Mini-96 World Challenge >
Like Tree3035Likes
Old 12-02-2024 | 09:05 PM
  #2671
We had 8 drivers posting 26 entries last month, including some new racers. Had close racing in several classes.
Here are the Novembeer 2024 results:
Box Stock Sportsman
1st - Shawn Oliver – 287.5/3.47
2nd –
danjoy25/Dan Dylen Garcia – 318.85/3.38
3rd – Roadrashracing2 – 346/4.02
4th - Berat – 348.20/3.85
5th - Fredoise85 -494.10/4.98
Box Stock Expert
1st - Traveler2/Marwan Zabaneh – 230.3/2.85
2nd - PoorBoy/David Krinard – 247.5/3.04
3rd – TAMAK/Mitchel Kauppila – 249.5/2.97
Stock Class
1st - Traveler2/Marwan Zabaneh – 210.7/2.53
2nd - PoorBoy/David Krinard – 231.1/2.78
3rd – TAMAK/Mitchel Kauppila – 258.5/3.04
4th - danjoy25/Dan Dylen Garcia – 287.49//3.30
5th – Crazyfastford – 321.90/3.65
Pro Stock
1st - Traveler2/Marwan Zabaneh – 210.3/2.59
2nd - PoorBoy/David Krinard – 225.7/2.8
Narrow Class
1st - Traveler2/Marwan Zabaneh – 235.7/2.9
2nd - PoorBoy/David Krinard – 240.05/2.89
Unofficial Open MX-5 Class
1st - Traveler2/Marwan Zabaneh – 243.2/2.78
2nd – PoorBoy/David Krinard – 238.2/2.93
Porsche Cup Class
1st - PoorBoy/David Krinard – 227.95/2.81
2nd – Traveler2/Marwan Zabaneh – 229.8/2.99
Open 2WD
1st - Traveler2/Marwan Zabaneh – 211.2/2.55
2nd - PoorBoy/David Krinard 225.19/2.80
Open AWD
1st - PoorBoy/David Krinard – 242.96/2.79
2nd - TAMAK/Mitchel Kauppila – 269.92/3.01
3rd – Fredoise85 – 435.6/4.60
Phatz_60 likes this.
Poor_Boy is offline
Old 12-05-2024 | 04:48 AM
  #2672
Ok Guys, I’ve probably asked this before ( meds mess with my memory too) I’m building a printed chassis, a OBRC OBZ and would definitely love to run it in the challenge, is it legal in 2wd open? Thx Walt
PS don’t worry I’ll never get close to PoorBoy and Traveler2‘s Box Stock Runs let alone some of the other times y’all are insanely FAST
Phatz_60 is offline
Old 12-05-2024 | 06:30 AM
  #2673
Originally Posted by Fredoise85
Class-Open AWD
Date-10/19/2024
Location-Norway
Race Time-435,6
Fastest Lap-4.60
Chassis-GL racing GLA aV2
Body- gl lexan
Wheelbase-98mm
Tires-Marka slik front and rear
Motor-3500kv
Batteries-2S lipo
Front springs- GL blue
Rear springs -GL blue
Dampener (If applicable)-None
Gearing-Stock Gear Diff/15T pinion
Notes- first time attending 🤗 so not alowed to post pictures yet
Now you motivated me to try with my GLA, too
Haven't driven it much since I bought it because I wanted to gain some experience in the box stock class.
Berat is offline
Old 12-05-2024 | 07:19 AM
  #2674
I'm pretty sure printed chassis are 2wd open legal, but PoorBoy will confirm. And don't worry about ur times, speed comes with practice. BUT you are 100% correct that PoorBoy and Traveler2 are stupid fast with very few mistakes!!! I'm getting close to their lap times, but when I try to run that fast my overall consistency SUX and it's full of mistakes. It's hard for me to remember slower and steady is faster!
Pics of the printed build would be awesome, as I love to build/tune on cars almost as much as I do driving!
Berat likes this.
BoxxerBoyDrew is offline
Old 12-05-2024 | 07:21 AM
  #2675
Hey Walt! Yes the OBZ will put you into Open 2WD.
Phatz_60 and Berat like this.
Traveler2 is offline
Old 12-05-2024 | 01:47 PM
  #2676
Awesome I just wanted to be sure I could use it, thx Traveler
Berat likes this.
Phatz_60 is offline
Old 12-07-2024 | 06:22 AM
  #2677
The key to the getting 2wd open cars to work on the Mini96 is turning the throttle endpoint down. I would start in the 40-50% range until you can run consistently then slowly turn it back up (I don't think mine is above 70% with a 3500kv motor). It took me a few months to be able to beat my stock times with an open car as they can be a handful to drive and the setup can be difficult to figure out. The great thing about getting into the brushless cars is you don't have to stop to let the motor cool so it is great for getting a lot of laps of practice in a short time.
Poor_Boy is offline
Old 12-07-2024 | 05:25 PM
  #2678
I put a few runs with my Stock car on the clock, and I 4 SURE a Clock Wise dominate driver!!! I am almost a half second slower and mistake ridden! I had to turn the throttle end point from 75% to 50% to even get the car somewhat controllable turning CCW! I had to keep fighting my instincts when recovering from a mistake when needing to reverse, to not start going CW. Anyway here's a starting time to see how I improve through out the month.
This is with my PN2.5W 03EVO Stock chassis w/ Green Jomurema w/Lexan windows. Also I am trying to drive with a Soft Tx wheel, and I think I'm better with a firmer wheel. I tend to over correct going past center. Probably has a lot to do with the reduced feeling in my rt hand.
I also got some parts in from Wolfram for my Open Chassis (8500kv), and just in time too, as the HARD Reversing was destroying my 03 factory gear diff! Using the #6 motor plates in the 04 MM Pod, the PN Ball Diff geared 52/9, the car is SOOO MUCH better and controllable! It flat out RUNS with either a NSX or Camaro body using PN +1mm 19mm Dish Wheels up front, and the factory NSX +1 20mm rear wheels and PN KS Medium LH front and KSM Soft Rear Radials! Both bodies handle well but the NSX is a bit easier on the rails. I'll get some times tomorrow and post them up. The PN V4 motor mount should be hear Monday, so I will time with both pods ( PN V4 vs. Kyo MR04 MM) and see if there's a difference between the 2. I also got a PN 2.5W chassis to swap the Kyo 04 chassis, but it's dialed in as it is so I hate to change it!
Running both the NSX and the Camaro on the MR04 Open is a world of difference than on the 03! I shelved both the bodies after trying them on an MR03 as they had bad traction rolling problems no matter what I tried to solve it, but on the MR04 they show no signs of TR! Now the problem is I'm out of KS Medium LH fronts, and my normal go to stores are out of stock! Thinking of trying some Reflex tires, but I haven't seen anyone using them here yet. Anyone try them yet?
Anyway hope all is well! Drew
Old 12-08-2024 | 06:21 AM
  #2679
Your fast lap is great I am sure the constancy will improve with more laps. It still takes me over 50 laps before I start turning any sub 3 second laps on this layout but if I really work at it I can find a few sub 2.9 laps. Best run so far in stock with my newly assembled 94mm chassis running my fastest 94 body that has been out of the lineup for a few years. Will be interesting to see how it stacks up against my other stock cars.
Poor_Boy is offline
Old 12-08-2024 | 08:47 AM
  #2680
Hey Folks, Berat and I just finished driving some laps ( was getting cold in the garage even with a heater lol ) I’m having trouble as always but he beat his last month’s run by 11 seconds!!!, we‘ll be driving again next week too so maybe I can get some times in too. Have a Nice week guys, drive smooth
BoxxerBoyDrew and Berat like this.
Phatz_60 is offline
Old 12-08-2024 | 07:21 PM
  #2681
Video of my 94mm car. Not my fastest run but wanted to get some video up incase it helps someone find a fast line around this layout. Found that throttle endpoint in the 70-75% range is fastest for my driving style.
BoxxerBoyDrew and Phatz_60 like this.
Poor_Boy is offline
Old 12-09-2024 | 05:34 AM
  #2682
Sorry double post
Phatz_60 is offline
  #2683
https://www.youtube.com/watch?v=38AVjSznBrU
saw it on fb thx we were driving a completely different line
Drive Smooth
Phatz_60 is offline
Old 12-09-2024 | 06:05 AM
  #2684
Drive Smooth
I mean: I'd love to follow his line. My problem is that I can't position the car that precisely yet
Berat is offline
Old 12-09-2024 | 10:43 PM
  #2685
Hey PoorBoy,
Now that the MR04 Ready Set has been released, are they going to be allowed in BoxStock? They are supposed to be the same board, but the rear pod has axel height adjustment, which is NICE but an advantage over the 03 along with the improved steering and lower CG. I have most of the spare parts to change my 03 to an 04 already, and as much as I like how the 04 drives, it would probably be worth the time and small expense!
What's Yall's thoughts?
p.s. Your driving and times are freakin Awesome!
