Mini-96 World Challenge >
Like Tree3035Likes
Old 03-16-2025 | 07:31 PM
  #2941
Could we design some tracks and submit them for possible use?
Phatz_60 likes this.
iDChuck is offline
Old 03-16-2025 | 08:57 PM
  #2942
AM03GT's Avatar
Originally Posted by iDChuck
I have heard that before, but sometimes you have to learn the limit to find that 100% and back off as necessary to 90%. and yes, even if i have to slow down in my laps just to prevent an accident, is better than having a mistake.
definitely this... losing ..5 seconds or so on a wall glance or a light bump-and-go will be much better than a full stop or a hard bump where you roll back... 75 laps is tough. i find that somewhere in the 40-50 range i usually lose focus for just a bit and have a few close calls or mishaps... whether or not those are the mild bad laps determines if the overall is a good run or not.
BoxxerBoyDrew and Phatz_60 like this.
AM03GT is offline
Old 03-16-2025 | 09:13 PM
  #2943
I'm glad you brought that up, because i thought I had ADHD around that mark thinking about brocolli or what color shirt I should wear tomorrow. I start to feel the fatigue and I force myself to focus on the task on hand lol
I also noticed wheels tucked in the body are less prone to snagging on the wall, which is why I am now using 0 offset up front. I turn the wheel to see if the tire is exposed outside of the wheel well to choose the offset. This also prevents knuckles from breaking. Maybe not optimal for racing with the narrow offset, but have to find the lesser of two evils. With better driving style, most likely don't need to worry. Initially at first I would ride the walls, but after finding a better line resulted in better driving style.
chjosi, BoxxerBoyDrew and Phatz_60 like this.
iDChuck is offline
Old 03-19-2025 | 04:13 PM
  #2944
Originally Posted by chjosi
I say the same thing every month when Poor_Boy and I chat. The more clean laps you run, the lower your time will go.
Another thing that helped me was when a local experienced racer told me, "90%. You should only drive at 90%."
When I feel like I'm driving slower it ends up being faster overall. The mistakes really do add up in time. I haven't found my rhythm on this layout let but its coming with more consistent lap times.
Maaku0220 is offline
Old 03-21-2025 | 12:40 PM
  #2945
I ran the GLR this morning and I'm dialing in on the best setup for me, but I ran the best at 54% throttle. I tried bumping up, but I got slower times while going faster with more mistakes. More details in the GLR thread. Anyway here's the first run on the clock with the GLR in this months layout.
The GLR is freakin sweet!!!
danjoy25 and Phatz_60 like this.
BoxxerBoyDrew is offline
Old 03-21-2025 | 09:22 PM
  #2946
I have TONS of track designs I made up when I first got the Z Round software with my EZLap timer system. I really need to try some of them out, because what fits our space and looks good on the screen may not drive well! Swapping the track around crawling on the floor is hard on my back, so maybe at the beginning of the month I'll try a few, and post how they worked out if my back is up to it!
The room I have the track in can only go 1 maybe 2 tiles longer and 2 tiles wider, but I don't know if others have more room, so I kept the designs to 12x8 tiles.
iDChuck and Phatz_60 like this.
Old 03-22-2025 | 12:26 PM
  #2947
AM03GT's Avatar
Those running open class do you gear smaller pinions due to the tight track? My open BL2500 is usually only .1-.2 faster than my box stock but since swapping to the pro match PN pinion in box stock they're almost identical for hot laps... Wondering if I need to gear for more low end and corner exit pull since we don't have any long straights to run out taller gearing...
AM03GT is offline
Old 03-22-2025 | 04:27 PM
  #2948
AM03GT, I usually start with any of my BrushLess at 11/53, stock to open. Then if I need more out of a turn I'll bump down a tooth, or if I need more roll through a corner I'll bump up, then adjust the throttle d/r to adjust speed for the track. Really just a personal feel. I'm just getting started with a true open chassis, and learning the GL ESC, but it's settings don't feel much different than the ICS settings on an 03/04EVO.
That said, for me when I've been learning and getting faster, no matter what car i'm driving, I'm usually within .3-.4 on my lap times. Now my overall times will be different as I can recover much faster with BL vs. BoxStock.
AM03GT and Phatz_60 like this.
Old 03-23-2025 | 09:16 PM
  #2949
AM03GT's Avatar
Thanks right in line with what I was thinking dropped down to a 11T from 13T and ran a new hot lap on the first run out.
AM03GT is offline
Old 03-26-2025 | 06:41 AM
  #2950
Yes for sure. If you or anyone else would like to draw up some track layouts we can vote to decide on a layout for May/June 2025. Tracks need to fit the 8'x12' layout.
chjosi and Phatz_60 like this.
Poor_Boy is offline
Old 03-26-2025 | 10:39 AM
  #2951
Here's a few layouts I've thought up. I have not tried them yet, so take that into consideration.
These are some of the more difficult layouts. I have some fast flowy layouts too, if that's more what yall are looking for.
iDChuck, chjosi and Phatz_60 like this.
Old 03-26-2025 | 10:49 AM
  #2952
A few of the flowy layouts.
Old 03-26-2025 | 03:29 PM
  #2953
OR if we want to get crazy, we can go back to a Loop Cross Over layout. A cross over layout was the first track I started on. It's tricky, but fun.
Old 03-26-2025 | 11:08 PM
  #2954
OR if we want to see how fast we can make ourselves dizzy, here's an oval.
Old 03-27-2025 | 02:00 AM
  #2955
danjoy25's Avatar
Nice track layout. 1, 4 & 9 looks good
danjoy25 is offline
