Mini-96 World Challenge
#2971
Well, my day of driving was CRAP! The humidity is way up and all my cars were very nervous feeling, and my GLR handled the best, it was having receiver issues (I think) and would either throttle down and keep turning into the wall ,usually off the first 90* on the straight, or wouldn't turn or throttle down going into a corner, again usually at the 180* off the straight.
VERY aggravated with the whole day! I HOPE YALL had a better day of running! I ran all 7 chassis in the 7 classes I can, so at least that's a positive no matter my times! Anyway here goes!
Class-BOXSTOCK
Date- 03/31/2025
Location-Central Texas
Race Time- 337.256 / 5:37.256
Fastest Lap- 4.042
Chassis-MR04
Body-Audi B8 LMS 2015
Wheelbase-98mm
Tires- F-PN KSM Medium LH / R-PN KS-M Soft Radials
Wheels- F- N +1mm 20mm PN BBS Yellow / R- W +1mm 20mm PN BBS Black
Motor- Kyo Stock
Batteries- Eneloop 850HV
Front Springs-Purple
T-Plate-Nexx #4 Carbon
Motor Mount-Kyo Stock MM
Dampener (If applicable)- Kyo Spring shock (yellow spring)
Dampener Fluid (If applicable)- Atomic 15k grease
Gearing-7/44 Kyo Gear Diff- Ruby Lube packed
Notes- car feels very underpowered, and it shows when even the slightest contact with the wall slows the car to almost a stop. Also rear end chatters bad underpower. NEEDS WORK!
VERY aggravated with the whole day! I HOPE YALL had a better day of running! I ran all 7 chassis in the 7 classes I can, so at least that's a positive no matter my times! Anyway here goes!Class-BOXSTOCK
Date- 03/31/2025
Fastest Lap- 4.042
Chassis-MR04
Wheelbase-98mm
Motor- Kyo Stock
#2972
Class-STOCK
Date- 03/31/2025
Race Time- 308.161 / 5:08.161
Fastest Lap- 3.789
Chassis- PN 2.5W/MR03EVO board/ 04 arms
Body-Jomurema
Wheelbase-98mm
Tires-F-PN KS Soft / R- Marka V1RR10 Soft Radials almost worn to slicks
Wheels- F-PN N+1.5mm 19mm Flanged White 6 hole / R- PN W+2mm 20mm Flanged White 6 Hole
Motor-PN 3500Kv
Front Springs-PN Purple
T-Plate-PN #3 Silver Carbon Fiber
Motor Mount-PN V3 94/98mm
Dampener (If applicable)- PN DDS ( Green top/ PN lt. purple X-Strenght bottom spring) PN Dual Spring Top Shock (Green Front/Purple Rear)
Gearing-12/53 PN Ball Diff
Notes- Car ok but nervous, me not so good! I should have broken the 5 minute mark!
Date- 03/31/2025
Fastest Lap- 3.789
Body-Jomurema
Wheelbase-98mm
Motor-PN 3500Kv
#2973
Class-PROSTOCK
Date- 03/31/2025
Race Time- 307.700 / 5:07.700
Fastest Lap- 3.787
Chassis-PN 2.5W/04EVO board/ 04 Arms/ Nexx knucks
Body-Mazda 787B
Wheelbase-102mm
Tires-F- Reflex 45* LH slicks/ R- Reflex 30* Radials
Wheels- F- N+1mm 20mm PN BBS Yellow / R- W+2mm 20mm PN Yellow BBS
Motor-PN Anima 5500Kv
Batteries-Eneloop
Front Springs-Green
T-Plate-Nexx #5 Carbon
Motor Mount-PN Multi Mount
Dampener (If applicable)- PN DDS (Green top/Gold bottom springs) PN Dual Spring Top Shock Silver springs
Gearing-12/52 PN Ball Diff
Notes- Car was second best next to GLR, me not so good! Next month!!! Again should have broken the 5 minute mark.
Date- 03/31/2025
Fastest Lap- 3.787
Body-Mazda 787B
Wheelbase-102mm
Batteries-Eneloop
Front Springs-Green
#2974
Class-PORSCHE
Date- 03/31/2025
Race Time- 337.145 / 5:37.145
Fastest Lap- 3.997
Chassis-MR03EVO
Body-Porsche 911 GT3 RSR
Wheelbase-90mm
Tires-F- PN KS Medium LH / R-PN KSK Soft Slicks
Wheels- F-PN N +.5mm 19mm 6 Hole Flanged White Delrin / R-PN W 0mm 20mm Yellow BBS
Motor-Rocket 3500Kv
Batteries-Eneloop
Front Springs- PN White
T-Plate-Nexx #5
Motor Mount-Nexx 90/94mm RM
Dampener (If applicable)- PN DDS (no top disk/Purple bottom springs) PN Dual Spring Shock ( Purple front/Red Rear)
Gearing-12/53 PN Gear Diff
Notes- I couldn't keep the rear from hooking around, and it was a handful to control!
Date- 03/31/2025
Fastest Lap- 3.997
Chassis-MR03EVO
Wheelbase-90mm
Motor-Rocket 3500Kv
Batteries-Eneloop
T-Plate-Nexx #5
#2975
Class-NARROW
Date- 03/31/2025
Race Time- 345.383 / 5:45.383
Fastest Lap- 4.047
Chassis-MR03EVO
Body-Mazda MX-5
Wheelbase-90mm
Tires- F-PN KSK Medium LH / R- PN KS-M Medium LH
Wheels-F- PN N 0mm 20mm 6Hole Flanged White Delrin / PN N 0mm 20mm White Dish
Motor-PN 3500Kv
Batteries-HiTec 750HV
Front Springs-Kyo Short/Soft Orange on Inner Tube Shock Set (dry)
T-Plate-Nexx #5
Motor Mount-Nexx 90/94mm MM
Dampener (If applicable)- PN DDS (Purple top/Green bottom springs)
Gearing- 12/53 sealed ball diff
Notes- Haven't figured out the 90mm MM pod yet. rear end is on ice!
Date- 03/31/2025
Fastest Lap- 4.047
Chassis-MR03EVO
Body-Mazda MX-5
Wheelbase-90mm
Motor-PN 3500Kv
T-Plate-Nexx #5
#2976
Class- MX-5 Open
Date- 03/31/2025
Race Time- 335.261 / 5:35.261
Fastest Lap- 3.863
Chassis-MR03 EVO
Body-Mazda MX-5
Wheelbase-90mm
Tires-F- PN KS Medium LH / R- PN KS-M Soft LH
Wheels-F- PN N 0mm Yellow BBS / R- DXR MP1 W -1mm 20mm Carbon Black
Motor-PN 3500Kv
Batteries-Eneloop 850HV
T-Plate-Nexx #5
Gearing-13/53 PN Gear Diff
Notes- Car twitchy and rear end was loose. Me not very good.
Date- 03/31/2025
Fastest Lap- 3.863
Chassis-MR03 EVO
Body-Mazda MX-5
Wheelbase-90mm
Motor-PN 3500Kv
T-Plate-Nexx #5
#2977
Class-2WD OPEN
Date- 03/31/2025
Race Time- 333.728 / 5:33.728
Fastest Lap- 3.064
Chassis-GL Racing GLR
Body- Green Jomurema Lexan Window
Wheelbase-98mm
Tires-F- PN KS Firm Normal height / R- Marka V1R10
Wheels-F- N+1 19mm PN White Dish/ R- W+2mm 20mm PN BBS Yellow
Motor-GL 3500kv sensored but running Unsensored
Batteries- GNB 350mAh 2S LiPo
Front Springs- GL Blue
T-Plate-N/A
Motor Mount- GL 98mm
Dampener (If applicable)- GL Blue Center / Yellow Side springs on metal side dampers
Dampener Fluid (If applicable)-Atomic 15K on center and side dampers & lower kingpin balls
Gearing- 11/53 GL Ball Diff w PN Spur
Notes- First month with GLR, and until this run it was flawless. RX issues ( I think), but the GLR IS AWESOME! Every lap over 5 seconds was a radio issue/glitch.
Date- 03/31/2025
Fastest Lap- 3.064
Wheelbase-98mm
T-Plate-N/A
#2979
March Mini96 attendance
Class-Box Stock
Date-03/21/2025
Location-Norway
Race Time-482,83
Fastest Lap-5,21
Chassis-MR-03
Body-Camaro
Wheelbase-98mm
Tires-kyosho slik 30 front radial 20 rear
Motor-Stock
Batteries-Orion 750s
Front Springs-Kyosho Stock
T-Plate-Kyosho carbon medium
Motor Mount-Stock MM
Dampener (If applicable)-None
Notes- still not able to post pictures.
Class-Box Stock
Date-03/21/2025
Location-Norway
Race Time-482,83
Fastest Lap-5,21
Chassis-MR-03
Body-Camaro
Wheelbase-98mm
Motor-Stock
Last edited by Fredoise85; 03-31-2025 at 11:47 PM. Reason: Miscalculated the time. I used 8.04.43
#2980
Class-Open 2WD
Date-03/21/2025
Location-Norway
Race Time-453,94
Fastest Lap-4.96
Chassis-OBRC OBZ
Body- Jomurema
Wheelbase-98mm
Tires-Atomic radial front and rear
Motor-Atomic 3500kv
Batteries-2S lipo
Front springs- GL blue
Rear springs -GL blue
Gearing-Stock GL-GTR Gear Diff 63/10T pinion
Notes- not sure that this chassis is allowed in 2wd Open, if not this is at least my unofficial attendance
Class-Open 2WD
Date-03/21/2025
Location-Norway
Race Time-453,94
Fastest Lap-4.96
Chassis-OBRC OBZ
Body- Jomurema
Wheelbase-98mm
Motor-Atomic 3500kv
Batteries-2S lipo
#2981
Class-Open 2WD
Date-March 2025
Location-Sydney
Race Time-5:33.986
Fastest Lap-4.029
Chassis-GL Racing LmP2
Body- GL McLaren 720
Wheelbase-102mm
Tires-Marka front and rear
Motor-3500kv
Batteries-2S lipo
Front springs-stock
Rear springs -stock
Dampener Fluid (If applicable)-none
Gearing- stock ball diff
Notes- none
Date-March 2025
Location-Sydney
Race Time-5:33.986
Fastest Lap-4.029
Wheelbase-102mm
Motor-3500kv
Batteries-2S lipo
Front springs-stock
Rear springs -stock
Notes- none
#2982
Class-box stock
Date-March 2025
Location-Sydney
Race Time-5:56.992
Fastest Lap-4.273
Chassis-MR04
Body- Jomurema
Wheelbase-98mm
Motor-stock brushed
Batteries-Kyosho AAA
Front springs-stock
Rear springs -stock
Gearing- stock
Notes- none
Date-March 2025
Location-Sydney
Race Time-5:56.992
Fastest Lap-4.273
Chassis-MR04
Body- Jomurema
Wheelbase-98mm
Motor-stock brushed
Front springs-stock
Rear springs -stock
Gearing- stock
Notes- none
#2983
Class-Open 2WD
Date-03/21/2025
Location-Norway
Race Time-453,94
Fastest Lap-4.96
Chassis-OBRC OBZ
Body- Jomurema
Wheelbase-98mm
Motor-Atomic 3500kv
Batteries-2S lipo
Class-Open 2WD
Date-03/21/2025
Location-Norway
Race Time-453,94
Fastest Lap-4.96
Chassis-OBRC OBZ
Body- Jomurema
Wheelbase-98mm
Motor-Atomic 3500kv
Batteries-2S lipo
3D Printed chassis are perfect in the OPEN class. Welcome it to the Challenge!
#2984
I ran the GLR trying to figure out what the heck happened to it last night and running the layout CCW for the first time. After running 2 batterie packs, no glitches this morning at all!
The track flows pretty good CCW, though my CCW skills need work!
#2985
March 2025 Results
BOX STOCK
1) PoorBoy- 304.950 / 3.550
Box Stock Sportsman
1) AM03GT- 316.165 / 3.957
2) BoxxerBoyDrew- 337.256 / 4.042
3) iDChuck- 346.693 / 4.228
4) danjoy25- 356.992 / 4.273
5) Maaku0220- 380.560 / 4.400
6) Fredoise85- 482.83 / 5.21
STOCK
1) PoorBoy- 298.64 / 3.700
2) BoxxerBoyDrew- 308.161 / 3.789
PRO STOCK
1) PoorBoy- 304.660 / 3.680
2) BoxxerBoyDrew- 307.700 / 3.787
NARROW
1) PoorBoy- 330.040 / 3.960
2) BoxxerBoyDrew- 345.383 / 4.047
PORSCHE
1) PoorBoy- 311.680 / 3.870
2) BoxxerBoyDrew- 337.145 / 3.997
UNOFFICIAL OPEN MX-5
2) BoxxerBoyDrew- 335.261 / 3.863
OPEN 2WD
1) PoorBoy- 291.700 / 3.420
2) AM03GT- 309.651 / 3.883
3) BoxxerBoyDrew- 333.724 / 3.604
4) danjoy25- 333.986 / 4.029
5) Crazy Fast Ford- 417.301 / 4.832
6) Fredoise85- 453.94 / 4.96
OPEN AWD
1) PoorBoy- 306.650 / 3.360
Fastest Lap Overall : PoorBoy with his impressive 3.360 on Open AWD!!!
Box Stock and Open 2WD were are largest classes this month, and we had a few new drivers! WELCOME to the challenge!!! I'm still trying to figure this whole thing out, so let me know if I screwed something up!
BOX STOCK
Box Stock Sportsman
STOCK
PRO STOCK
NARROW
PORSCHE
OPEN 2WD
OPEN AWD
3035Likes
