V1 10 Slick (PN F1 19mm +1 Front/Reflex 0 rear)
Motor- Stock white cap
Batteries- Kyosho Speed House
Front Springs- Green
T-Plate- Kyosho 6M
Motor Mount- RM
Dampener (If applicable)- Oil Shock
Dampener Fluid (If applicable)- 100
Gearing- 8T (Kyosho ball diff)
Notes - I actually spent a long time on this car for some reason, just wanted to get more speed out of it but might need to order another stock motor or two. Got it to handle pretty well, was really struggling with lazy turn in and getting it to go around the roundabout with any consistency was a challenge. Might swap this for another car and try to run a Evo Chassis/4100 green motor next month.
Date- 12-22-25
Location- Omaha, NE
Race Time- 4:10.146
Fastest Lap- 3.146
Chassis- MR03
Body- 911 GT3
Wheelbase- 90MM
T-Plate- Kyosho 6M
Motor Mount- RM
#3422
Mini96 December Results
December was a busy month! So much going on so it was hard to find time to run. But towards the end of the month I put in a charge. Both cars had pretty good pace. Seems like I can go faster on CCW layouts. Box stock time improved by 4 secs over Nov. I had a wicked pace in Open but could not put it together for a good overall. Cars felt pretty good just need to focus better. The laps were so fast. For a bit I was struggling to get into the 2.9s in BS because I’m running some old batteries and motor. So I went from KSK40s to KSM 542s and was able to get a few 2.9s. In a few weeks I’ll be down in SoCal and I’ll get some fresh batteries and rubber. This was my first full month with the DAS wheel. It is good just need to keep getting used to how it feels. Love how this group pushes each other. Not sure if I’m making the podium this month. Just makes me wanna work harder!
Class- 2WD Open
Date- 11/7/25 to
Location- Elk Grove, CA
Race Time- 75/3:43.097
Fastest Lap- 2.698
Chassis- Reflex RX28 Gen2
Body- Rad Body
Wheelbase- 98mm
Tires- PN KSM Med F Marka V1 15deg Radial
Motor- HobbyWing 3500kv
Batteries- MWX 340mah Lipo
T-Plate- N/A
Motor Mount- Kit under
Dampener (If applicable)- Kit
Dampener Fluid (If applicable)- 30k Kyo
Gearing- PN-53/13
Notes- 50degrees with 73% humidity.
Class- Box Stock
Date- 12/26/25
Race Time- 75/3:54.168
Fastest Lap- 2.954
Chassis- MR03 Readyset
Body- 12C
Wheelbase- 98mm
Tires- PN KSM542 F / Marka V1 15deg R
Motor- Kyosho Stock
Batteries- Carrera F850
Front Springs- Kyosho Red
T-Plate- Spring Steel #4
Motor Mount- #7
Dampener (If applicable)- Stock
Dampener Fluid (If applicable)- Kyosho 30K
Gearing- 7T
Notes- Front Knuckles had 2x shims under to lower the ride height. Front tires have 22.6 Reflex rings. Batteries charged @ 1.5 amps. 60 degrees in garage with 73% humidity.
Class- 2WD Open
Date- 11/7/25 to
Fastest Lap- 2.698
Body- Rad Body
Wheelbase- 98mm
T-Plate- N/A
Gearing- PN-53/13
Class- Box Stock
Date- 12/26/25
Fastest Lap- 2.954
Body- 12C
Wheelbase- 98mm
Motor- Kyosho Stock
Motor Mount- #7
Gearing- 7T
#3423
Box Stock
Date 12/4/2025
Location- California
Race Time-245.84
Fastest Lap-3.05
Chassis-MR-04
Body- 720s
Wheelbase-98mm
Rear Marka 15 +2mm
Front PN medium slick +0
Motor-Stock
T plate PN #4 steel
Front springs PN purple (soft)
This was just a base line run early in the month but never had time to make more box stock runs
Date 12/4/2025
Race Time-245.84
Fastest Lap-3.05
Chassis-MR-04
Body- 720s
Wheelbase-98mm
Rear Marka 15 +2mm
Motor-Stock
T plate PN #4 steel
#3424
Stock
Date-12/28/2025
Race Time-232.60
Fastest Lap-2.86
Chassis-PN2.5
Body- Jer
Wheelbase-98mm
Tires- R Marka 15 radials +2mm F PN KS medium slick +1mm
Motor-PN 3500KV
This is a brand new stock build with the Reflex pod and I only had a few hours to tune it and get my run for the month. Car wound up driving great but after taking a few weeks off this was the best I could do.
Date-12/28/2025
Race Time-232.60
Fastest Lap-2.86
Chassis-PN2.5
Body- Jer
Wheelbase-98mm
Motor-PN 3500KV
#3425
Pro Stock
Date-12/7/2025
Race Time-242.40
Fastest Lap-2.82
Chassis-MR-04 Evo2
Body- Jer
Wheelbase-98mm
Tires- R Marka 15 +2mm F PN KSk 40 slick +0mm
Motor-Koyosho 5600KV
Early month baseline run I never had to to improve
Date-12/7/2025
Race Time-242.40
Fastest Lap-2.82
Chassis-MR-04 Evo2
Body- Jer
Wheelbase-98mm
#3426
2wd open
Date- 12/2/2025
Location- Northern California
Race Time-236.26
Fastest Lap-2.91
Chassis-MRX ME
Body- Jer
Wheelbase-98mm
Tires- F unknown slicks Med R unknown radials
Motor-3500KV GL
Batteries- 2S lipo
Another early base line run I never had time to improve
Date- 12/2/2025
Race Time-236.26
Fastest Lap-2.91
Chassis-MRX ME
Body- Jer
Wheelbase-98mm
Motor-3500KV GL
Batteries- 2S lipo
#3427
Only ran one class this month due to busy holiday schedule. This was a fun layout that needs more wheel time to achieve max consistency.
Class- BOX STOCK
Date- 12/17/2025
Location- Lake Forest, CA
Race Time- 3:59.17 / 239.17
Fastest Lap- 2.83
Chassis- MR03
Body- C8 Vette
Wheelbase- 98mm
Tires- +1 PN KSK 40 / +3 Marka 10 Slick
Wheels- Nexx 20mm/ Discs +1/ AMA Racing +3
Motor- Stock Silver Can
Batteries- PN 900
Front Springs- PN Blue - Stiff
T-Plate- PN #4 Carbon
Motor Mount- MM2
Dampener (If applicable)- No
Dampener Fluid (If applicable)- Tamiya AW grease on upper shock
Gearing- 7T Pinion (PN Pro Match) / Stock Differential (44T)
Note- Kingpin flip mod, AE anti wear grease inside gear diff to slow down action. MR04 front conversion
Class- BOX STOCK
Date- 12/17/2025
Fastest Lap- 2.83
Chassis- MR03
Body- C8 Vette
Wheelbase- 98mm
Batteries- PN 900
Motor Mount- MM2
#3428
Class-BOXSTOCK
Date- 12/19/24
Location-Central Texas
Race Time- 3:56.726 / 236.726
Fastest Lap- 2.943
Chassis-MR04
Body-McLaren 720S GT3
Wheelbase-98mm
Tires- F-PN KS Medium LH / R-Marka V1R10
Wheels- F- N +1mm 20mm PN White Dish / R- +2mm 20mm 3D black no disk
Motor- Kyo Stock
Batteries- GensAce 750HV
Front Springs-Purple
T-Plate-Pn #2 Spring Steel
Motor Mount-Kyo Stock MM
Dampener (If applicable)- Kyo Spring shock (Red Spring)
Dampener Fluid (If applicable)- Kyosho 15k grease
Gearing-7/44 Kyo Gear Diff
Notes-
Date- 12/19/24
Fastest Lap- 2.943
Chassis-MR04
Wheelbase-98mm
Motor- Kyo Stock
Notes-
#3429
Class- STOCK
Date- 12/11/2025
Race Time- 3:57.205 / 237.205
Fastest Lap- 2.775
Chassis- PN 2.5W/MR03EVO board/ 04 arms
Body-Jomurema Pink w/ Lexan roof and wing
Wheelbase-98mm
Tires-F-PN KS Soft / R- Marka V1R10
Wheels- F-PN N+1.5mm 19mm Flanged White 6 hole / R- PN W+2mm 20mm Yellow BBS
Motor-PN 3500Kv
Front Springs-PN Purple
T-Plate-PN #3 Silver Carbon Fiber
Motor Mount-PN V3 94/98mm
Dampener (If applicable)- PN DDS ( Green top/ PN lt. purple X-Strenght bottom spring) PN Dual Spring Top Shock (Green Front/Purple Rear)
Gearing-12/53 PN Ball Diff
Notes-
Date- 12/11/2025
Fastest Lap- 2.775
Wheelbase-98mm
Motor-PN 3500Kv
Notes-
#3430
Class- PROSTOCK
Date- 12/11/2025
Race Time- 3:54.988 / 234.988
Fastest Lap- 2.937
Chassis- PN 2.5W/MR04EVO board/ 04 arms
Body- McLaren 12C
Wheelbase- 98mm
Tires-F- PN KSK 540 / R- PN KSK 2030
Wheels- F- 3D Disk Wheels +1mm 20mm Blk #6 dsk / R- 3D Disk wheels +2mm 20mm Blk #12 dsk
Motor-PN 5500Kv Anima Sensored
Front Springs- Kyo Green
T-Plate-PN #4 Black Fiber Glass
Motor Mount-PN Multi Mount
Dampener (If applicable)- PN DDS ( Green top/ Green bottom spring) PN Dual Spring Top Shock (Silver Stock Springs)
Gearing-8/52 PN Ball Diff
Notes-
Date- 12/11/2025
Fastest Lap- 2.937
Body- McLaren 12C
Wheelbase- 98mm
Notes-
#3431
Class- PORSCHE
Date- 12/15/2025
Location- Central Texas
Race Time- 3:53.864 / 233.864
Fastest Lap- 2.932
Chassis- MR04EVO
Body- Porsche 911 GT3 RS (MZN232)
Wheelbase- 90mm
Tires-F- PN KS Medium LH (new KS1138) / R-Marka V1R10 half worn but good grip still
Wheels- F-PN N +2mm 19mm Black 3D Disk no dsk / R- W 0mm 20mm Black 3D no dsk
Motor-PN Anima V4 3500Kv Sensored
Front Springs- PN Green
T-Plate-Nexx #3 Black Carbon Fiber
Motor Mount-Nexx 90/94mm RM
Dampener (If applicable)- PN DDS (Purple top disk/Green bottom spring)
Gearing-11/53 PN Ball Diff
Notes-
Date- 12/15/2025
Fastest Lap- 2.932
Chassis- MR04EVO
Wheelbase- 90mm
Notes-
#3432
Class- NARROW
Date- 12/17/2025
Race Time- 4:00.625 / 240.625
Fastest Lap- 3.054
Chassis-MR03EVO
Body-Yaris
Wheelbase-90mm
Tires- F-PN KS Medium LH (KS1138) / R- PN KSK535 Soft
Wheels-F- 3D Disk N-0mm 19mm Blue #6 dsk / DXR N -1mm 20mm Gold 10spoke
Motor-PN 3500Kv
Batteries- SpeedHouse 800HV
Front Springs-Kyo Orange (soft and short) on Inner Tube Shock Set dry
T-Plate-Nexx #4
Motor Mount-Nexx 90/94mm MM
Dampener (If applicable)- PN DDS Purple top and Bottom springs
Gearing- 13/53 PN Ball Diff
Notes-
Date- 12/17/2025
Fastest Lap- 3.054
Chassis-MR03EVO
Body-Yaris
Wheelbase-90mm
Motor-PN 3500Kv
T-Plate-Nexx #4
Notes-
#3433
Class- MX-5
Date- 12/17/2025
Race Time- 3:59.631 / 239.631
Fastest Lap- 2.961
Chassis- PN 2.5W / MR03 board
Body- Kyosho MX-5
Wheelbase- 90mm
Tires-F- PN KS Medium LH (new KS1138) / R- Old Marka V1R10
Wheels- F-PN N +1mm 19mm Black 3D Disk wheels no disk / R-W DXR Black carbon -1mm 20mm
Motor-Rocket 3500Kv
Front Springs- PN White
T-Plate-PN #2 Silver Carbon Fiber
Gearing-13/54 PN Ball Diff
Notes-
Date- 12/17/2025
Fastest Lap- 2.961
Body- Kyosho MX-5
Wheelbase- 90mm
Motor-Rocket 3500Kv
Notes-
#3434
Class- OPEN 2WD
Date- 12/19/2025
Race Time- 3:41.433 / 221.433
Fastest Lap- 2.816
Chassis- GL GLR
Body- Audi R8 2015
Wheelbase- 98mm
Tires-F- PN KS Medium LH (KS1138)/ R- Marka MZR-V1R05
Wheels- F- N+1.5mm 19mm PN Flanged 6 hole Delrin / R- W+3mm 20mm 3D Disk wheels Black (no disk)
Motor- GL 3500kv
Batteries- GNB 350mAh 2S LiPO
Front Springs- Purple
T-Plate-N/A
Motor Mount-GL 98mm
Dampener (If applicable)- Short Center Shock (Blue Spring) / Yellow side springs
Dampener Fluid (If applicable)- 15K Kyo grease- Center / 15K Kyo grease- Sides
Gearing- 10/52 GL Ball Diff
Notes-
Date- 12/19/2025
Fastest Lap- 2.816
Chassis- GL GLR
Body- Audi R8 2015
Wheelbase- 98mm
Motor- GL 3500kv
T-Plate-N/A
Motor Mount-GL 98mm
Notes-
#3435
December 2025 Final Results
Well Yall, another year has come to an end, and we had a good showing for this time of year! Welcome Jdunfee424 and the rest of yall who got tracks and are soon to join us! We had some close racing in all classes but BoxStock was very tight with the top 5 places having less than 8 seconds between them.
Congrats to Traveler2 for the fastest overall time of 3:35.311, and I had the fastest lap of 2.775 (lucky, even the sun shines, lap that I couldn't match even with my open car).
I hope we have a even stronger year, as quite a few people got tracks the last few months, so post those times, even if they aren't podium places, as it's great to keep track of your progress, and when we run the same track at a later date, you can really see your improvement!!!
I want to THANK everyone who participated and helped this year, and if we continue this we will only get stronger!!! So keep turning those laps and keep it shiny side up!!!
BOX STOCK
1) joelisenat************** 3:52.816 / 2.927
2) Traveler2*************** 3:53.114 / 2.981
3) BurgerMaster************ 3:54.168 / 2.954
4) BoxxerBoyDrew*********** 3:56.726 / 2.943
5) ekim628***************** 3:59.170 / 2.830
6) AM03GT****************** 4:04.983 / 3.076
7) Poor_Boy**************** 4:05.840 / 3.050
8) Jdunfee424************** 5:30.600 / 3.640
9) BrianNichols************ 6:37.751 / 3.976
STOCK
1) joelisenat************** 3:41.732 / 2.797
2) Traveler2*************** 3:45.930 / 2.904
3) Poor_Boy**************** 3:52.600 / 2.860
4) BoxxerBoyDrew*********** 3:57.205 / 2.775
5) AM03GT****************** 4:14.365 / 3.108
PRO STOCK
1) Traveler2*************** 3:46.687 / 2.946
2) joelisenat************** 3:54.445 / 2.856
3) BoxxerBoyDrew*********** 3:54.988 / 2.937
4) Poor_Boy**************** 4:02.400 / 2.820
NARROW
1) BoxxerBoyDrew*********** 4:00.625 / 3.054
2) Traveler2*************** 4:12.768 / 3.211
PORSCHE
1) BoxxerBoyDrew*********** 3:53.864 / 2.932
2) Traveler2*************** 4:05.762 / 3.132
3) joelisenat************** 4:10.146 / 3.146
4) Gburr******************* 4:26.506 / 3.179
OPEN MX-5
1) BoxxerBoyDrew*********** 3:59.631 / 2.961
2) Traveler2*************** 4:24.593 / 3.381
OPEN 2WD
1) Traveler2*************** 3:35.311 / 2.788
2) BoxxerBoyDrew*********** 3:41.433 / 2.816
3) BurgerMaster************ 3:43.097 / 2.698
4) AM03GT****************** 3:50.629 / 2.866
5) Poor_Boy**************** 3:56.260 / 2.910
6) BrianNicols************* 5:50.625 / 3.722
I think I got everything and everyone correct and included, but if a missed something just holler and I'll get it fixed up!
BOX STOCK
STOCK
PRO STOCK
NARROW
PORSCHE
OPEN MX-5
OPEN 2WD
3036Likes
