Mini-96 World Challenge
#2821
CrazyRonny / Ronald Bolduc
Class- Box Stock
Date-01/31/2025
Location- Quebec Canada
Race Time- 4:59 minutes / 299 seconds
Fastest Lap- 3.625 seconds
Chassis- MR03
Body- Audi R8
Wheelbase- 98mm
Wheels/Tires: F- 8.5mm +2mm PN Soft low profile / R- 11mm +3mm Marka 10
Motor- Stock
Batteries- SpeedHouse 800
Front Springs- Stock
T-Plate- Kyosho Fiberglass 6H
Motor Mount- stock MM
Dampener (If applicable)- stock
Dampener Fluid (If applicable)- none
Gearing- 7t pinion/ stock gear diff
Class- Box Stock
Date-01/31/2025
Chassis- MR03
Body- Audi R8
Wheelbase- 98mm
Motor- Stock
#2822
Class- Stock
Date-01/31/2025
Race Time- 4:33 minutes / 273 seconds
Fastest Lap- 3.294 seconds
Chassis- MR04
Body- Nissan GTR
Wheelbase- 98mm
Wheels/Tires: F- 8.5mm +2mm PN Med low profile / R- 11mm +3mm Marka 15
Motor- Kyosho brushless sensored 5700
Front Springs- ?
T-Plate- PN-5
Motor Mount- Xpower
Dampener (If applicable)- xpower
Gearing- ? pinion/ ? Spur (to lazy to count...)
Class- Stock
Date-01/31/2025
Chassis- MR04
Body- Nissan GTR
Wheelbase- 98mm
Front Springs- ?
T-Plate- PN-5
Motor Mount- Xpower
#2823
Class- AWD Box Stock MA-020
Date-01/31/2025
Race Time- 5:06 minutes / 306 seconds
Fastest Lap- 3.685 seconds
Chassis- MA020
Body- Nissan GTR
Wheelbase- 94mm Narrow
Wheels/Tires: F- 8.5mm Kyosho 30 Radial / R- 11mm Kyosho 30 Radial
Motor- Stock
Batteries- Duracell 750mah
T-Plate- Stock
Motor Mount- Stock
Dampener (If applicable)- none
Gearing- Stock
Date-01/31/2025
Chassis- MA020
Body- Nissan GTR
Motor- Stock
T-Plate- Stock
Motor Mount- Stock
Gearing- Stock
#2824
Class - Box Stock
Date - 1/31/2025
Location - Iowa
Race Time - 255.536
Fastest Lap - 3.162
Chassis - MR-03 MM
Body - McLaren 12C
Wheelbase - 98mm
Tires - PN KS Medium on 20mm F1 flanged wheels, no tape / Marka V1R10 R2 wheels
Motor - Stock
Batteries - Orion 750 SHO
Front Springs - Orange
T-Plate - Kyosho Carbon Firm
Motor Mount - Stock
Dampener (If applicable) -
Dampener Fluid (If applicable) -
Gearing - 7T, stock diff
Date - 1/31/2025
Location - Iowa
Race Time - 255.536
Fastest Lap - 3.162
Chassis - MR-03 MM
Body - McLaren 12C
Wheelbase - 98mm
Motor - Stock
Motor Mount - Stock
#2825
January 2025 MX-5 Miata Unofficial Experimental Class
Class - 90mm Narrow MX-5 Miata Unofficial Experimental Class
Date - 1/31/25
Location - Iowa
Race Time - 270.251
Fastest Lap - 3.162
Chassis - MR-03 RM
Body - MX5 Roadster
Wheelbase - 90mm
Tires - PN KS Medium / PN KS Soft
Wheels - 0 Offset Flanged Narrows x4
Motor - Stock
Front Springs - PN Super Soft Blue
T-Plate - Kyosho FRP 5S
Motor Mount - Stock
Notes - Found out that the brake was always being applied at neutral. After bumping the trim forward it took off the drag brake effect and is now fun to drive.
Date - 1/31/25
Location - Iowa
Race Time - 270.251
Fastest Lap - 3.162
Chassis - MR-03 RM
Body - MX5 Roadster
Wheelbase - 90mm
Motor - Stock
Motor Mount - Stock
#2826
repost from the beginning of the month, as I woke up with my back out, and couldn't beat this time! Between my back and the rain we had for the last 2 days my driving tonight SUCKED!!! Cars were very edgy!
After seeing PoorBoys 102mm 787B run I wanted to try my 787B, so I stuck my 787B on my ProStock MR04 chassis and it is flat running! A few less mistakes and I would have been under 4 minutes!
P.S. Shoe Goo is holding the broken left front light/nose very well! Looks like crap if you look close, but it's holding!
#2827
Class-2WD OPEN
Date- 01/31/2025
Location-Central Texas
Race Time- 277.260 / 4:37.260
Fastest Lap- 3.066
Chassis-PN 2.5W/ MR04EVO Board
Body- RadBody Mako X Lexan
Wheelbase-98mm
Tires-F- PN KSM Medium LH / R- Marka V1R10
Wheels-F- N+2 20mm PN BBS Yellow / R- W+3mm 20mm Kyosho BBS Black
Motor-PN V4 Anima 3500kv
Batteries-Eneloop
Front Springs-Kyo Orange
T-Plate-Nexx #5
Motor Mount-PN V3 94/98mm
Dampener (If applicable)- PN DDS ( Gold top and Bottom Springs)
Gearing- 12/54 PN Ball Diff
Notes- Mako X lexan body is STUPID FAST and GLUED TO THE TRACK!!! BUT DAMN HARD TO SEE BEING UNPAINTED!! I had to really concentrate to keep up with it, and would loose it from time to time! I'm testing colors and layouts on water bottles before trying to airbrush my first Lexan 1/28th scale body! . V4 Anima 3500kv is as fast as I can handle on the MINI96 with a Lexan body, but I can see where it would be slow on bigger tracks against 03EVOs. Maybe a Hard Body would be slow with the added weight, and I want to try it, but the Mako X is running too good to screw with!
Again back screwed, and humidity and temp are both way up in the last few days! Humidity went from 25-30% to 68% tonight, track temp went from 60* to 71*! Cars are very edgy and rear ends were greasy! My times sucked and I rolled on my lid twice clipping the inside corner at the end of the straight!!!
Hard to jump up and overturn the car when the back is out!
Date- 01/31/2025
Fastest Lap- 3.066
Wheelbase-98mm
Batteries-Eneloop
T-Plate-Nexx #5
#2828
Class-PORSCHE
Date- 01/31/2025
Race Time- 274.713 / 4:34.713
Fastest Lap- 3.184
Chassis-MR03EVO
Body-Porsche 911 GT3 RSR
Wheelbase-90mm
Tires-F- PN KS-M Medium LH / R-PN KS-M Soft LH
Wheels- F-PN N +1mm 20mm Yellow BBS / R-PN W +1mm 20mm Yellow BBS
Motor-Rocket 3500Kv
Batteries-Eneloop
Front Springs- PN Yellow
T-Plate-Nexx #5
Motor Mount-Nexx 90/94mm RM
Dampener (If applicable)- PN DDS (Gold top/Purple bottom springs)
Gearing-12/50 PN Gear Diff
Notes- Had to superglue the sidewalls of the front and rear tires to help with traction roll at high speed, and it's better, but not as good as I want it to be!
Date- 01/31/2025
Fastest Lap- 3.184
Chassis-MR03EVO
Wheelbase-90mm
Motor-Rocket 3500Kv
Batteries-Eneloop
T-Plate-Nexx #5
#2829
Class- MX-5
Date- 01/31/2025
Race Time- 282.496 / 4:42.496
Fastest Lap- 3.228
Chassis-MR03 EVO
Body-Mazda MX-5
Wheelbase-90mm
Tires-F- PN KS Medium LH / R- PN KS-M Soft LH
Wheels-F- PN N 0mm Yellow BBS / R- DXR MP1 W -1mm 20mm Carbon Black
Motor-PN 3500Kv
Batteries-Eneloop
Front Springs-Green on Inner Tube Shock Set
T-Plate-Nexx #5
Dampener (If applicable)- PN DDS (Gold top/Green bottom springs)
Gearing-13/53 PN Gear Diff
Notes- As my open and Porsche were, the MX-5 was super edgy, and the ass end wouldn't stay planted. It kept slipping out from under itself on throttle in the corners. DANG back and weather!! Hope Yall's end of month driving went better than mine!
If you look close, you can see the Shoe Goo repair where the nose broke in the corner of the passenger headlamp through the splitter. Held so far!
Date- 01/31/2025
Fastest Lap- 3.228
Chassis-MR03 EVO
Body-Mazda MX-5
Wheelbase-90mm
Motor-PN 3500Kv
Batteries-Eneloop
T-Plate-Nexx #5
#2830
I have had Mini Z's for about 6 months but only got a RCP track about 2 months ago. I pushed extremely hard to get under 5 mins for the month. I wanted my total time to start with a 2XX.XX. It was so much fun pushing for a personal best time. I can't wait to get next months track layout.
Good Luck and Welcome to the fold!
#2831
Dan Garcia
Class- Box Stock
Date-01/31/2025
Location- Sydney
Race Time- 4:55.508
Fastest Lap- 3.631
Chassis- MR04
Body- Jomurema
Wheelbase- 98mm
Wheels/Tires: Marka 20f & 10r
Motor- Stock
T-Plate- Kyosho Fiberglass 4
Class- Box Stock
Date-01/31/2025
Location- Sydney
Race Time- 4:55.508
Fastest Lap- 3.631
Chassis- MR04
Body- Jomurema
Wheelbase- 98mm
Motor- Stock
#2832
Dan Garcia
Class- Stock
Date-01/31/2025
Location- Sydney
Race Time- 4:13.688
Fastest Lap- 3.152
Chassis- MR04
Body- PN C9
Wheelbase- 98mm
Motor- 3500kv
Gearing- 9t pinion/ stock ball diff
Class- Stock
Date-01/31/2025
Location- Sydney
Race Time- 4:13.688
Fastest Lap- 3.152
Chassis- MR04
Body- PN C9
Wheelbase- 98mm
Motor- 3500kv
#2833
Dan Garcia
Class- 2wd open
Date-01/31/2025
Location- Sydney
Race Time- 4:22.091
Fastest Lap- 3.167
Chassis- GL GTR
Body- PN C9
Wheelbase- 98mm
Motor- 2500kv
Batteries- GL Lipo
T-Plate- N/A
Dampener Fluid (If applicable)- 30k
Gearing- 12t pinion/ stock ball diff
Class- 2wd open
Date-01/31/2025
Location- Sydney
Race Time- 4:22.091
Fastest Lap- 3.167
Chassis- GL GTR
Body- PN C9
Wheelbase- 98mm
Motor- 2500kv
Batteries- GL Lipo
T-Plate- N/A
#2835
Class-Box Stock
Date-1/6/2025
Location-Winston-Salem, NC
Race Time-246.4
Fastest Lap-3.10
Chassis-MR-03 FHSS
Body-2012 NSX
Wheelbase-98mm
Tires-PN KS Firm fronts, Marka V1R15 rears
Motor-Stock
Batteries-GensAce 750s
Front Springs-Kyosho Stock
T-Plate-Kyosho FRP 0.6H
Motor Mount-Stock MM
Dampener (If applicable)-None
Notes-Got within 1.4 seconds of my fastest Feb 2023 time, but could not beat it despite several tries.
Date-1/6/2025
Race Time-246.4
Fastest Lap-3.10
Chassis-MR-03 FHSS
Body-2012 NSX
Wheelbase-98mm
Motor-Stock
3036Likes
